[Plugin] SketchyBevel 0.1(Updated May 11)
• Page 2 of 5 • 1, 2, 3, 4, 5
Re: [Plugin] SketchyBevel 0.1where is the file to download your plugin???
...i don't find it!!! please i need SketchyBevel!!!
Re: [Plugin] SketchyBevel 0.1Look at first post on 1st page one of this thread.
i click on [Plugin] SketchyBevel 0.1 but this is a link to another page! ...i'm going crazy. please HELP ME!!!
Re: [Plugin] SketchyBevel 0.1Right-click (Windows) or press command and click (Mac), then download.
Bill Maher on the French: "They invented sex during the day, lingerie and the tongue."
Re: [Plugin] SketchyBevel 0.1Stinkie you have been using your mac too long that you forgot the Windoze system.
Left click and save in your SU plugins folder.
Re: [Plugin] SketchyBevel 0.1lol! You're right. My humblest apologies!
I'm gonna trade in my 8 cores for an abacus, I think. Bill Maher on the French: "They invented sex during the day, lingerie and the tongue."
Re: [Plugin] SketchyBevel 0.1i feel stupid! but i'm clicking on it ( [Plugin] SketchyBevel 0.1 )
...if there is another way to download it...SHOW ME PLEASE!
Re: [Plugin] SketchyBevel 0.1Look at the very bottom of the first post-- under the animating demo. There's an attachment called:
SketchyBevel.rb That's what you click on. If that doesn't work for you, then tell us what browser and OS you are using.
Re: [Plugin] SketchyBevel 0.1THANK YOU!!!! THANK YOU!!! THANK YOU!!!
but before under the animating demo there wasn't this file, but the was a sentence on a yellow backgrond that i don't remember! maybe a stay a lot in front of the pc... Howerer THANK YOU!!!
Re: [Plugin] SketchyBevel 0.1Like the built in Outliner tool Bevel doesnt work with "holes" in faces. You can usually work around those problems by subdividing the face with a hole.
Here is an example. The mesh on the left doesn't Bevel right. But add a line to break up the hole and it works. Then you can just erase the extra edges. Please, register (free) to access all the attachments on the forums.
Re: [Plugin] SketchyBevel 0.1Thanks for the explanation, it clarifies a lot.
Good call. Didn't realise he hadn't found the attachment. Bill Maher on the French: "They invented sex during the day, lingerie and the tongue."
Re: [Plugin] SketchyBevel 0.1Thanks Chris,
Drawing that extra line indeed works
Re: [Plugin] SketchyBevel 0.1Thank you Chris!!! Extra line is the solution
Daniel S PS. Not very important but when you apply the sketchybevel tool 2 times.. the plugin create a lot of extra lines that are not used and not create faces... is there a way to easily eliminate this lines? Please, register (free) to access all the attachments on the forums.
Only thing you can do is turn off "cap holes" after 1st bevel and then fill them in by hand. Hopefully I can figure out how to eliminate the extra faces in future version.
Re: [Plugin] SketchyBevel 0.1Daniel, you could also try running that CAD cleanup script that was recently released (sorry i cant remeber exactly what its called or who its by
EDIT: this is the one i meant.
Re: [Plugin] SketchyBevel 0.1Missed this one while I was away, but a nice present upon my return - Thanks!
Thank you, but it dosen´t work with this lines. I have another old script that removes unused Edges but don´t delete this ones. It´s not a big problem, but when you use soften edges this lines affect the model. Daniel S Please, register (free) to access all the attachments on the forums.
Re: [Plugin] SketchyBevel 0.1 very cool! Merci. Spasibo. Gracias. Danke. Tanks a lot! If I make it look easy. . .rest assured--it probably is.
Re: [Plugin] SketchyBevel 0.1too bad i don't visit the ruby forum...i found a link to this topic in the Kerkythea forum.
anyway, thanks a lot for this plugin!
Re: [Plugin] SketchyBevel 0.1Chris, this is incredibly useful script. What a stud you are. Thank you very much. In case anybody was wondering, this works in SU5 as well as SU6.
Ron
Re: [Plugin] SketchyBevel 0.1Ah yes, the old "delete the related components" trick. It's a feature. Actually I see the same thing. It appears that the plugin doesn't appreciate components. Still, thank you very much for this. Inspecting mirrors is a job I could easily see myself doing.
So the problem is that you cant bevel geometry inside a component? Ill try to fix that next version.
Re: [Plugin] SketchyBevel 0.1That seems to be half of what Jon was illustrating. The other is that the other instances of the component get deleted and the one that is being edited ends up exploded.
Thanks again for this plugin. Dave Inspecting mirrors is a job I could easily see myself doing.
Oh, That. Yeah Ill fix.
Have been following this thread for a while, great ruby!! Is there a chance of the plug-in being converted to metric for those of us on the other side? cheers, purpose/expression/purpose/....
SketchUcation One-Liner AdvertsKeyframe Animation plugin - animate your SketchUp model by adding movement to any object.
