by samuel_t » Sat Jan 04, 2020 12:58 am
Hi!  Here's a free new SketchUp plugin: Universal Importer. It imports more than 50 3D file formats*. Bonus: You can reduce polygon count of imported model or existing model. => You can download it from SketchUcation PluginStore. (*) Supported formats: - 3D - 3DS - 3MF - AC - AC3D - ACC - AMJ - ASE - ASK - B3D - BLEND - BVH - CMS - COB - DAE/Collada - DXF - ENFF - FBX - glTF 1.0 + GLB - glTF 2.0 - HMB - IFC-STEP - IRR / IRRMESH - LWO - LWS - LXO - M3D - MD2 - MD3 - MD5 - MDC - MDL - MESH / MESH.XML - MOT - MS3D - NDO - NFF - OBJ - OFF - OGEX - PLY - PMX - PRJ - Q3O - Q3S - RAW - SCN - SIB - SMD - STP - STL - TER - UC - VTA - X - X3D - XGL - ZGL
samuel_t
- Name: Samuel Tallet
- Operating system: Windows
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: illustration, cartoons
by Pixero » Sat Jan 04, 2020 7:48 pm
Wow. Thanks. Does it import textured objects?
Pixero
- Name: Pixero
- SketchUp version: 2019
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by samuel_t » Sat Jan 04, 2020 8:19 pm
Pixero wrote:[...] Does it import textured objects?
Yes. If input model has only one material: select material texture at second step. If input model has more materials: you can ignore second step because materials should be automatically loaded:
samuel_t
by Khai » Sun Jan 05, 2020 12:08 am
thank you thank you thank you!!!
started to move my old trueSpace models from the archives to Sketchup...
just gotta work out a method tho... some of my models (well all of them) are multipart models that are to big to bring in as one mesh. problem is, splitting them down means having to line it all up again, unless I'm missing a key modifier for "paste in place"....
Khai
- Name: Khai
by samuel_t » Sun Jan 05, 2020 3:01 am
1.0.1 version adds: - Polygon reduction, - French translation. UIR Plugin Polygon Reduction Demo.jpg Download latest Universal Importer plugin from SketchUcation PluginStore.
samuel_t
by fredo6 » Sun Jan 05, 2020 7:24 am
Impressive...!
Fredo
fredo6
- PluginStore Author
- Name: Fredo6
- SketchUp version: 2021
- License type: Pro
- SketchUp use: interior design
by Glenn at home » Sun Jan 05, 2020 6:50 pm
Impressive, imported a Quake 2 (game) md3 file. Thank you
SketchUp Pro 2021 Dell Precision 3630 Intel i7-8700 32 GB Ram 512 M.2 PCIe SSD Nvidia RTX 2080
Glenn at home
- Name: Glenn at home
- License type: Pro
by glro » Sun Jan 05, 2020 8:14 pm
plateforme#202001051957_ca.dxf Hi, i tried your plugin It worked for a OBJ file but not for this DXF file (joined) do you know why?
glro
- Name: georges louis m le roux
- SketchUp version: 8
- License type: Pro
- SketchUp use: engineering and mechanical design
by Oxer » Sun Jan 05, 2020 8:17 pm
Fantastic plugin but I work on mac, is there plan for macos support? Spanish Language File es.zip
Oxer
- Name: Oscar
- Operating system: Mac
by Khai » Sun Jan 05, 2020 8:27 pm
ok. Cob (caligari trueSpace) is a little shakey, but don't worry, I'm likely to be the only person to be using that.... OBJ so far is nice and solid, other than some scaling issues.. everythings coming in tiny  but thats not a real issue... thanks again!
Khai
- Name: Khai
by samuel_t » Sun Jan 05, 2020 8:51 pm
glro wrote:Hi, i tried your plugin
do you know why?
Hi, Import fails because filename contains a '#' character. Substitute '#' with '_' and import will be succesful.  plateforme_202001051957_ca.dxf
samuel_t
by samuel_t » Sun Jan 05, 2020 9:02 pm
Oxer wrote:Fantastic plugin but I work on mac, is there plan for macos support?
Problem is I don't have macOS computer. Maybe I could try code it on a virtual machine?Since v1.0.3, plugin is compatible with macOS. Oxer wrote:Spanish Language File
Thanks for Spanish translation.
samuel_t
by samuel_t » Sun Jan 05, 2020 9:07 pm
Khai wrote:[...] thanks again!
You're welcome!
samuel_t
by paladinjnr » Mon Jan 06, 2020 3:51 pm
Hi I have installed the plugin in my SketchUp 2018 , absolutely brilliant how ever I am having a problem with textures , models import fine but no textures, which format should the textures be , I have tried dds and png
paladinjnr
- Name: Ray
- License type: Pro
- SketchUp use: hobby
- Level of SketchUp: Beginner
by ken » Mon Jan 06, 2020 5:14 pm
I have not had this program to import any files, STL or OBJ or STP. Below is the following error message I get trying to import an STP file of a nut that is 24k large.
