by samuel_t » Wed May 13, 2020 6:42 pm
TIG wrote:So do you need to explain to MAC users to open the Terminal first, and then try your tool... And any error-messages might appear in that Terminal window ?
No, command line needs to be pasted in Mac's Terminal after that Universal Importer plugin crashes.
samuel_t
- Name: Samuel Tallet
- Operating system: Windows
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: illustration, cartoons
by edwinfolk » Fri May 15, 2020 12:58 am
Hello Samuel,
Thanks for doing this. This looks like a really great plugin that can help with rendering and setting up reference models for a lot of Maxwell users. Attached is a screen shot of the terminal window. Hope you can make sense of it.
edwinfolk
- Name: edwin
- Operating system: Mac
- SketchUp version: 2018
- License type: Pro
- SketchUp use: architecture
by McGordon » Fri May 15, 2020 9:11 am
edwinfolk wrote:This looks like a really great plugin that can help with rendering and setting up reference models for a lot of Maxwell users. Attached is a screen shot of the terminal window. Hope you can make sense of it.
The permission denied means you don't have executable permissions on that assimp file. Can you paste this into Terminal and press return: - Code: Select all
ls -l ~/Library/Application\ Support/SketchUp\ 2018/SketchUp/Plugins/universal_importer/Assimp/Mac
Then show us the results, which should look something like this: - Code: Select all
total 25448 -rwxr-xr-x@ 1 gordon staff 3791 24 Sep 2019 LICENSE.txt -rwxr-xr-x@ 1 gordon staff 149772 6 Jan 16:05 assimp -rwxr-xr-x@ 1 gordon staff 12810620 6 Jan 16:05 libassimp.dylib -rwxr-xr-x@ 1 gordon staff 58316 24 Sep 2019 x.dyl
I haven't installed this yet, I'm just trying to help as samuel_t doesn't have a Mac. The first 'x' in '-rwxr-xr-x@' for assimp means I could run that file as a program. That's the bit I'm looking for when you run that command which just lists what's in that directory.
McGordon
- Premium Member
- Name: Gordon McIntyre
- SketchUp version: 2020
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Advanced
by edwinfolk » Fri May 15, 2020 11:51 am
Hello McGordon, I attached a screen shot of the command sent through terminal. Not sure what that means - sorry I am not a coder or Ruby specialist. Anyway if you can make sense of this and help Samuel thereby helping us MacOS users, awesome. Thanks for the help and stay safe.
Edwin
edwinfolk
- Name: edwin
- License type: Pro
by TIG » Fri May 15, 2020 1:14 pm
In the first part of the 'report' the "rw" means "read/write". If you see the earlier McGordon example you see "rwx" which means "read/write/execute". So yours is failing because it doesn't have permission to execute the necessary files...
You could try selecting the subfolder [.../Plugins/universal_importer] and changing it to have "full" permissions - for all users and all of its contents...
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
by McGordon » Fri May 15, 2020 1:25 pm
As I suspected, you don't have permission to run that file. You could fix it with another terminal command: - Code: Select all
chmod u+x ~/Library/Application\ Support/SketchUp\ 2018/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp
Be more careful copying and pasting this time. The 'CODE: SELECT ALL' link doesn't work for me, it just scrolls to the top of the page. That command just changes the execute (run) permissions of that one file. They are perfectly readable, but you don't have to screenshot the terminal, just copy the text as if it was any text document in a word processor or text editor.
McGordon
- Premium Member
- License type: Pro
by edwinfolk » Fri May 15, 2020 7:31 pm
Hi Guys,
Thanks again for looking at this. I review both your responses. I think I had previously made a mistake entering the cut and paste into terminal and received the wrong information which I sent to you. I went back a step and copy/pasted into terminal the correct line of code and the terminal spit this out.
-rw-rw-rw- 1 edfolk staff 3791 Sep 24 2019 LICENSE.txt -rwxrw-rw- 1 edfolk staff 149772 Jan 6 17:05 assimp -rw-rw-rw- 1 edfolk staff 12810620 Jan 6 17:05 libassimp.dylib -rw-rw-rw- 1 edfolk staff 58316 Sep 24 2019 x.dyl
I did try to paste into the line McGordon sent but the plugin did not complete the import. I attached a series of 3 screenshots to show you. As you can imagine I am not the computer guy. Decent enough designer but shit when it comes to this sort of thing.
Thanks again you guys are really great.
