[Plugin] Universal Importer - v1.1.5 - 29 Jan. 2020
Re: [Plugin] Universal Importer - v1.1.5 - 29 Jan. 2020
Postby Pixero » Mon Feb 10, 2020 6:58 pm
About adding support for quads.
Couldn't you ask Thomthom if he would be willing to share the code he uses in his Quadface tools?
Pixero
Postby samuel_t » Mon Feb 10, 2020 7:05 pm
Pixero wrote:About adding support for quads.
I think it's not possible because import feature is based on external programs not written in Ruby.
samuel_t
Postby jiminy-billy-bob » Wed Feb 12, 2020 8:42 am
panixia wrote:
Einstein wrote: Then we wouldn't probably need Transmutr, which is an expensive tool.
I don't know how expensive this tool is, but as far as I saw, this doesn't supports quads from other modeling pakages.
If it does, I would pay for it no problem at all. Now. The "shut up and take my moneys!" style.
It is planned for a future Transmutr version ;)
It's a bit tricky to do, but I believe it's possible.
I don't have an ETA, though. For now we are focused on Skatter v2.
5
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby pinoy » Thu Feb 13, 2020 3:59 am
Thank you so much!
pinoy
Postby panixia » Fri Feb 14, 2020 9:48 pm
That would be really valuable for me, I'm more on the VR/game engine side of the fence right now, so no need for scatters/proxyes, but good topology is on top of the needs. :)
panixia
Postby 8 perf » Wed Feb 19, 2020 1:43 am
This seems like a fantastic plugin!
I too am having issues with 1.1.5 on Mac OS 10.12.6. with Sketchup 2017 Make.
A poster back on page 6 had the same issue I am having. I dont know if I can post images here or not as I dont frequent the site enough. His earlier post had this...
viewtopic.php?f=323&t=71951&start=120#p656540
Im getting the same and was wondering if its an OS issue. I downloaded the most recent version of ASSIMP thinking I might need that. Do I? Couldn't figure out how to install it anyway. :)
Would love to get this sorted to be able to play around with this and put it through its paces. Thanks for any insight.
8 perf
Postby samuel_t » Wed Feb 19, 2020 4:06 pm
8 perf wrote:[...]
Unfortunately, I think plugin is not compatible with macOS 10.12.x, you need macOS 10.13 or greater.
samuel_t
Postby 8 perf » Wed Feb 19, 2020 10:35 pm
samuel_t wrote:
8 perf wrote:[...]
Thanks samuel. Maybe after a long needed upgrade Ill try it again.
8 perf
Postby colorfulman » Wed Mar 04, 2020 4:07 am
Hi sir:
Thank you so much for you write this power plugin.
When I use Universal Importer import any .stp file,Showned below erro,Can you help me?
you can try import any .stp file to test this bug,This website is not allow me upload .stp file
SketchUp 2019
Universal Importer Error: Command failed: "C:/Users/Colorfulman/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Win/assimp.exe" info "C:\ProgramData/Universal Importer/tmp/import.stp" > "C:\ProgramData/Universal Importer/tmp/assimp.nfo"
Launching asset import ... OK
Validating postprocessing flags ... OK
ERROR: Failed to load file: Validation failed: A node of the scenegraph is NULL
assimp info: Unable to load input file C:\ProgramData/Universal Importer/tmp/import.stp
C:/Users/Colorfulman/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universal_importer/assimp.rb:166:in `get_texture_refs'
Universal Importer Version: 1.1.5
确定
colorfulman
Postby treddigaetano » Fri Mar 06, 2020 5:44 pm
hi, can to import also mtl texture file of .obj ?
treddigaetano
Postby samuel_t » Sat Mar 07, 2020 10:10 am
treddigaetano wrote:hi, can to import also mtl texture file of .obj ?
Hi, don't worry: MTL texture file of OBJ is automatically loaded. ;)
samuel_t
Postby samuel_t » Sat Mar 07, 2020 10:11 am
colorfulman wrote:Hi sir:
SketchUp 2019
确定
Thank you for your report. Unfortunately I can't fix that issue. :?
samuel_t
Postby kd8qlo » Tue Mar 10, 2020 10:19 pm
Hello!
I keep getting this same error?
any ideas?
kd8qlo
Postby samuel_t » Wed Mar 11, 2020 2:48 pm
kd8qlo wrote:
Hello!
any ideas?
Hello! Reinstall Microsoft Visual C++ runtime then try to import a model with Universal Importer...
samuel_t
Postby christopheforet » Fri Mar 20, 2020 1:23 pm
Hi all!
I get errors when importing different file types...
On Mac OS, Sketchup 2017, plugin v1.1.5.
Any ideas on how to fix this?
christopheforet
Postby Dave R » Sat Mar 21, 2020 1:25 am
christopheforet wrote:I get errors when importing different file types...
On Mac OS
What version of Mac OS? As Samuel indicated a few posts up, "...plugin is not compatible with macOS 10.12.x, you need macOS 10.13 or greater."
Global Moderator
Postby ibex » Tue Mar 24, 2020 8:17 am
Thanks for providing this plugin.