I did notice in the program, it lists the file as obj file when the file name is, CROSBY 2160 300T NUT.STP.
Thanks for your help.
Ken
ken
- Premium Member
- Name: Ken
- License type: Pro
by samuel_t » Mon Jan 06, 2020 5:25 pm
paladinjnr wrote:Hi I have installed the plugin in my SketchUp 2018 , absolutely brilliant how ever I am having a problem with textures , models import fine but no textures, which format should the textures be , I have tried dds and png
Could you please upload whole folder (model and textures) to a file hoster? This way I could debug it.
samuel_t
by paladinjnr » Mon Jan 06, 2020 5:49 pm
Will do Hi Here is a link to the model as requested. https://filehorst.de/d/dhiIBdiyMany Thanks Rae Thank You for your help, I have spent most of today importing different models , some worked some didn't , so I am gong to give it a break for a couple of weeks then pick it up again . Once again many thanks for your help Keep up the good work Rae
paladinjnr
- Name: Ray
- License type: Pro
by samuel_t » Mon Jan 06, 2020 5:52 pm
Good news: I'm working on a macOS version of plugin.  Stay tuned!
samuel_t
by samuel_t » Mon Jan 06, 2020 6:03 pm
ken wrote:I have not had this program to import any files, STL or OBJ or STP. Below is the following error message I get trying to import an STP file of a nut that is 24k large.
Ken
Did you tried plugin with another model? If yes, does same (assimp stop) problem occurs? Install Microsoft Visual C++ library then restart SketchUp. Let me know if problem persists.
samuel_t
by TIG » Mon Jan 06, 2020 8:42 pm
Run SketchUp as Administrator then re-import OBJ model. Let me know if problem persists.
If this step fixes the issue then it's almost certain that SketchUp was not installed correctly ! To fix it... Whilst logged into Windows as your normal Windows user-name, ensure that SketchUp is closed. Find the SketchUp installer's exe file - probably in your Downloads folder ? Select the exe file's icon and right-click > context-menu > "Run as administrator" When prompted choose "Repair". Restart SketchUp and retry... Installing any complex app in any other way can cause weird and unpredictable problems, often around permissions... So never double-click an installer's exe file to 'Run' it - even if you have admin-powers, it is not the same thing.
- Global Moderator
- Name: TIG
- License type: Pro
by Didier Bur » Mon Jan 06, 2020 9:04 pm
French translation file  fr.zip
Didier Bur Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
- Name: Didier Bur
- SketchUp version: 2020
- License type: Pro
by samuel_t » Mon Jan 06, 2020 9:38 pm
Your model had absolute paths to textures. That's not supported by plugin. I converted absolute paths to relative paths with a text editor. It's OK now: Fixed DirectX Model.png Fixed model is attached below: fixed-directx-model.zip
samuel_t
by samuel_t » Mon Jan 06, 2020 9:39 pm
Didier Bur wrote:French translation file
Thank you!
samuel_t
by samuel_t » Tue Jan 07, 2020 4:17 am
1.0.2 version adds: - Preliminary macOS support, - Spanish translation. Download latest Universal Importer plugin from SketchUcation PluginStore.
samuel_t
by Danish9762 » Tue Jan 07, 2020 8:38 am
Hi sir im using sketchup 2017 when i install this plugins by extension manager so im getting unsigned plugin please contact plugins developer. Not working please gix it or tell me how to fix it
Danish9762
- Name: Danish
- SketchUp version: 2016
- License type: Pro
- SketchUp use: education
by juju » Tue Jan 07, 2020 12:28 pm
Danish9762 wrote:Hi sir im using sketchup 2017 when i install this plugins by extension manager so im getting unsigned plugin please contact plugins developer. Not working please gix it or tell me how to fix it
@Danish9762: You need to relax the extension loading policy you have set withing SketchUp.
juju
- Premium Member
- Name: Juju
- License type: Pro
by samuel_t » Tue Jan 07, 2020 12:47 pm
@Danish9762 "Unsigned" problem isn't a bug, it just means plugin doesn't come from SketchUp Extension Warehouse.
As suggested by @juju, relax SketchUp extension loading policy settings. To access these settings, select Window > Preferences > Extensions Policy (Microsoft Windows) or SketchUp > Preferences > Extensions > Policy tab (OS X). SketchUp has three available extension policy modes: “Identified Extensions Only”, “Approve Unidentified Extensions”, and “Unrestricted”. Select “Unrestricted” then restart SketchUp.
samuel_t
by sketch3d.de » Tue Jan 07, 2020 3:49 pm
based on the MeshLab engine should maybe be mentioned.
sketch3d.de
- SketchUp version: 2018
- License type: Pro
- SketchUp use: other
by samuel_t » Tue Jan 07, 2020 5:50 pm
sketch3d.de wrote:based on the MeshLab engine should maybe be mentioned.
It was already mentioned on GitHub page. And now, it's also mentioned on SketchUcation page.
samuel_t
by pilou » Tue Jan 07, 2020 7:44 pm
- Top SketchUcator
- Name: Pilou
- Robot
Return to Plugins
