Fredo6 Tools Aren't working on my Mac
I'm trying to use the Fredo6 Tools on SU via my Mac. I'm able to install them but I'm not able to see the menu's on any Fredo plugin when they are selected. I need these to work for a class I'm in and I can't get them to work. Note: I've completely uninstalled the plugins and SU and reinstalled everything and still nothing.
Did you install the required LibFredo6 files, too? What method did you use to install the extensions?
Hi Dave, yes I have installed the LibFredo6 file also. I also went into the "app file folder" and deleted all files to ensure it would be a clean reinstall.
Before you did the clean install, did you also delete the Plugins folder in User/Library/Application Support...?
I just did the upload from my computer after downloading them from the Plugin Store.
I don't understand what you mean by "I just did the upload from my computer."
I downloaded the plugin from the Pluginstore and then went into SU and clicked the install extension button, which allowed me to select the downloaded plugin and upload it to SU for installation. I don't know if I deleted that folder, I deleted anything that was labeled LibFredo, Fredo in my app library. It's hard to find the files on a MAC but I was able to find them after some searching.
It seems that the Sketchup API does not draw line (
view.draw2d
method).Very strange..... and first time this is signaled.
@betheverett31: do you see the problem with all my plugins having a button palette, or just ThruPaint?
