[Plugin] Xref Manager
Re: [Plugin] Xref Manager
Postby Bob James » Fri Jun 24, 2016 2:31 am
Well, that's three orders :fro:
Bob James
Premium Member
Premium Member
Postby juju » Fri Jun 24, 2016 8:23 am
JQL wrote:I'd be very interested in a pro version too.
+1!!!
juju
Premium Member
Premium Member
Postby davecoopstl » Wed Oct 05, 2016 11:22 pm
Hi TIG,
Any chance that you've already updated the X-Ref Manager extension, and are just waiting to release it for the world to use?!?
Seriously, I'm running into the same "no scroll bar" problem as above, and would love to be able to keep adding X-Refs into my base model, instead of reference them into separate files that then get referenced into the base model.
And yes, we're willing to PAY you $$ to make it happen! It's THAT valuable for our workflow.
Let us know!
Dave Coop.
3
davecoopstl
Postby XenoEnder » Wed Mar 29, 2017 1:29 pm
I'm currently looking to include this plugin in my workflow, but I can't get the dialog to come up when the file opens to fix outdated xrefs. If This doesn't work, I will need to find another option. Is there something I can do to fix this?
Edit:
So it turns out, the xref manager only seems to load at startup if the file is opened from windows explorer, but not by opening the file within sketchup...? Would that be an easy fix?
XenoEnder
Postby ctrlaltf1 » Thu Aug 17, 2017 2:04 am
Im SKP 2017.
I get an "unsigned" message in the extension manager and the plug in wont run.
any ideas?
ctrlaltf1
Postby Frederik » Thu Aug 17, 2017 12:03 pm
Although this is an old plugin, I just discovered it and I sure could also use it in my work flow... :)
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby TIG » Thu Aug 17, 2017 1:09 pm
ctrlaltf1 wrote:Im SKP 2017.
any ideas?
Set your Extension Loading Policy to 'Urestricted' otherwise many older plugins will be blocked...
Global Moderator
Previous
Return to Plugins
Users browsing this forum: BrunovBruno, tech 23 and 27 guests
