by Mike Amos » Sun Feb 04, 2018 10:51 am
An 11' long by just under 5' 6" wide coupe. Rear mid engined with a three cylinder turbo engine potentially an electric motor assist too. This render was to check for panel quality and fit.
- Premium Member
- Name: Mike Amos
- Operating system: Windows
- SketchUp version: 2019
- License type: Pro
- SketchUp use: hobby
by L i am » Sun Feb 04, 2018 12:21 pm
Cool project Mike  Out of curiosity how many hours so far?
- Premium Member
- Name: Liam day
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: landscape architecture
by Mike Amos » Sun Feb 04, 2018 3:38 pm
Thanks L i am. So far this version (#60 in this series) about 12 hours. Mainly due to modeling aerodynamic surfaces and modules so if I can get this done in another 12 I'll be happy. The radiator outlets will exhaust onto the engine/transmission cover hopefully directly onto the lower surface of the rear wing. The exhaust will also exit near this outlet and have a baffle to stall the rear wing for straight line speed.
- Premium Member
- Name: Mike Amos
- License type: Pro
by tuna1957 » Sun Feb 04, 2018 9:24 pm
 Looking forward to seeing the finished model.
tuna1957
- Premium Member
- Name: Charles Treon
- Operating system: Mac
- SketchUp version: 2015
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Beginner
by L i am » Mon Feb 05, 2018 11:01 am
Mike Amos wrote:Thanks L i am. So far this version (#60 in this series) about 12 hours. Mainly due to modeling aerodynamic surfaces and modules so if I can get this done in another 12 I'll be happy. The radiator outlets will exhaust onto the engine/transmission cover hopefully directly onto the lower surface of the rear wing. The exhaust will also exit near this outlet and have a baffle to stall the rear wing for straight line speed.
Am I reading you correctly. This is number 60, that you have done?
- Premium Member
- Name: Liam day
by Mike Amos » Mon Feb 05, 2018 6:54 pm
Number 60 in this series but several hundred overall. I tend to chuck those I do not like so the total number is a miss Terry.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Mike Amos » Tue Feb 06, 2018 11:39 pm
Moving on, the white oblong is the footprint of a Lotus Elise which demonstrates how small my project is.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Bryan K » Fri Feb 09, 2018 9:11 am
Looking good!
- Name: Bryan K
- SketchUp use: product design
by Mike Amos » Sat Feb 10, 2018 10:40 am
Thanks Bryan.
- Premium Member
- Name: Mike Amos
- License type: Pro
by liam887 » Thu Feb 15, 2018 11:58 pm
Nice work!
liam887
- Name: liam887
- SketchUp version: 7
- License type: Pro
- SketchUp use: illustration, cartoons
- Level of SketchUp: Advanced
by Mike Amos » Sat Feb 17, 2018 11:08 am
Thanks Liam, I am getting the feeling I may have gone too small with this one.
- Premium Member
- Name: Mike Amos
- License type: Pro
by tuna1957 » Sat Feb 17, 2018 6:36 pm
Good progress on this one.
tuna1957
- Premium Member
- License type: Pro
by liam887 » Sat Feb 17, 2018 6:40 pm
Mike Amos wrote:Thanks Liam, I am getting the feeling I may have gone too small with this one.
You can always scale it up my a meter if you need no?
liam887
- Name: liam887
- License type: Pro
by Mike Amos » Sun Feb 18, 2018 1:46 pm
I did upscale to Lotus Elise length but it just does not work. Horrible in fact. I may need to rethink my engine/power system for this but that is much easier, there is a very useful two cylinder engine in the Fiat 500 and that with electric assistance and a light vehicle would go some. Batteries go where the transmission tunnel is.
- Premium Member
- Name: Mike Amos
- License type: Pro
by hellnbak » Mon Feb 26, 2018 8:02 am
Yay, something with wheels! Looking good, Mike. I'm curious as to why you say you might have gone too small (assuming the driver can fit comfortably in it). Also curious about the object protruding from the front. A laser maybe? Keep at it! Steve
hellnbak
- Premium Member
- Name: hellnbak
by Mike Amos » Mon Feb 26, 2018 12:10 pm
Thanks Steve, nice to see you around. The projecting thing at the front is the steering column that I need to alter, a laser might be useful in traffic. When I say possibly too small I am talking about radiator air flow and a decent fuel tank. Thing is, as intended this whole vehicle is meant to tip the3 scales at about 600-650kg. The crumple zones are going to be aluminium honeycomb structures at the front and a similar item at the rear incorporating the cat/exhaust can. All of this is getting very tight in the structure so far attempted. However it keeps the brain, whats the word, clock thing.............
- Premium Member
- Name: Mike Amos
- License type: Pro
- Robot
Return to WIP
