SketchUcation Plugin Store
[Plugin] SU2POV for GSU6
Re: [Plugin] SU2POV for GSU6
Postby Didier Bur » Tue Apr 22, 2008 7:36 pm
if I import the .skp light components should they function in a similar manner as if they had been loaded via the scripts?
Yes.
Will the components only work if they are placed on the su2pov layer or will they on other layers too?
If they are on other layers, their geometry can possibly be exported (if this layer is active) and will inhibit light from lighting the scene. The script automatically hides the su2pov layer to prevent this problem.
Am I correct that quotes need to be put around the N in ......Output_File_Type="N" ....?
No, no quotes needed, just: Output_File_Type=N
I'll publish a minor release soon: you'll have additionnal output options such has image size, image format, antialias on/off, alpha channel on/off.
For the image size you'll be able to render the same size as your SU window, or common sizes, or choose your size as usual within pov-ray.
But remember, I want to keep this thing as simple as possible...
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby JClements » Tue Apr 22, 2008 8:10 pm
Didier:
I DO appreciate your designing the script to keep "keep it simple". It is partcularly useful for "beginners" or "casual" users like myself and I thank you for doing so.
I was a bit frustrated that the Point and Area light scripts didn't work as designed for me but since I can import the light components manually it is not that big of a deal.
I do wish cylindrical (smoothed) surfaces could be handled better since they are prevelent in many of my models, but what the POV renderer does offer will be helpful in certain instances. Question: Do you think Fred06's the forthcoming subdivision scripts would be helpful in POV generating better renderings of smoothed surfaces?
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby Didier Bur » Tue Apr 22, 2008 10:44 pm
Hi again,
Small bug found and fixed. I will publish the patch asap.
Yes, as it will creta more faces to represent curved surfaces.
Now let's go to sleep ;) :ecstatic:
Didier Bur
SketchUp version: 8
License type: Pro
Postby JClements » Wed Apr 23, 2008 7:22 am
Note sure is this is a bug or not.
If you change the color of a Point Light component (by painting the selected component without editing the component), then the SU display of ALL Point Lights are changed to that color as well even though the actual color properties of individual Point Lights (as seen in its Entity Info) are different.
Comments:
I understand the script is targeted more towards architectural rendering. My work is primarily illustrating non-architectural models. Many times I turn on "Use Sun for Shading" to control the contrast of surfaces, but do NOT display shadows as shadows often 'hide' smaller, intertwined geometry. If it is possible to turn OFF shadows in the POV rendering (as an option) and there is a broad enough demand for this, I'd like you to consider that in some future release.
Likewise, being able to use Point Lights or Spot Lights to subtly accent a part of a model withOUT displaying the bulb would be handy. Perhaps there could be an option for this in their respective edit dialogs at some later time.
This may go over the "adding too much complexity" threshold, I hope its not the case. :roll:
Regards, John
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby ilay7k » Wed Apr 23, 2008 8:09 am
also
i catch this when selected Phong Matt in mat.converter, something is wrong.
resent mat.options is normal
it likes feature of light-group(described in manual of pov-ray).
i remember about unique-function...
John, you work with studio-lighting setup?
i add some info in pov-ray editor, for example about area-lights...it's simple...
ilay7k
Postby Didier Bur » Wed Apr 23, 2008 12:01 pm
The PointLight component in "Windmill.skp" is not the good one :oops: because to avoid what you describe, the material of the component must be "default". But I formerly painted the bulb with a yellow material. The su2pov_pl.skp component in the Plugins/su2pov folder is OK.
Sorry for all these little inconveniences...
Didier Bur
SketchUp version: 8
License type: Pro
Postby Didier Bur » Thu Apr 24, 2008 11:21 am
Version 3.1. released (at top of this thread)
@John: your suggestions have been included ;)
Didier Bur
SketchUp version: 8
License type: Pro
Postby ilay7k » Thu Apr 24, 2008 2:16 pm
thank you for update!
Keep it simple!
it's simple 5-min test work with all Finish mats(with photoshop)
used 2bounce-settings(1 picture...phong matt) and skylight-settings(for 3 pics,... glass, glossy) and without photon-mapping :( (a few dark places)...then layer post-processing in pshp
Please look at export mat like Phong Matt....i used 3.6 pov-ray
ilay7k
Postby Didier Bur » Fri Apr 25, 2008 11:04 am
Small bug fix this morning, thanx to ilay7k.
