by cotty » Thu Apr 05, 2012 2:33 pm
cotty
- Top SketchUcator
- Name: Carsten
- Operating system: Windows
- SketchUp version: 2020
- License type: Pro
- SketchUp use: hobby
- Level of SketchUp: Advanced
by cotty » Thu Apr 05, 2012 2:35 pm
YogieStars wrote:my apples
Nice models and great render!
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by YogieStars » Thu Apr 05, 2012 2:40 pm
cotty wrote:YogieStars wrote:my apples
thanks
YogieStars
- Name: Yogie
by ninopiamonte » Fri Apr 06, 2012 2:36 am
Oh, I love Danbo. You make me feel good~!
ninopiamonte
- Name: Nino Piamonte
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
by cotty » Sun Apr 08, 2012 12:52 pm
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Wed Apr 11, 2012 11:22 am
A makefured teddy ... (The attached model only contains some of the rendered hairs because of filesize) teddy.jpg
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Wed Apr 11, 2012 3:07 pm
Sea shark model by solo from here... (proxy model is attached there) sea_shark_solo.jpg
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Wed Apr 11, 2012 3:15 pm
Lomme bed by leminilab from here... (ZIP with model is attached there) leminilab_lomme_bed.jpg
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Fri Apr 13, 2012 6:56 am
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Fri Apr 13, 2012 7:10 am
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Fri Apr 13, 2012 4:27 pm
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Fri Apr 20, 2012 9:12 pm
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Fri Apr 20, 2012 10:31 pm
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by baz » Sat Apr 21, 2012 2:07 am
That second chair is a ripper cotty, I wouldn't mind having a go at making it for real using laminated timber. baz
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
- Name: baz
- SketchUp version: 2019
- License type: Pro
- SketchUp use: other
by cotty » Sat Apr 21, 2012 7:28 am
baz wrote:That second chair is a ripper cotty, I wouldn't mind having a go at making it for real using laminated timber. baz
Thank you! If it was a chair of Alvydas, it would probably be beautiful and perfect textured as laminated timber  . Maybe this will be a task to practice the new texturing tools out there ...
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Sat Apr 21, 2012 9:52 pm
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by pilou » Sat Apr 21, 2012 10:35 pm
Chairs are very cuty!
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
- License type: Free/Make
by cotty » Sun Apr 22, 2012 7:34 pm
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Sun Apr 22, 2012 8:46 pm
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Fri May 25, 2012 2:02 pm
A new post after a long time... ...but with power: a wind turbine  windturbine.jpg
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Mon May 28, 2012 7:27 pm
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by cotty » Mon May 28, 2012 7:29 pm
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by ninopiamonte » Tue May 29, 2012 2:22 am
Nice overall, keep sharing Thanks!
ninopiamonte
- License type: Pro
by shri » Tue May 29, 2012 6:19 am
shri
- Name: shrijan
by baz » Tue May 29, 2012 9:34 am
Nice cotty. How would you go about this if you wanted a single face for the front and back? Ie: as if it were bent plywood with vertical edges in the z plane. Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:) baz cotty_bookshelf.jpg
baz
- Name: baz
- License type: Pro
by cotty » Thu May 31, 2012 4:08 pm
baz wrote:Just wondering how an artisan would do it
I am not shure, but I will dream of it, maybe a solution will appear ... Here is a little boat ... boat.jpg
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
by d12dozr » Thu May 31, 2012 5:06 pm
baz wrote:How would you go about this if you wanted a single face for the front and back? Ie: as if it were bent plywood with vertical edges in the z plane.
Delete the sides, crease the corners, run artisan, then just draw 4 lines to connect the corners together. Like so: cotty_baz_bookshelf.jpg Awesome collection, Cotty - please keep it up! This thread was invaluable to me a couple weeks ago when I made my first real project with SDS (I haven't needed to upgrade to Artisan yet.) The project was for 3D printing, and my customer was very happy with the result, so thank you!
d12dozr
- Top SketchUcator
- Name: Marcus
- SketchUp version: 2015
- License type: Pro
- SketchUp use: product design
by baz » Fri Jun 01, 2012 1:03 am
Hi Marcus, can you explain the 'crease' a bit more? The model has the labels but I'm missing the creases.
baz
- Name: baz
- License type: Pro
by mitcorb » Fri Jun 01, 2012 1:27 am
Hi, cotty: Your thread is inspiring and helpful. I have tried a few of the examples, myself. Thank you for posting.
mitcorb
- Top SketchUcator
- Name: mitcorb
- SketchUp version: 2016
- License type: Pro
by jeff hammond » Fri Jun 01, 2012 4:50 am
baz wrote:Nice cotty. How would you go about this if you wanted a single face for the front and back? Ie: as if it were bent plywood with vertical edges in the z plane. Of course one could intersect a plane and intersect/delete, which image shows. Just wondering how an artisan would do it:) baz
cotty_bookshelf.jpg maybe? [edit] after step3, delete the face which has all sorts of coplanar lines from the subsmooth.. draw a line to form a new single face.. then push/pull..
dotdotdot
jeff hammond
- Global Moderator
- Name: Jeff Hammond
- Operating system: Mac
- License type: Pro
- Robot
Return to Organic Modelling
