Vikingship
Vikingship
Postby Epix3D » Thu Jul 16, 2020 12:48 pm
This shipmodel is an import from other CAD program and I am trying to recreate this vikingship in SketchUp making a low poly model. Tried using Curviloft but cannot make it work.
Can anyone show me how it can be done?
[img]
[/img]
ShipSplines2018.skp
Attached find the SketchUp model
Epix3D
Premium Member
Premium Member
Re: Vikingship
Postby tuna1957 » Fri Jul 17, 2020 2:27 am
You might get a little more help if you save back your model to an earlier SU version and repost it. Not everyone is using SU2020 for various reasons. :thumb:
tuna1957
Premium Member
Premium Member
Re: Vikingship
Postby Epix3D » Fri Jul 17, 2020 11:59 am
Model saved to version 2018. Thank you for tip. ;)
Epix3D
Premium Member
Premium Member
Re: Vikingship
Postby HornOxx » Fri Jul 17, 2020 12:14 pm
... SkUp 2017(the last Make) could be better :) ;)
never trust a skinny cook
HornOxx
Re: Vikingship
Postby Mike Amos » Fri Jul 17, 2020 5:37 pm
I would suggest V8, lots of folk still use V8 pro.
Premium Member
Premium Member
Re: Vikingship
Postby tuna1957 » Sat Jul 18, 2020 12:27 am
Had to fool about with this, couldn't help myself :lol: . Boy what a mess ! After digging through all the nested repetitive components there was enough damage to the mesh towards the bow - stern end figured I'd redo it from semi scratch.
Got a decent profile at the middle of the hull and copied the upper edge of the hull for a path. Used "follow me" tool and trimmed things up down the center with a cutting plane. Ended up with a reasonably decent 1/4 hull. Did a little reshaping on the keel and there you go :thumb: Posting the model , your welcome to use it if it suits your needs.
tuna1957
Premium Member
Premium Member
Re: Vikingship
Postby tuna1957 » Sat Jul 18, 2020 1:20 am
One more thing.... I tried pulling contours off the model you posted and using Curviloft to skin it .... no love there. After doing my thing with follow me there was a lot of brute force clean up to do. Realized the original model has tons of minute line segments everywhere. I think thats what was keeping Curviloft from working on the profiles copied from the original model......
tuna1957
Premium Member
Premium Member
Re: Vikingship
Postby Bryan K » Sun Jul 19, 2020 8:45 am
That is amazing. :thumb:
Re: Vikingship
Postby pilou » Sun Jul 19, 2020 6:34 pm
Cool ;)
For any problem save as V6 will be the better solution! :)
Of course the Gif recorder don't gives the same render than the original Twinmotion :)
Speedy Galerie
Top SketchUcator
Re: Vikingship
Postby pbacot » Sun Jul 19, 2020 6:54 pm
Is that some comment from medieval Paris, a swamped Viking ship?
Top SketchUcator
Re: Vikingship
Postby pilou » Sun Jul 19, 2020 9:15 pm
It's beaten by the waves, but it doesn't sink!
Speedy Galerie
Top SketchUcator
Re: Vikingship
Postby Epix3D » Mon Jul 20, 2020 1:16 pm
Wow Tuna!
What a great job! You also managed to reduce the model file significantly which was my goal. Thank you.
The model was converted from some other CAD program and was pretty much messed up.
Thank you again. :D
Here is a photo from my hometown Tønsberg where the original vikingships where found. While the originals stays in the museums in Oslo they build replicas at the site the old way using same tools as the vikings.
This is from the launch of the Oseberg replica at the harbor in the middle of Tønsberg. The ships are really beautyful work of art.
Epix3D
Premium Member
Premium Member
Re: Vikingship
Postby Epix3D » Mon Jul 20, 2020 2:42 pm
(Enscape 5sec)
Epix3D
Premium Member
Premium Member
Re: Vikingship
Postby HornOxx » Mon Jul 20, 2020 4:03 pm
all this is so cool! :thumb: as well as your fast Enscape render :D
HornOxx
Re: Vikingship
Postby tuna1957 » Mon Jul 20, 2020 4:15 pm
Epix3D , Glad it helped you out. Realized it was not your model to start with. Was crazy how chunks of random mesh was scattered into different components and identical bunches of mesh were unique components overlapping one another. Made me wonder if it was originally modeled that way or if SU went crazy importing it. Getting rid of all the overlapping repetitive components and multitudes of short line segments down to a clean SU mesh really did make a difference in file size. Kept it simple and figured the final result was clean enough for you to add detail if needed. :thumb:
tuna1957
Premium Member
Premium Member
Re: Vikingship
Postby pbacot » Mon Jul 20, 2020 5:42 pm
Great job! Thanks for all the details too!
Top SketchUcator
Return to WIP