I have installed it on Sketchup 2017 and also reinstalled the Windows C+ library. The plugin appears in my options and the toolbar is in place.
Each time I run it I get this error message trying to install an .stp file which I downloaded from here https://www.linak.com/products/linear-a ... a22/#/2d3d
ibex
Postby samuel_t » Thu Mar 26, 2020 4:42 pm
ibex wrote:Thanks for providing this plugin.
samuel_t
Postby lema » Fri Apr 10, 2020 9:39 am
Textures are not imported correctly.
The leaf is imported upside down.
This can be understood if you open the model in other applications.
https://drive.google.com/file/d/1-aTDHwlIvZhZY7RVeTcOy5WcILBdpfy1/view?usp=sharing
lema
Postby samuel_t » Mon Apr 13, 2020 2:44 pm
lema wrote:Hi
Hi, thank you for your report. Unfortunately I can't fix that issue. :?
samuel_t
Postby turbodizayn » Sat Apr 25, 2020 9:37 pm
Hi Sam!
This is great plugin and for me it is better than transmuttr and skimp. Genius work.
There is only problem-if model textured I have no polygon reduction =((( It works only with no texture material models for me. From time to time "redusePolygonCount" makes even more polygons then is in original model. May be it is 1.1.5 issue but there no source to download previous versions.
I hope it will be fixed, please!
PS You can see in second row no optimization of textured sphere
turbodizayn
Postby samuel_t » Sat May 02, 2020 3:33 pm
turbodizayn wrote:Hi Sam!
Hi Turbo!
Issues you describe seem to come from polygon reduction program (MeshLab) used in background by plugin. This mean, I can't fix them. :?
samuel_t
Postby suestorm » Sun May 10, 2020 3:26 am
Hi Samuel,
Thanks for the plug in, unfortunately I can not get it to work with Sketchup Pro 2019 or 2020. I downloaded universal importer v1.1.5.rbz from SketchUcation and installed it using the Extension Manager. I click on "Import with Universal Importer" in the File menu, select my .obj or .fbx model, and get the following error message. (please see attachment) and then the program crashes.
I am using Mac OS 10.15.1 Catalina. I have Sketchup Pro 2019 and 2018 and I get the same result on both versions.
Any suggestions?
thanks,
Dawn
suestorm
Postby edwinfolk » Mon May 11, 2020 8:25 am
Hello Samuel,
This looks like an awesome plugin and incredibly useful for rendering. Unfortunately, like Sue I cannot get it to work. I am using 2018 SKU and MacOS 10.15.2. Is there a work around? Or, is our OS not compatible at this time? Look forward to your answer and thanks.
edwinfolk
Postby samuel_t » Mon May 11, 2020 12:12 pm
Hi suestorm, hello edwinfolk,
I don't have a real mac computer. :?
When error occurs in SketchUp: Can you copy-paste command that fails ("/Users/.../assimp.nfo") to a terminal then show me back result?
This way I could maybe remotely debug...
samuel_t
Postby suestorm » Mon May 11, 2020 8:21 pm
Hi Samuel,
Thanks for your reply. I don't understand what you mean about sending you a terminal, but I copy/pasted what comes up in the error box on my screen. Also attached a screen grab. I see several Mac users have posted the same error message, we are all having a consistent problem. I am on Mac OS 10.15.4 Sketchup Pro 2020. Thanks.
Universal Importer Error: Command failed: "/Users/dawn/Library/Application Support/SketchUp 2020/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp" info "/Users/dawn/.UniversalImporter/tmp/import.fbx" > "/Users/dawn/.UniversalImporter/tmp/assimp.nfo"
/Users/dawn/Library/Application Support/SketchUp 2020/SketchUp/Plugins/universal_importer/assimp.rb:166:in `get_texture_refs'
suestorm
Postby samuel_t » Wed May 13, 2020 5:43 pm
suestorm wrote:Hi Samuel,
Thanks for your reply. I don't understand what you mean about sending you a terminal [...]
Hi suestorm,
I mean:
1. Open SketchUp.
2. Import a .fbx model with Universal Importer plugin.
3. Wait error... then copy-paste following command to your terminal. (See this tuto here to know how.)
Code: Select all
4. Send me back terminal result (text or screenshot).
Thanks.
samuel_t
Postby TIG » Wed May 13, 2020 6:06 pm
I think something might be getting lost in translation ?
For 'Terminal' perhaps read 'SketchUp > Window > Ruby Console' [open it before doing anything]
Although on a MAC there is a separate 'Terminal' app, surely you'd need it running before the error occurs ?
Global Moderator
Postby samuel_t » Wed May 13, 2020 6:11 pm
TIG wrote:I think something might be getting lost in translation ?
I'm talking about that separate 'Terminal' app.
samuel_t
Postby TIG » Wed May 13, 2020 6:34 pm
So do you need to explain to MAC users to open the Terminal first, and then try your tool...
And any error-messages might appear in that Terminal window ?
Global Moderator
PreviousNext
Return to Plugins
Users browsing this forum: bean3333, MarcoDusi, samareya, shah613 and 15 guests
