by cotty » Sat Apr 21, 2012 9:52 pm
Please, register (free) to access all the attachments on the forums. A picture is worth a 1000 words. A 3D SketchUp model is worth a (1e3)^2 words?!my little gallery
cotty
- Top SketchUcator
- Name: Carsten
- Operating system: Windows
- SketchUp version: 8
- License type: Free/Make
- SketchUp use: education
by Pilou » Sat Apr 21, 2012 10:35 pm
Chairs are very cuty!
Pilou
- Top SketchUcator
- SketchUp version: 6
- SketchUp use: hobby
- Level of SketchUp: Advanced
by cotty » Sun Apr 22, 2012 7:34 pm
cotty
- Top SketchUcator
- Name: Carsten
by cotty » Sun Apr 22, 2012 8:46 pm
cotty
- Top SketchUcator
- Name: Carsten
by cotty » Fri May 25, 2012 2:02 pm
A new post after a long time... ...but with power: a wind turbine  windturbine.jpg
cotty
- Top SketchUcator
- Name: Carsten
by cotty » Mon May 28, 2012 7:27 pm
cotty
- Top SketchUcator
- Name: Carsten
by cotty » Mon May 28, 2012 7:29 pm
cotty
- Top SketchUcator
- Name: Carsten
by ninopiamonte » Tue May 29, 2012 2:22 am
Nice overall, keep sharing Thanks!
ninopiamonte
- Name: Nino Piamonte
- License type: Pro
- SketchUp use: architecture
by shri » Tue May 29, 2012 6:19 am
shri
- Name: shrijan
by baz » Tue May 29, 2012 9:34 am
Nice cotty. How would you go about this if you wanted a single face for the front and back? Ie: as if it were bent plywood with vertical edges in the z plane. Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:) baz cotty_bookshelf.jpg
Please, register (free) to access all the attachments on the forums. "What do we want?...Time travel... When do we want it?... Irrelevant" Thanks to Funny Pics
baz
- Name: Barry
- License type: Pro
- SketchUp use: other
by cotty » Thu May 31, 2012 4:08 pm
baz wrote:Just wondering how an artisan would do it
I am not shure, but I will dream of it, maybe a solution will appear ... Here is a little boat ... boat.jpg
cotty
- Top SketchUcator
- Name: Carsten
by d12dozr » Thu May 31, 2012 5:06 pm
baz wrote:How would you go about this if you wanted a single face for the front and back? Ie: as if it were bent plywood with vertical edges in the z plane.
Delete the sides, crease the corners, run artisan, then just draw 4 lines to connect the corners together. Like so: cotty_baz_bookshelf.jpg Awesome collection, Cotty - please keep it up! This thread was invaluable to me a couple weeks ago when I made my first real project with SDS (I haven't needed to upgrade to Artisan yet.) The project was for 3D printing, and my customer was very happy with the result, so thank you!
Please, register (free) to access all the attachments on the forums. "There is a man in the world who will never be turned down... he is the man who delivers the goods."
d12dozr
- Top SketchUcator
- Name: Marcus
- License type: Pro
- SketchUp use: product design
by baz » Fri Jun 01, 2012 1:03 am
Hi Marcus, can you explain the 'crease' a bit more? The model has the labels but I'm missing the creases.
baz
- Name: Barry
- License type: Pro
by mitcorb » Fri Jun 01, 2012 1:27 am
Hi, cotty: Your thread is inspiring and helpful. I have tried a few of the examples, myself. Thank you for posting.
mitcorb
- Top SketchUcator
- Name: Tim
by Jeff Hammond » Fri Jun 01, 2012 4:50 am
baz wrote:Nice cotty. How would you go about this if you wanted a single face for the front and back? Ie: as if it were bent plywood with vertical edges in the z plane. Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:) baz
cotty_bookshelf.jpg maybe? [edit] after step3, delete the face which has all sorts of coplanar lines from the subsmooth.. draw a line to form a new single face.. then push/pull..
