SketchUcation Premium Membership
[Tutorial] Tufted Ottoman
Postby boofredlay » Thu Feb 03, 2011 5:53 pm
stereofidelic asked here how to model a tufted style ottoman so I did a quick tutorial. Hope this helps someone.
This requires the Subdivide and Smooth plugin.
Simply make a square or rectangle and offset it a couple times. Then manually connect all the points, here just draw from corner to corner. I then drew lines from midpoint on each side. Using the move tool I created a bit of "elevation" to the mesh, simulating where the buttons would pull the fabric inward. Then I copied the shape many times and then ran the Subdivide and Smooth plugin with one iteration. That's it.
boofredlay
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: Tufted Ottoman
Postby Rich O Brien » Thu Feb 03, 2011 6:07 pm
Nice :thumb:
deserves [Tutorial] tag ;)
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Re: Tufted Ottoman
Postby boofredlay » Thu Feb 03, 2011 6:11 pm
True. I will add it.
Something I was wondering. Now that we have the organic modeling sub-forum, how do we decide where the tutorials actually go? If it is an Organic tutorial should it go here or in the SketchUp tutorial section. Hmmm
boofredlay
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Tutorial] Tufted Ottoman
Postby Rich O Brien » Thu Feb 03, 2011 6:13 pm
Csaba?
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby stereofidelic » Fri Feb 04, 2011 8:29 am
Bookmarked this page, and I will try to follow it this weekend. :berserk:
stereofidelic
Postby ely862me » Fri Feb 04, 2011 10:38 am
Take those lines out because they give a square result when subsmoothing .
See what i mean.
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby john.warburton » Fri Feb 04, 2011 12:31 pm
Excellent tutorial - really useful, thank you.
Life's a reach, and then you gybe. http://www.pixelorchard.com
john.warburton
Name: John Warburton
Re: Tufted Ottoman
Postby Gaieus » Fri Feb 04, 2011 2:11 pm
Boofredlay wrote:True. I will add it.
Rich O'Brien wrote:Csaba?
I dunno guys. Think about it - we can move these any time. Or if we move it (and make more), we can keep a list with links here. Maybe tag like [Tutorial organic] (we used to gad tuts with special names, too). Then we can somehow generate a search result page like the Plugin Index.
Ah and before I forget; great tut! :thumb:
Administrator
SketchUp version: 2013
License type: Pro
SketchUp use: historical reconstruction
Postby vicspa » Fri Feb 04, 2011 2:35 pm
(Bookmarked) Thanks guys, I hope there are more tuts like this once SDS2 comes out. :berserk:
vicspa
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby boofredlay » Fri Feb 04, 2011 3:21 pm
ely862me wrote:Take those lines out because they give a square result when subsmoothing.
Thanks for improving my knowledge. :thumb:
boofredlay
Global Moderator
SketchUp version: 8
License type: Pro
Postby Bryan K » Sun Feb 06, 2011 1:44 am
Excellent tutorial(s).
I've also learned something new.
SketchUp version: 8
License type: Free/Make
SketchUp use: product design
Postby danielschultz » Wed Sep 14, 2011 11:13 pm
I've followed your tutorial, starting with a square. My result after subdivide and smooth "facets" the corners of the square as shown in the attached photo. Help please.
danielschultz
Postby Gaieus » Sun Sep 18, 2011 2:55 pm
You need to use the crease tool on those edges before subdividing so that they remain intact after subdivision.
Administrator
License type: Pro
Postby boofredlay » Sun Sep 18, 2011 3:15 pm
Well yes and no. In the original example I had that piece connected to many others to make the full ottoman cushion. Therefore you do not need to use the crease tool as it is all together. But if you are only doing one segment as you have shown Daniel then you need to crease the corners, not the edges.
boofredlay
Global Moderator
SketchUp version: 8
License type: Pro
Postby Gaieus » Sun Sep 18, 2011 5:41 pm
well, corners then, thanks Eric. point is that it keeps the thing.
Administrator
License type: Pro
Postby gudio83 » Thu Dec 08, 2011 11:12 pm
i'm following the tutorial , but after 2 iterations my square is always in 2D. there is no a hole. What i get wrong?
gudio83
Postby ely862me » Fri Dec 09, 2011 9:12 am
Probably you don't have any "hole" in it .First you must create the "hole" then subdivide.
See what I mean .
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby mwm5053 » Mon Mar 05, 2012 5:09 pm
Been having a HELL of a time with that crease tool till I saw this.
Thanks Eric
So what does creasing edges or quads do for it I don't see much difference when doing it that way.
mwm5053
Premium Member
Premium Member
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby panixia » Sat Jun 16, 2012 11:30 am
i did a slight variation to the proxy to obtain a quad-mesh most confortable for texture mapping, faster selections and further editing and it works fine for me.. hope it can help someone else for mapping leather, fabrics, etc. on it.
quadface tools rocks!
panixia
SketchUp version: 8
SketchUp use: other
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Return to Organic Modelling
