[Plugin] Random Entity Generator - v1.1.8 - 02 Jan. 2020
Postby samuel_t » Tue Dec 03, 2019 2:52 am
Hello, I created a plugin for SketchUp that generates random entities and randomizes existing ones. It's able to create proxies for Enscape. (It's also compatible with V-Ray and Thea Render.) You can doing scattering with it. ;)
=> You can download it from the SketchUcation PluginStore.
Below, three Random Entity Generator plugin demonstrations:
3
samuel_t
Re: [Plugin] Random Entity Generator - v1.0.0 - 03 Dec. 2019
Postby pilou » Tue Dec 03, 2019 12:22 pm
Always interesting! :thumb:
Not yet used (some busy with Flowscape ;) but can we have a version where elements are choosen in an existing family ? :enlight:
Speedy Galerie
Top SketchUcator
Re: [Plugin] Random Entity Generator - v1.0.1 - 03 Dec. 2019
Postby samuel_t » Tue Dec 03, 2019 9:46 pm
What's new in version 1.0.1?
- Generation process is way faster.
- Extension is translated in French.
- You can, via context menu, randomize position and size of selected entities:
samuel_t
Postby samuel_t » Tue Dec 03, 2019 11:45 pm
pilou wrote:[...] can we have a version where elements are choosen in an existing family ?
It's possible with 1.0.1 version...Attention, selected entities must be groups:
samuel_t
Postby pilou » Wed Dec 04, 2019 2:02 am
Absolutly marvelous! :fro: :thumb:
Speedy Galerie
Top SketchUcator
Re: [Plugin] Random Entity Generator - v1.0.2 - 04 Dec. 2019
Postby samuel_t » Wed Dec 04, 2019 4:05 pm
The 1.0.2 version adds many parameters:
- Rotate entities?
- Entity min size
- Entity max size
- Entity density
samuel_t
Re: [Plugin] Random Entity Generator - v1.0.3 - 05 Dec. 2019
Postby samuel_t » Thu Dec 05, 2019 1:21 am
With 1.0.3 version you can:
- Randomize components
- Glue entities to ground :enlight:
samuel_t
Postby pilou » Thu Dec 05, 2019 9:28 am
Near the perfection! :thumb:
What is the process for don't have frame (segments) around the object with the transparent texture/photo ?
If i erase them (segments) all is erased! (Texture/photo)
I can mask it but does exist something else ?
Here the fame was "masked"
Speedy Galerie
Top SketchUcator
Postby Pixero » Thu Dec 05, 2019 11:33 am
pilou wrote:Near the perfection! :thumb:
Set SketchUp to show Wireframes.
Open any group or component.
Drag to select the edges and right click to hide them.
Set SketchUp to Shaded with textures.
The edges are now "gone".
Pixero
Re: [Plugin] Random Entity Generator - v1.0.4 - 05 Dec. 2019
Postby pbacot » Thu Dec 05, 2019 7:03 pm
Looks like a good one. I think it's amazing you can make it work with Enscape and all. Thank you!
Top SketchUcator
Postby samuel_t » Thu Dec 05, 2019 7:04 pm
With 1.0.4 version:
You can create proxies for Enscape. So, a tree becomes a forest in secs.
Proxies are symbolized by little translucent cubes with a random color:
samuel_t
Postby samuel_t » Thu Dec 05, 2019 7:05 pm
pbacot wrote:[...] I think it's amazing you can make it work with Enscape and all. [...]
It also works with V-Ray and potentially other renderers. :) :thumb:
Just randomize the component-proxy made with V-Ray/other...
(Right click on component-proxy then left click "Randomize...".)
samuel_t
Postby pilou » Fri Dec 06, 2019 2:36 am
@Pixero
It's that I made with "Masked them" ;)
It's curious because seems to me that was a trick for have only the "material/texture/Photo" but maybe i have dreamed! :)
Speedy Galerie
Top SketchUcator
Re: [Plugin] Random Entity Generator - v1.0.5 - 07 Dec. 2019
Postby samuel_t » Sat Dec 07, 2019 1:33 am
What's new in 1.0.5 version?
- There is a new param: Avoid entity collision. After 5 unsuccessful attempts, collided entity is erased.
- Enscape proxies have real dimensions based on real model. This allows a better collision detection.