Edwin
edwinfolk
- Name: edwin
- License type: Pro
by McGordon » Fri May 15, 2020 8:45 pm
It looks like the previous chmod command worked: edwinfolk wrote:- Code: Select all
I think you've made a bit of progress. You're now getting a different error from another program that probably doesn't have executable permissions either. Here's one more command to make it run too: - Code: Select all
chmod u+x ~/Library/Application\ Support/SketchUp\ 2018/SketchUp/Plugins/universal_importer/MeshLab/Mac/MacOS/meshlabserver
run that then try to do your import again. I think there might be other files on your system with the wrong permissions, but I'm only getting you to change one at a time here.
McGordon
- Premium Member
- License type: Pro
by edwinfolk » Fri May 15, 2020 9:37 pm
Hello,
Thanks for the help. It seems to work better than before. I attached a jpg so you can see that the file I imported (OBJ) did not completely import successfully. Not sure what the problem is but as you can tell from the image it is not complete. Same thing happened with a Light Wave import although the import image was about 1/100 the expected size. I will try some other imports from other formats and see what happens. If you have any ideas would love to hear them.
I have been able to convert some files from these formats using MODO to make a Collada file and then using the normal import to SKU. Cleaning them up and ignoring UV distortion which gives okay results. However, if I can get the universal importer to work well then I can save a lot of time.
Thanks again. Really appreciate the help.
edwinfolk
- Name: edwin
- License type: Pro
by malditobill » Tue Aug 18, 2020 1:53 pm
Hi. Do I have to install Assimp library and MeshLab software before Universal Importer? Ive just installed only Universal Importer and in the tool bar only get the reduce poligons icons.
malditobill
by samuel_t » Sun Aug 23, 2020 7:49 pm
malditobill wrote:Hi. Do I have to install Assimp library and MeshLab software before Universal Importer? Ive just installed only Universal Importer and in the tool bar only get the reduce poligons icons.
Hi. No. Assimp library and MeshLab software are bundled with Universal Importer plugin. SketchUp toolbar only contains shortcut to Poly reducer... In SketchUp menu, use "File > Import with Universal Importer...".
samuel_t
by rspierenburg » Tue Oct 20, 2020 2:49 pm
I'm trying to import an OBJ. I want to keep the existing model scale but the plugin keeps asking for the height of the model. Is there a way to ignore that?
rspierenburg
by samuel_t » Tue Oct 20, 2020 7:18 pm
rspierenburg wrote:I'm trying to import an OBJ. I want to keep the existing model scale but the plugin keeps asking for the height of the model. Is there a way to ignore that?
Hello. You can't ignore that.
samuel_t
by Lacee » Thu Oct 29, 2020 2:51 pm
Unable to reduce a 6,000,000 poly SU2020 file / also unable to import OBJ source file for same #2 Posted in GitHub.
Lacee
- Name: Lacee Lamphere
- License type: Pro
- SketchUp use: engineering and mechanical design
by Kolarik » Mon Nov 02, 2020 2:50 pm
1) Can you explain, how size of imported object is calculated? I am not able to import objects in correct size. See attached example - block 10x20x30mm Block10_20_30.jpg It was exported to STL, and imported back by Universal Importer. Height set to 1 cm Importer_settings.jpg no texture, no reduction. Result : Block_result.jpg I do not know, what I am doing bad.... 2) I am using milimetres as default in Sketchup - if the sizing rules would work, can it be changed into mm instaed of cm?
Kolarik
- Name: Jiri
- SketchUp use: hobby
by samuel_t » Mon Nov 02, 2020 10:18 pm
Lacee wrote:Unable to reduce a 6,000,000 poly SU2020 file / also unable to import OBJ source file for same #2 Posted in GitHub.
Hello Lacee. I just answered you at GitHub
samuel_t
by Einstein » Tue Nov 03, 2020 12:54 pm
Hello, Would it be possible to support importing loose edges from Blender? When a mesh contains faces, it imports properly but if there are only edges, they don't get imported. It would also be cool if separate Blender objects would be imported to separate SketchUp groups. But I'm aware this can be a lot of work to code.
Einstein
- Name: Michal P
- License type: Pro
by samuel_t » Tue Nov 03, 2020 8:54 pm
Kolarik wrote:1) Can you explain, how size of imported object is calculated? I am not able to import objects in correct size. See attached example - block 10x20x30mm [...]
Technically, sizing algorithm is a hack. Since in most cases, by default, imported object is oversized: plugin scales down this object to height set by user. This hack works pretty well with "tall" objects. Kolarik wrote:2) I am using milimetres as default in Sketchup - if the sizing rules would work, can it be changed into mm instaed of cm?
Maybe if I ask user for a height in mm instead of cm, size of imported model will be more accurate...
samuel_t
by samuel_t » Tue Nov 03, 2020 9:19 pm
Einstein wrote:Hello, Would it be possible to support importing loose edges from Blender? When a mesh contains faces, it imports properly but if there are only edges, they don't get imported. It would also be cool if separate Blender objects would be imported to separate SketchUp groups. But I'm aware this can be a lot of work to code.
