[Plugin] FredoSpline - v1.6a - 19 Nov 20
Postby fredo6 » Tue Apr 21, 2020 6:27 pm
The information on FredoSpline is maintained on the Plugin Home Page of FredoSpline. This is also where you can download the RBZ file.
REQUIREMENTS:
  • LibFredo6: v11.3a or above
  • Usage: Free for the time being
  • Expiration on: 08 Jan 2021
If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
FredoSpline is a suite of tools dedicated to handling a variety of curves based on control points.
  • Bezier, Classic and Nurbs
  • Fit Spline, local and global
  • Polyline with division pattern
  • Polycorner, which are polylines with configurable corners at vertices
When you run FredoSpline for the first time, the toolbar shows only 5 icons
You can however configure the toolbar to show more icons. Here is the full toolbar
CREDIT: JClements for all icons and cursors
For each tool, there is an online help in the Instructor panel. You can print it.
Here are the corresponding PDF:
FredoSpline - Instructor - Creation.pdf
FredoSpline - Instructor - Edition.pdf
FredoSpline - Instructor - Swap.pdf
FredoSpline - Instructor - Convert.pdf
FredoSpline - Instructor - Purge.pdf
18
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoSpline - v1.1a - 21 Apr 20
Postby pilou » Tue Apr 21, 2020 9:04 pm
A new futur hit! :enlight: What a museum of curves! :fro:
4
Speedy Galerie
Top SketchUcator
Postby rv1974 » Wed Apr 22, 2020 8:19 am
I can't believe it's made by single person. Monumental!
4
rv1974
Postby Didier Bur » Wed Apr 22, 2020 8:23 am
Impressionnant :thumb:
Tout ce que SketchUp devrait comporter comme outils natifs, Fredo le fait...
Impressive :thumb:
Almost all what SketchUp should encompass natively is developed by Fredo...
3
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: [Plugin] FredoSpline - v1.1a - 22 Apr 20
Postby johnnygitarr » Wed Apr 22, 2020 12:40 pm
Hi Fredo6,
another unbelievable useful new plugin from you.
1.000 thnx and big thumbs up!
but i do have problems with the plugin on my mac
macOS 10.15.4 (Catalina) and SKP 20.0.362.
SKP crashes while i try to use the plugin.
I think i can delete Fredo's Bezierspline now, or?
Greetings and many thnx again for your effort for the SKP community.
Toby
johnnygitarr
Postby rv1974 » Wed Apr 22, 2020 1:09 pm
Fredo,
*) In other, de-facto standard programs like Max and Pshop, one spline can include all 4 types of points: bezier corner, bezier, corner, smooth, corner. Is this general type of spline possible?
A single mouse click creates corner point, continuous mouse click creates bezier point. Is it possible to implement in FredoSpline?
*) May Undo last point be with Backspace key?
*) Can moving handle grips aside control pitching (like in attached gif)?
Thank you for attention
rv1974
Postby fredo6 » Wed Apr 22, 2020 1:15 pm
johnnygitarr wrote:but i do have problems with the plugin on my mac
I could not test on Mac since I don't have one.
Could you tell me more about the crash.
johnnygitarr wrote:I think i can delete Fredo's Bezierspline now, or?
I suggest you keep it. I maintain it, although there won't be functional evolutions.
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Wed Apr 22, 2020 2:11 pm
rv1974 wrote:In other, de-facto standard programs like Max and Pshop, one spline can include all 4 types of points: bezier corner, bezier, corner, smooth, corner. Is this general type of spline possible?
Not clear to me what this means...and I don't have these software to compare.
rv1974 wrote:May Undo last point be with Backspace key?
Backspace is used to remove inference visuals. Undo is more natural with Ctrl-Z or Escape
rv1974 wrote:Can moving handle grips aside control pitching (like in attached gif)?
Maybe this is because I have a small screen, but I found that grasping the tangent for rotation and having a handle on the same tangent segment was not very handy.
fredo6
PluginStore Author
PluginStore Author
Postby johnnygitarr » Wed Apr 22, 2020 3:17 pm
Hi Fredo6,
I wish I could describe the crash more then the following words:
The only thing I can say is, that when I click on a FredoSpline icon
and then click on the drawing area to draw, then SKP crashes immediately.
No Beachball, no other info.
Greetings
johnnygitarr
Postby fredo6 » Wed Apr 22, 2020 3:27 pm
Do you see the button palette appearing?
Does it happen for any icon?
Can you start the Quick Launcher?
fredo6
PluginStore Author
PluginStore Author
Postby johnnygitarr » Wed Apr 22, 2020 4:33 pm
HIi Fredo,
Palette is visible and i did my changes to show every icon,
but i havn't tried every icon yet.
Dunno what you mean with Quicklauncher!?
If it is the Fredo-Menu of the plugin, then i can say no.
Plugin crashes SKP before Quicklauncher is acitve.
It might be useful if another Mac user would try the plugin,
maybe it is a special thing on my machine.