- You can specify, via context menu, a spawn zone for generated objects. It is called "Random Zone":
samuel_t
Re: [Plugin] Random Entity Generator - v1.0.6 - 07 Dec. 2019
Postby samuel_t » Sat Dec 07, 2019 9:33 pm
New in v1.0.6: If you've set a Random Zone, distribution algorithm follows possible mesh deformations:
Download latest REG plugin from the SketchUcation PluginStore.
samuel_t
Re: [Plugin] Random Entity Generator - v1.0.7 - 09 Dec. 2019
Postby samuel_t » Mon Dec 09, 2019 12:29 am
1.0.7 version:
- Adds four parameters:
- Entity minimum rotation
- Entity maximum rotation
- Follow face normals?*
- Overwrite entity colors?
- Supports multiple Random Zones.
(*) Thanks to Eneroth3 for its help.
samuel_t
Re: [Plugin] Random Entity Generator - v1.0.8 - 09 Dec. 2019
Postby samuel_t » Mon Dec 09, 2019 5:38 am
1.0.8 version fixes a bug about entity rotation.
samuel_t
Re: [Plugin] Random Entity Generator - v1.0.9 - 10 Dec. 2019
Postby samuel_t » Tue Dec 10, 2019 8:37 pm
1.0.9 version includes a library of proxies ready-to-use for Enscape and V-Ray. (It's available on Windows only.)
samuel_t
Re: [Plugin] Random Entity Generator - v1.1.0 - 11 Dec. 2019
Postby samuel_t » Wed Dec 11, 2019 2:08 pm
1.1.0 version:
- Adds a parameter: Entity max. altitude.
- Handles complex meshes very quickly:
samuel_t
Postby pilou » Wed Dec 11, 2019 2:35 pm
A FlowScape challenger! ;)
Speedy Galerie
Top SketchUcator
Re: [Plugin] Random Entity Generator - v1.1.1 - 12 Dec. 2019
Postby samuel_t » Thu Dec 12, 2019 10:06 pm
1.1.1 version:
- Adds a parameter useful e.g. to hide tree roots: Push entities to down (cm).
- Adds four presets to help you discover how parameters work in REG plugin.
samuel_t
Re: [Plugin] Random Entity Generator - v1.1.2 - 13 Dec. 2019
Postby samuel_t » Fri Dec 13, 2019 11:44 pm
What's new in 1.1.2 version?
- There is a "Preview" button in REG Parameters.
- Random Zones can be constituted of triangles.
samuel_t
Re: [Plugin] Random Entity Generator - v1.1.3 - 16 Dec. 2019
Postby samuel_t » Mon Dec 16, 2019 1:34 am
With 1.1.3 version:
You can set Random Zone from an image. Here is how. Note: SketchUp 2018 or greater is required.
samuel_t
Re: [Plugin] Random Entity Generator - v1.1.4 - 16 Dec. 2019
Postby samuel_t » Mon Dec 16, 2019 6:24 am
1.1.4 version enhances compatibility and performance for "Set Random Zone from Image" feature. Now, this feature is compatible with SketchUp 2017 or newer and is a lot faster.
samuel_t
Re: [Plugin] Random Entity Generator - v1.1.5 - 16 Dec. 2019
Postby samuel_t » Mon Dec 16, 2019 11:02 pm
1.1.5 version adds three parameters:
- When you set selection as Random Zone:
- Entity distribution algorithm
- When you set Random Zone from an image:
- How many vertical (Z axis) layers?
- Space between each Z layer (cm)?
samuel_t
Re: [Plugin] Random Entity Generator - v1.1.6 - 19 Dec. 2019
Postby samuel_t » Thu Dec 19, 2019 5:46 pm
1.1.6 version adds two parameters:
- Put entities in group
- Put entities in layer
Download latest Random Entity Generator plugin from the SketchUcation PluginStore.
samuel_t
Re: [Plugin] Random Entity Generator - v1.1.7 - 25 Dec. 2019
Postby samuel_t » Wed Dec 25, 2019 12:27 am
1.1.7 version fixes a bug concerning scaling.
samuel_t
Postby Didier Bur » Sat Dec 28, 2019 6:14 pm
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby samuel_t » Mon Dec 30, 2019 5:41 pm
Hi. You're right Didier. They're similar. ;)
samuel_t
Postby kenancakir » Mon Dec 30, 2019 11:32 pm
Thank you..
kenancakir
Next
Return to Plugins
Users browsing this forum: Bing [Bot], ibit, mark_ankon, rayZhao, Sorec1 and 16 guests