Hello. No. You can see Universal Importer plugin for SketchUp as an Assimp script. This means that, in most cases, if Assimp doesn't support a feature: Universal Importer plugin doesn't support this feature.
samuel_t
by Kolarik » Sat Nov 07, 2020 11:14 am
samuel_t wrote:Maybe if I ask user for a height in mm instead of cm, size of imported model will be more accurate...
I would prefer it, either as default or at least as option.
Kolarik
- Name: Jiri
by Einstein » Mon Nov 23, 2020 8:24 pm
Hello, I have a problem with importing Blend files. There is a model in Blender containing one object with all faces touching each other, so the object is "water-tight", "3D-printable" and there are no "border edges" (every edge is connected to two faces). When I import it to SketchUp, some faces stay connected but some disconnect, leaving doubled vertices living nearby but not touching each other. This basically makes a broken mesh. Can something be done with this issue - either manually, or within the plugin? I tried exporting from Blender to OBJ, then to SketchUp. It fixes the issue if I use ThomThom's QFT OBJ importer but introduces another issue - missing some faces.
The BLEND model is in the ZIP archive because SketchUcation won't let me post BLEND files.
Einstein
- Name: Michal P
- License type: Pro
by brettmahon01 » Sat Nov 28, 2020 10:33 pm
Hi, this plugin sounds amazing! i installed but i keep getting error message?
Universal Importer Error: Command failed: "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp" info "/Users/brettmahon/.UniversalImporter/tmp/import.obj" > "/Users/brettmahon/.UniversalImporter/tmp/assimp.nfo"
/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/assimp.rb:166:in `get_texture_refs'
Universal Importer Version: 1.1.5
brettmahon01
- Name: Brett Mahon
- SketchUp version: 2015
- License type: Pro
by samuel_t » Sun Nov 29, 2020 1:50 pm
Einstein wrote:Hello, I have a problem with importing Blend files. There is a model in Blender containing one object with all faces touching each other, so the object is "water-tight", "3D-printable" and there are no "border edges" (every edge is connected to two faces). When I import it to SketchUp, some faces stay connected but some disconnect, leaving doubled vertices living nearby but not touching each other. This basically makes a broken mesh. Can something be done with this issue - either manually, or within the plugin? I tried exporting from Blender to OBJ, then to SketchUp. It fixes the issue if I use ThomThom's QFT OBJ importer but introduces another issue - missing some faces.
Hello. I don't know Blender enough to help you
samuel_t
by samuel_t » Sun Nov 29, 2020 1:57 pm
brettmahon01 wrote:Hi, this plugin sounds amazing! i installed but i keep getting error message?
Hi, you have probably a file permission issue. Open a Terminal in your Mac then run these commands: - Code: Select all
chmod +x "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp"
- Code: Select all
chmod +x "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/MeshLab/Mac/MacOS/meshlabserver"
Then reopen SketchUp.
samuel_t
by NC3D » Thu Dec 03, 2020 8:02 pm
Samuel
Seems like a great plug-in, thanks for sharing this!
We have an fbx we are trying to bring in but we are not sure how to get it to be placed exactly where we want it and at the right scale. I think we could find the right scale factor to get it right but unfortunately I can not type in an accurate enough number (only integers allowed) into the dialogue box.
Is there a better way or different way we could have our model drop in more accurately?
Kind Regards, Greg Hamilton
NC3D
- Name: NC3D
- License type: Pro
- Level of SketchUp: Beginner
by samuel_t » Sat Dec 05, 2020 4:45 pm
NC3D wrote:Samuel
Hello, There's no solution for the moment. Maybe I'll publish a more accurate plugin version in the future. Best regards.
samuel_t
by Noire0891 » Sat Dec 05, 2020 8:30 pm
Sketchup 2016 will be implemented?
Noire0891
- Name: Noire
- SketchUp version: 2016
- License type: Pro
by samuel_t » Sun Dec 06, 2020 9:49 am
Noire0891 wrote:Sketchup 2016 will be implemented?
I don't think so.
samuel_t
by xinhengxie » Fri Dec 25, 2020 10:29 am
Your software is very useful!! Thanks a million!! BTW, I don't know if you have thought of adding an function that it can import OSGB file format, it would be cool!!
Merry Christmas!!!!!!
xinhengxie
- Name: xinheng
- License type: Pro
- SketchUp use: other
by samuel_t » Tue Jan 05, 2021 1:47 pm
1.1.6 version improves scaling accuracy during import and fixes file permissions issue on MacOS. Download latest Universal Importer plugin from SketchUcation PluginStore.Happy new year!
samuel_t
- Robot
Return to Plugins
