by Fletch » Thu Mar 27, 2008 7:37 pm
muchas gracias, amigo!
Fletch
- Twilight Render
by cdubea » Tue Apr 01, 2008 12:55 pm
TIG,
Any chance of getting the Xref Manager tweaked to show only the top level components in the Xref Manager dialog bog?
Thanks,
chris
cdubea
- Name: Chris
by cdubea » Wed May 21, 2008 6:35 pm
cdubea wrote:TIG,
Thanks,
chris
Due to multiple issues, I've gotten to the point where this tool is no longer useful to me. These are (in no particular order) 1) Inability to effectively deal with multiply nested parts. This is due to the fact that ALL xref'd components of ALL components are listed in the manager. This causes multiple rebuilding to be required and WILL go into an infinite loop requiring Sketchup to be shut down. 2) Issues with sub component names not being updated. A part that I renamed the components did not update properly. Some component names changed, some didn't. 3) Had issues with component names have #1... being added to them. Any chance of getting some of these things rectified? Please? chris
cdubea
- Name: Chris
by dammerel » Sat May 31, 2008 12:41 pm
i get this error
Error Loading File XrefManager.rb undefined method `add_submenu' for nil:NilClass
Andrew
dammerel
by plot-paris » Sun Jun 01, 2008 6:00 pm
same error message for me...
plot-paris
- Name: plot-paris
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by TIG » Tue Jun 03, 2008 9:59 am
Try v5.1 that fixes this... see below or here: viewtopic.php?f=180&t=7329
- Global Moderator
- Name: TIG
- SketchUp version: 2013
- License type: Pro
by perk » Tue Jun 03, 2008 2:04 pm
When I try to click on the link I get a message saying "you are not authorised to read this forum"
perk
- Name: Jeff
by Juju » Tue Jun 03, 2008 2:56 pm
perk wrote:When I try to click on the link I get a message saying "you are not authorised to read this forum"
+1, get the tools out and fix it.
Save the Earth, it's the only planet with chocolate. Keeping things organised is not a sin.
Juju
- Name: Julian Smith
by Jim » Tue Jun 03, 2008 9:43 pm
Ok, links are fixed.
Jim
- Global Moderator
- Name: Jim
- License type: Pro
- SketchUp use: other
by Juju » Tue Jun 03, 2008 10:58 pm
Great response time, thanks!
Juju
by perk » Wed Jun 04, 2008 2:05 pm
Thanks Jim
its working now
perk
- Name: Jeff
by David_H » Mon Jul 14, 2008 7:05 pm
So does this work as XREF in autocad that it reduces model size and hence adds to speed cuz the model is referenced and not attached or bound, (inserted) into the mother model?
If I make it look easy. . .rest assured--it probably is.
David_H
- Top SketchUcator
- Name: David Hunter
by TIG » Mon Jul 14, 2008 7:41 pm
David_H wrote:So does this work as XREF in AutoCAD that it reduces model size and hence adds to speed cuz the model is referenced and not attached or bound, (inserted) into the mother model?
No. You'll have all of the files inserted into the model. It only keeps track of external file changes and allows up to reload them as you want...
- Global Moderator
- Name: TIG
- License type: Pro
by David_H » Mon Jul 14, 2008 9:22 pm
Oh well . ..c'est la vie
David_H
- Top SketchUcator
by alz » Thu Jul 17, 2008 7:21 pm
Quick basic question --
What is the advantage of the XRef plugin over using the native "Reload" feature on a component?
alz
by TIG » Thu Jul 17, 2008 9:35 pm
It batch processes any 'xrefs' and it also tells you which ones need reloading etc...
- Global Moderator
- Name: TIG
- License type: Pro
by alz » Thu Jul 17, 2008 10:00 pm
Gotcha -- so it's a way to tell me when I load a scene that some items have been modified. Without this, I'd have to know which ones had been changed, and then find them individually in the scene to update.
alz
by mra » Thu Mar 03, 2011 4:55 am
Thanks for the plugin Tig!
mra
by Edson » Thu Mar 03, 2011 9:28 pm
TIG wrote:The v6 new Import methods could also mean that in the future importing DWG/DXFs is easier, more reliable and works on Macs - BUT that's NOT in this release - watch this space...
edson mahfuz, architecthttp://www.mahfuz.arq.brAnyone can get you more for more, but it takes genius to get you more for less.
Edson
- Global Moderator
- Name: Edson Mahfuz
- Operating system: Mac
- License type: Pro
by TIG » Thu Mar 03, 2011 11:30 pm
Edson wrote:TIG wrote:The v6 new Import methods could also mean that in the future importing DWG/DXFs is easier, more reliable and works on Macs - BUT that's NOT in this release - watch this space...
Xref Manager is long overdue an update BUT the list IS looooong........
- Global Moderator
- Name: TIG
- License type: Pro
Return to Plugins
