SketchUcation Plugin Store
Shape bender doesn't really work
Postby Jet » Mon Jul 25, 2011 2:49 pm
Doesn't seem like Chris is available. I have no choice but just create a new post here. Shape bender doesn't really work for this kind of shape. Anyone know why?
Never give up, Never surrender!
Jet
Re: Shape bender doesn't really work
Postby SketchUpNoobie » Mon Jul 25, 2011 3:03 pm
Works fine for me.
Try to be a little more specific. What does "not work" mean? Does SketchUp crash? Does does the plugin just hang? Do you get an error message? Do you get messed up geometry?
You'll get a better answer if you let people know whats going on.
SketchUpNoobie: the complete noob in all things SketchUp.
SketchUpNoobie
Operating system: Windows
SketchUp version: 8
License type: Free/Make
SketchUp use: hobby
Level of SketchUp: Beginner
Postby Jet » Mon Jul 25, 2011 3:08 pm
SketchupNoobie wrote:Works fine for me.
I run the shape bender command but the object doesn't bender at all.
Jet
Postby Box » Mon Jul 25, 2011 3:25 pm
Works for me.
Did you hit enter after you clicked the two lines?
Opinions are like wives.
Those found on the internet have been known to contain varying traces of nuts!
SketchUp version: 8
SketchUp use: other
Postby TIG » Mon Jul 25, 2011 3:27 pm
It does...
See this... I have moved the group/line/curve onto the origin.
The bent copy was being made up in the air because nothing was at z=0. It is onlt slightly bent because the curve you use is very 'flat'...
Global Moderator
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Jet » Mon Jul 25, 2011 3:37 pm
Box wrote:Works for me.
Of course, I did.
I think it might have something to do with this:
Jet
Postby TIG » Mon Jul 25, 2011 3:40 pm
Doh!
You never mentioned that error-message until now!
Help us help you. :roll:
We are not that psychic... :?
If you read the tool's download page it clearly says it also requires 'progressber.rb'.
This is a helper file that shows progress in the status-bar.
Download it free from Smustard.com - there is even a link........
Global Moderator
License type: Pro
Postby Box » Mon Jul 25, 2011 3:41 pm
Link is in the download post.
SketchUp version: 8
SketchUp use: other
Postby Jet » Mon Jul 25, 2011 4:02 pm
TIG wrote:Doh!
Thanks Tig.
I works now, takes long though. but how come it created some pieces separated from the shape. I don't see yours come out like that.
Jet
Postby Jet » Mon Jul 25, 2011 4:13 pm
and how do I get rid of those doted vertical line on surface. I can't really use offset when they r there.
Jet
Postby Box » Mon Jul 25, 2011 4:16 pm
Turn off Hidden Geometry.
View/untic Hidden Geometry
P.S. Normal offset won't work on a curved surface, you need the offset from Tools On Surface.
SketchUp version: 8
SketchUp use: other
Postby Jet » Mon Jul 25, 2011 5:03 pm
Box wrote:Turn off Hidden Geometry.
Thanks Box. It helps.
BTW, How do I weld these two pieces together seamlessly?
Jet
Postby vicspa » Mon Jul 25, 2011 5:21 pm
Select the middle joining lines and delete them.
vicspa
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby Jet » Mon Jul 25, 2011 5:31 pm
vicspa wrote:Select the middle joining lines and delete them.
On the flat one of course you can do that. the one I was showing is on a curve. when deleting the joining lines it will only destroy the structure.
Like this:
Jet
Postby TIG » Mon Jul 25, 2011 5:32 pm
Hide them - Erase+Shift
or
Smooth them - Erase+Ctrl
Global Moderator
License type: Pro
Postby vicspa » Mon Jul 25, 2011 5:34 pm
Yes Jet that happened to me, so I only deleted the front, back and bottom, left the curved one in place.
vicspa
SketchUp version: 8
License type: Pro
Postby TIG » Mon Jul 25, 2011 5:36 pm
As Victor shows it's probably best to copy/mirror one half so you bend the whole thing centered on the line/curve so you avoid the 'seam' problems...
Global Moderator
License type: Pro
Postby vicspa » Mon Jul 25, 2011 5:37 pm
Tig, :thumb: :thumb: :thumb:
vicspa
SketchUp version: 8
License type: Pro
Postby Jet » Mon Jul 25, 2011 6:19 pm
TIG wrote:Hide them - Erase+Shift
or
I knew. that's what I've done.
I need to delete the line, but not just hide them. Cause I need to work on a seamless surface.
Jet
Postby TIG » Mon Jul 25, 2011 6:32 pm
'Smooth' them then!
They will then be like any other surface edge :?
Global Moderator
License type: Pro
Postby Jet » Mon Jul 25, 2011 6:56 pm
vicspa wrote:Yes Jet that happened to me, so I only deleted the front, back and bottom, left the curved one in place.
thanks, vicspa. I did that too. but the curved shape became too big. Is there a way to control it?
Jet
Postby gilles » Mon Nov 21, 2011 7:12 pm
Make the curve the shape and the line the same length (entity info).
gilles
Top SketchUcator
Operating system: Mac
SketchUp version: 8
SketchUp use: other
Postby sondos » Mon May 06, 2013 11:40 pm
SketchUpNoobie wrote:Works fine for me.
why shape bend can't choose the line when it ask me to choose it
sondos
SketchUp version: 8
License type: Pro
Postby sondos » Mon May 06, 2013 11:45 pm
I recently started using plugins on sketchup and Im also kinda amateur in using this program. I added your Plugin to my sketchup. Im trying to bend a wall with all its windows and openings but Im having a problem. Every time that I wanna activate the plugin it says "Please have a single group or Component to bend selected before activating the script."
I tried it with making my wall into a group and then selecting it, or exploding it and selecting the very bottom line, or drawing a line at the bottom of the wall and selecting it, or selecting both the line from the wall and the curved single line that I had made but nothing is working. Any suggestion?
sondos
SketchUp version: 8
License type: Pro
Postby TIG » Tue May 07, 2013 8:29 am
sondos wrote:...why shape bend can't choose the line when it ask me to choose it
The line AND the curve must NOT touch any other geometry, including each other.
This first picked line must also be parallel to the X-axis [red].
Tips:
If you get Ruby Console errors relating to 'cursors' it suggests that you have not installed this tool correctly and it's folder of cursor images etc is missing or incomplete.
If you get other errors in the Ruby Console or the tool 'stalls' after starting, then also ensure that you have downloaded and installed the helper file 'progressbar.rb' from 'smustard.com', as instructed in this tool's download page notes...
Global Moderator
License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Return to Organic Modelling