Greetings
Toby
johnnygitarr
Postby Oxer » Thu Apr 23, 2020 6:04 am
On macOS 10.13.6 & SU2017 the plugin doesn't work, I can init the Quick Launcher, the icons and the Contextual Menu appear but when you push some icon nothing happens, I looked into Console but it's empty. :shock:
http://www.oxervision.blogspot.com/
Oxer
Postby pascal1964 » Fri Apr 24, 2020 3:08 pm
Génial que de belles courbes! :thumb:
pascal1964
Postby jranly » Fri Apr 24, 2020 5:12 pm
johnnygitarr wrote:HIi Fredo,
Greetings
Toby
I'm having the same problem with the plugin on my Mac. Click the icon, then Sketchup disappears/crashes.
jranly
Postby jranly » Fri Apr 24, 2020 5:19 pm
Greetings
Toby
I'm having the same problem with the plugin on my Mac. Click the icon, then drawing area, then Sketchup disappears/crashes.
jranly
Postby fredo6 » Fri Apr 24, 2020 5:20 pm
jranly wrote:I'm having the same problem with the plugin on my Mac. Click the icon, then Sketchup disappears/crashes.
I am aware of this and trying to find out the cause. I have to count of Mac users because I don't have a Mac myself.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby pilou » Fri Apr 24, 2020 6:53 pm
Speedy Galerie
Top SketchUcator
Postby JClements » Fri Apr 24, 2020 7:34 pm
@y rv1974
Yes, FredoSpline can produce the equivalence to your questions. It just depends upon the type of spline you are editing and how to manipulate the control points. See Pilou's video and others. If you download the PDFs you should find specific answers to your question.
JClements
Premium Member
Premium Member
Postby T_MP » Mon Apr 27, 2020 4:31 pm
Same problem here. The plugin appears to install ok but crashes SKP when I try to select any of the FredoSpline tools.
macOS 10.13.6 (High Sierra) - SKP 19.0.684
T_MP
Re: [Plugin] FredoSpline - v1.2a - 29 Apr 20
Postby fredo6 » Wed Apr 29, 2020 1:33 pm
NEW RELEASE: FredoSpline v1.2a - 29 Apr 20
Requirement: LibFredo6 10.2
FredoSpline 1.2a is a major release that should now work on Mac platforms
Home Page of FredoSpline for information and Download.
Main post of this FredoSpline thread.
fredo6
PluginStore Author
PluginStore Author
Postby Arc » Thu Apr 30, 2020 3:34 am
Convert Curves Error.
Code: Select all
Error: #<TypeError: no implicit conversion of nil into Hash>
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/fredosplinetool.rbe:5847:in `update'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/fredosplinetool.rbe:5847:in `edge_picking_init'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/fredosplinetool.rbe:244:in `initialize'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe:291:in `new'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe:291:in `launch'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe:245:in `action__mapping'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:126:in `call'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:126:in `launch_action'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:224:in `launch_action'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe:118:in `launch_action'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe:183:in `block in declare_command'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1321:in `command_invoke'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1303:in `block (2 levels) in build_config_commands'
c:/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1372:in `block in add_command'
Arc
Postby fredo6 » Thu Apr 30, 2020 9:17 am
@Arc
Did you update to FredoSpline v1.2a?
The error lines seems outdated.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Arc » Sun May 03, 2020 9:39 am
It is fixed, thank you.
Arc
Postby reza1813 » Mon May 04, 2020 11:41 pm
Dear Fredo,
Hello, is it any possibility to add Gumball to Fredospline like the Rhino? I know that we have it now in these plugins, but regarding the graphical concern, it would be great when we select the point, then we can see a Gumball on top of the point. Thanks.
reza1813
Postby fredo6 » Tue May 05, 2020 10:03 am
reza1813 wrote:Dear Fredo,
You have the direction inferences on axes (global and local), you can also lock any direction. And once the direction is locked or inferred, you can type a distance.
The interest of the gumball (as I see it in the other software) is that you can select several control points (via a selection rectangle) and move them together.
fredo6
PluginStore Author
PluginStore Author
Postby Pixero » Wed May 06, 2020 10:11 am
I have always wanted a bezier tool in SketchUp that behaves like in 2D vector programs such as Freehand or Affinity Designer.
Here is an old little test I did with paperjs where I made a simple drawing tool in the browser.
Click to create straight lines. Click and hold and drag to create smooth corners.
What I like is the control and the preview of the next curve segment before you click to place it.
Close the curve to create a new curve.
(In this little test you can't go back and edit already made curves.)
http://pixero.com/old/paperjs/PenTool.html
This is exactly like how it works in for example Freehand (Which in my humble opinion was a much better vector program than Illustrator before Adobe bought and killed it.)
Would it be possible with FredoSpline?
Pixero
Postby rv1974 » Wed May 06, 2020 2:03 pm
@Pixero:
This is what I suggested: single click for Corner, click & drag for Bezier Smooth, Backspace for last input Undo. Rather standard cross platform behavior.
rv1974
Re: [Plugin] FredoSpline - v1.3a - 25 May 20
Postby fredo6 » Mon May 25, 2020 11:46 am
NEW RELEASE: FredoSpline v1.3a - 25 May 20
Requirements
  • LibFredo6: v10.5a
FredoSpline 1.3a is a maintenance release for bug fixing and cosmetic adjustments for Mac
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoSpline - v1.4a - 01 Jun 20
Postby fredo6 » Mon Jun 01, 2020 7:57 am
NEW RELEASE: FredoSpline v1.4a - 01 Jun 20
Requirements
  • LibFredo6: v10.6a
FredoSpline 1.4a is a maintenance release for bug fixing and cosmetic adjustments for Mac
fredo6
PluginStore Author
PluginStore Author
Postby Gray Gardner » Tue Jun 16, 2020 10:14 pm
File won't seem to install in my sketchup. "failed to install FredoSpline_v1.4a.rbz"
Gray Gardner
Next
Return to Plugins
Users browsing this forum: levenetince26, shah613 and 15 guests