Didier Bur
SketchUp version: 8
License type: Pro
Postby JClements » Fri Apr 25, 2008 4:17 pm
Hi Didier, a brief follow up.
I haven't had a chance to try the new options except the render with Alpha Channel and I do like that a LOT; I still can't believe that SU isn't capable of doing this natively with their PNG expoxt filter.
What I can tell you is that the two light tools do work for me ONLY IF:
1. I import each of their two respective .Skps FIRST so they are registered in the model's component library.
2. Then, after selecting a tool from your menu, pressing ESC. This allows the scripts to respond to subsequent mouse clicks.
I am not sure if #1 is related to what the user's default component directory is or not or if it has to do with SU's installed location (mine is C:\programs\SketchUp 6\...) .
Could you include the script's version number in the end of the script name listed in the Plugins' Menu? That would help identify if the latest version has been installed.
Hopefully, I can be more deligent this weekend and re-try all the settings of your lastest release.
Regards, John
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby ilay7k » Fri Apr 25, 2008 4:30 pm
Thanks for update
esc-pushing error(for placing lights) was fixed by Didier in latest...
John feel free for download it...
Can somebody tell about megapov?
ilay7k
Postby JClements » Fri Apr 25, 2008 4:39 pm
I thought I did as I downloaded yesterday. Perhaps a bad link exists. That's the benefit of having the version level listed in the menu. :)
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Didier Bur » Fri Apr 25, 2008 8:10 pm
Hi John,
All this is fixed now. The compos are loaded from a path relative to the Plugins folder, which Ruby can find by itself. So no matter where your SU main folder is, it MUST load components if they are not already present in the model. I've tested it hundreds of times believe me...
BTW good idea to put the version number in the menu ;)
Didier Bur
SketchUp version: 8
License type: Pro
Postby JClements » Sat Apr 26, 2008 4:41 am
I tried downloading again and I see no difference in the light tools and no version level in menu description so I can't verify if I am downloading the wrong version.
Can you post the zip here ... at least temporarily until Monday?
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Didier Bur » Sat Apr 26, 2008 1:12 pm
Here it is:
Didier Bur
SketchUp version: 8
License type: Pro
Postby JClements » Sat Apr 26, 2008 9:08 pm
Didier, thanks for posting the .Rb.
The component lights are now being found, I no longer have to manually import them prior to using the script,and the version level is displayed.
I still have to press the ESCAPE key to initiate creating the lights with mouse clicks, however.
Questions (of course :} ):
1- In your documentaton you mention that the Sun is automatically "shut off" at night. I had assumed that was when the model was Set to Use Sun for Shading, but this happens as well when it is not set for Use Sun for Shading and also when the rendering setting of Lights is set for lights only. Is this what you intended?
2- I was curious what the default is for when the script is turned to night mode. Is it a prescribed amount of minutes before the sunset time listed in the Shadows Dialog?
3- In your documentation you show the Sun actually being rendered in the sky. How is this done, is it automatically placed (per SU's sun position) once the script is run the first time for a model?
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby ilay7k » Sun Apr 27, 2008 5:37 am
John put time-slider in the right end at shadow-toolbar and export with lights
and some explanation in POV sample scenes and help-system too...
Strange, i haven't esc-effect...
ilay7k
Postby Didier Bur » Sun Apr 27, 2008 11:10 am
Hi John,
I never noticed any difference with that checkbox ticked or not. Here is what the SU help says: "Click on the Use Sun for shading checkbox to shade the faces of your model based on the position of the sun. SketchUp uses standard shading that follows the camera when Use Sun for Shading is not enabled."
Not correct, at least by me: no standard shading that follows the camera. It makes no difference, that's why the script doesn't take care of it...
Almost. The script calculates the "slope" of the sun rays and when it is less or equal than 0 radians it considers that it is night time (sun rays slope is negative during the night because the sun is "behind" the ground). Between 0 and 0.2 radians the color of the sun light is slightly modified (at sunset or sunrise).
This is done this way: the script evaluates the angle between camera direction and sun rays vector, and calculates wether the sun is in the field of view or not. When it is, the component "su2pov_sun" is inserted at the right place, then removed after the export is finished. The component uses a png image that goes from white to transparent to mix the sun with the sky color.
Regards,
Didier Bur
SketchUp version: 8
License type: Pro
Postby JClements » Sun Apr 27, 2008 6:30 pm
Thanks, Didier, for the feedback.