Please, register (free) to access all the attachments on the forums. dotdotdot
Jeff Hammond
- Global Moderator
- Operating system: Mac
- License type: Pro
by d12dozr » Fri Jun 01, 2012 1:30 pm
baz wrote:Hi Marcus, can you explain the 'crease' a bit more? The model has the labels but I'm missing the creases.
Just use the Crease tool (at least that's what its called in Subdivide & Smooth), and click on each of those vertices. The Crease tool icon changes from Red when uncreased to Green when creased. There's not a visible effect right away on the model, but you'll be able to tell the difference after running the plugin. ...or in this case, Jeff's way is simpler, but you'll still want to crease the end vertices before subdividing so you get square ends.
d12dozr
- Top SketchUcator
- Name: Marcus
- License type: Pro
by baz » Tue Jun 05, 2012 4:10 am
Thanks Marcus, got it.
baz
- Name: Barry
- License type: Pro
by cotty » Tue Jun 05, 2012 9:05 pm
Thanks to ninopiamonte, shri, d12dozr, mitcorb for your kind words. I'll try to add new examples regularly. If you have any ideas for simple geometries, let me know or feel free to share them here too... Another example: a very simple wind flower... cotty_wind_flower.jpg
cotty
- Top SketchUcator
- Name: Carsten
by cotty » Thu Jun 07, 2012 9:26 am
cotty
- Top SketchUcator
- Name: Carsten
by leminilab » Tue Jun 12, 2012 9:37 am
Hi, Here's a little contribution to this great thread: pipistrello lamp.png pipistrello bsd.png pipistrello lamp.skp This one can be certainly found on the internet but I found this an interesting modelling challentge. Could be better but there you go. Thanks a lot for starting this Cotty! Nicolas
Please, register (free) to access all the attachments on the forums. Live every day as if it were your last and then some day you'll be right.
leminilab
- Name: Nicolas
by cotty » Wed Jun 27, 2012 10:19 pm
cotty
- Top SketchUcator
- Name: Carsten
by cotty » Sat Jun 30, 2012 8:22 am
cotty
- Top SketchUcator
- Name: Carsten
by leminilab » Sat Jun 30, 2012 10:07 am
Seriously, I'm having a blast seeing you enjoying what you do that much! I like!
leminilab
- Name: Nicolas
by cotty » Sat Jun 30, 2012 5:57 pm
leminilab wrote:Seriously, I'm having a blast seeing you enjoying what you do that much! I like!
Thank you! And you are right, I enjoy these little Artisan practices
cotty
- Top SketchUcator
- Name: Carsten
by utiler » Mon Jul 02, 2012 5:24 am
I'm with you nicholas; cotty you bring joy to my day when I've seen what you're doing with Artisan....
utiler
- Top SketchUcator
- Name: Andrew
- License type: Pro
by cotty » Mon Jul 02, 2012 8:06 pm
utiler wrote:I'm with you nicholas; cotty you bring joy to my day when I've seen what you're doing with Artisan....
Thank you! Here is the next one: "The hand" (anatomically questionable  ) ... cotty_hand.jpg
cotty
- Top SketchUcator
- Name: Carsten
by cotty » Tue Jul 03, 2012 12:06 pm
cotty
- Top SketchUcator
- Name: Carsten
by pibuz » Tue Jul 03, 2012 3:36 pm
Wonderful!
pibuz
by pbacot » Tue Jul 03, 2012 8:02 pm
Would like to see some steps towards the proxy. Is that all free form joining of edges, say for carafe?
- Top SketchUcator
- Name: pbacot
- License type: Pro
by cotty » Tue Jul 03, 2012 8:38 pm
pbacot wrote:Would like to see some steps towards the proxy. Is that all free form joining of edges, say for carafe?
Here are some of the first steps, I will make a more detailed "making of" for the next example... glascarafe_firststeps.jpg
cotty
- Top SketchUcator
- Name: Carsten
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
- Robot
Return to Organic Modelling
