SketchUcation Premium Membership
can any one do this facade by SU ?
Postby anas » Fri Apr 27, 2012 1:11 am
it's make me dizzy
Aqua tower in chicago
anas
Re: can any one do this facade by SU ?
Postby Pilou » Fri Apr 27, 2012 1:48 am
Normally any body can make that with SU
It's just a question of time and have the blue print for take the measures of the 86 levels!
Seems it's here :enlight:
but not sure that is a detailed model! ;)
Speedy Galerie
Pilou
Top SketchUcator
Operating system: Windows
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Level of SketchUp: Advanced
Postby mitcorb » Fri Apr 27, 2012 2:25 am
This can be done with Sketchup, but was probably done with Rhino.
mitcorb
Top SketchUcator
SketchUp version: 8
SketchUp use: architecture
Postby Jeff Hammond » Fri Apr 27, 2012 4:08 am
an exploratory go at it..
conclusion(s):
-yes, you can definitely draw this in sketchup
-it's going to take a lot of work (not such a bad thing but in this case, a lot of tedious work)
-probably 2 if not 3 attempts to get the shell shape to your liking..
-i used uniform B-splines then curviloft's Loft to get solid outer shell which then was intersected with the floors.. an alternate approach could be artisan to sculpt the outer shell.
dotdotdot
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby brookefox » Fri Apr 27, 2012 5:41 am
You're sweet, Jeff, and Pilou, but there's no boulder in your future.
(Because you don't want it so, for one.)
~ Brooke
brookefox
SketchUp version: 8
Postby fakircho » Fri Apr 27, 2012 6:27 am
That is actually very easy, only looks hard beacause every floor plate has a different shape and that gives the 3D effect
fakircho
Postby TIG » Fri Apr 27, 2012 11:11 am
Make a big ripply box, grouped.
Smoove tool or Artisan etc will help with this from a proxy...
There's also the RandomizeTIN tool...
Use Slicer5 in Z with spacing at FFLtoFFL and thickness=FloorSlab.
[Or try the older Slicer if not a v8pro user]
Then you have the wavy edged floorplates.
Make a single floor of linear glazing for the orthogonal elements, as a component, and array copy up vertically by the FFLtoFFL value...
Global Moderator
SketchUp version: 2013
License type: Pro
Postby DareDevil » Fri Apr 27, 2012 1:24 pm
I like this tower, and I asked myself how can I do it too.
Of course, you can easily do it with other soft like Rhino, MoI or Bonzai. But you can do it with SU too, and you can use plugins like Artisan (not free) or other or do without.
I tried with the sand box tools to make waves on four horizontal facades and I turn them vertically. After, I intersect with floor planes and I extrude them. Finally, I made the glass block inside. The only thing hard to do without plugin its the joins between the facades, so I used Curviloft.
I cant put the file here because it's more than 5mb, but there is the result (with wave facade before the cut)
DareDevil
Postby Jeff Hammond » Sat Apr 28, 2012 3:08 am
i thought about trying this again using thomthom's bitmap to mesh but i couldn't get it to work right..
ended up doing it in rhino with it's heightfield from image command using a more turbulent water bumpmap (i'm assuming that how the building was done.. the didn't model the water shape.. they imported an image of actual water..)
[and i guess i will say.. rhino would be way better for doing this.. simply because it has superior boolean tools.. ie- a lot faster ;) ]
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby brookefox » Sat Apr 28, 2012 5:35 am
Great job, guys.
Now what will be done and why.
~ Brooke
brookefox
SketchUp version: 8
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Return to Organic Modelling