"..When it is, the component "su2pov_sun" is inserted at the right place, then removed after the export is finished. .."
Very clever programming.
Regards, John
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Juju » Mon Apr 28, 2008 9:19 am
JClements wrote:Thanks, Didier, for the feedback.
Regards, John
+1!
Keeping things organised is not a sin. ;)
Juju
Postby sparc » Thu May 08, 2008 7:52 pm
Great plugin. Question. How does the plug in know what surface is glass for glass finish?
sparc
Postby Didier Bur » Thu May 08, 2008 11:47 pm
If opacity is less than 100% the scripts considers this is a transparent material and applies a glass finish, if it is set in the rendering options.
PS: i'll publish a 3.2. release soon with a basic material editor.
Didier Bur
SketchUp version: 8
License type: Pro
Postby r_persater » Fri May 16, 2008 10:12 pm
Hi Didier!
I have unzipped su2pov3 and installed su2pov_24_setup.exe. I've also been able to export to POV-Ray and I'm a happy user of that part already now. But installing the 2.4 version gave me the su2pov buttons also. My problem is that I get an error message using the buttons. The program can't find the components (su2pov_spotlights.skp, su2pov_tree.skp etc.) and I can't find them in the installation or in any zip file. Where do I find them? Or should they be in the 3.2 package but happen to be missing?
Another question: Is there a function for making a component a "piece of glass", i.e. give all its faces an interior definition with a IOR? Right now I'm doing it the hard way, pasting a "stolen" interior definition and references into the pov file, but there must be a simpler way...
Thanks for a great job!
/Rickard
r_persater
Postby Didier Bur » Sat May 17, 2008 8:25 am
Release 3.2 and relase 2.4 are different, you guess. DON'T install 2.4 AFTER 3.2 !!!
Didier Bur
SketchUp version: 8
License type: Pro
Postby r_persater » Tue May 20, 2008 4:49 pm
Hi again,
Yep, I do understand basic version numbers... But installing just the 3.2 version did NOT give me the buttons and component folders, so I tried installing the 2.4 anyway (even if it is an older version). So my question is: Is something missing in the 3.2 installer when I can't find the button toolbars and components? Or is the file su2pov_materials.exe supposed to install them? The problem is I get the following error message trying to run it:
Line -1:
Error: Array variable has incorrect number of subscripts or subscript dimension range exceeded.
Regards,
Rickard
r_persater
Postby Didier Bur » Tue May 20, 2008 9:33 pm
There are no toolbars and no icons in 3.2. Maybe in 3.3 :roll:
su2pov_materials.exe is an executable that runs from within SU when you edit pov-ray material properties.
Regards,
Didier Bur
SketchUp version: 8
License type: Pro
Postby r_persater » Tue May 20, 2008 11:30 pm
OK, that explains why... :|
Is it possible to get the 2.4 versions lights, 3D trees etc. somewhere? Or is a 3.3 version coming soon? ;)
r_persater
Postby majid » Wed May 21, 2008 2:56 am
dear Didier . thanx for your nice jib on improving SU2POV.. and waiting to have v3.2beta ( material editor problem resolved ) :bounce: . v3.2 was a great improve !!! :ecstatic:
yours kindly
درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby honoluludesktop » Fri Sep 12, 2008 11:46 am
Dear Didier, Found this tread and after moving a copy of the su2pov folder into the components folder I am now able to use "lights" with the "esc" key.
I am still unable to "edit pov-ray" finishes. When ever I try to "apply" a change, a ASCII file titled "Program" is created in the root directory. The contents of this file include the selected changes. Apparently the file is not being saved in the proper location. (I discovered this file when I booted the computer and the boot process reported the file, requireing that it be renamed) When I again attempt to access the "edit pov-ray" menu, the menu would not open until I clear the file "Program" from the root directory. The title of the "edit pov-ray" menu is "Files/Google/Google". Is that right? I currently have su2pov.rb and the su2pov folder in the "plugins" folder. In addition, the su2pov folder is installed in the "components" folder.
honoluludesktop
In Remembrance
Postby Didier Bur » Fri Sep 12, 2008 7:54 pm
Thanks for the bug report. I also had a file on c:\ named "program" and never though it was my own script that did it ! Seems you've tracked the bug I'm on for a long time !
Didier Bur
SketchUp version: 8
License type: Pro
Artisan Organic Toolset - a set of powerful organic modeling tools.
Next
Return to Plugins
