[Plugin] CHAOS
[Plugin] CHAOS
Postby Pixero » Fri Nov 08, 2019 1:34 pm
Bring some chaos into your SketchUp scene with CHAOS randomizing script.
CHAOS moves, scales and rotates selected groups/components randomly in X,Y or Z axis within range.
Select which Axis you want to use.
Select if you want to move, scale or rotate or all of them at once.
World is the original SketchUp axis.
Current is the axis if you use the Axes tool to move the axes.
Local is the local axis inside each component/Group.
Transforms are made based on selected group/components origin (axis point).
To make the script NOT use a random value set both min and max to the same value.
Also note that those values can be negative. For example min: -100 and max 100 to make the script randomize in both positive and negative directions from the original position.
https://sketchucation.com/pluginstore?pln=Chaos
3
Pixero
Re: [Plugin] CHAOS
Postby Box » Fri Nov 08, 2019 2:24 pm
Scale and Rotate work, but Move doesn't seem to.
Re: [Plugin] CHAOS
Postby Pixero » Fri Nov 08, 2019 2:33 pm
Hmm. Ill look ito it.
Pixero
Re: [Plugin] CHAOS
Postby rv1974 » Fri Nov 08, 2019 5:35 pm
Great progress Pixero, many thanks!
I hope non-modal thing will eventually arrive.
rv1974
Re: [Plugin] CHAOS
Postby Pixero » Fri Nov 08, 2019 6:17 pm
Version 1.0.1
Fixed typo so now Move works as it should.
Pixero
Re: [Plugin] CHAOS
Postby Pixero » Fri Nov 08, 2019 6:33 pm
rv1974 wrote:Great progress Pixero, many thanks!
For now you could create a shortcut for the script so it's one key to open it.
Pixero
Re: [Plugin] CHAOS
Postby Pixero » Fri Nov 08, 2019 6:53 pm
Version 1.0.2 Fixed another small typo.
Pixero
Re: [Plugin] CHAOS
Postby Box » Fri Nov 08, 2019 11:09 pm
That works, Thanks.
Do you want me to delete my gif from earlier or is it handy for showing how it works.
Re: [Plugin] CHAOS
Postby pilou » Fri Nov 08, 2019 11:56 pm
Ultra funny! Bravo! :fro:
(recall me a free prog very cool for make also funny images with only 3 keys!!! In 3 seconds! :enlight:
Chaoscope
Speedy Galerie
Top SketchUcator
Re: [Plugin] CHAOS
Postby Einstein » Mon Apr 13, 2020 5:49 pm
Hi!
A strange thing happens to me. Rotation command uses radians instead of degrees. In the plugin window I typed rotation from 0 to 1 and as I suspected, some cubes rotated about 57 degs which is 1 radian. How can this be fixed?
I attached a screenshot.
Wht's more - I saw in this video: https://www.youtube.com/watch?v=k56xEFJfeH8
that the suthor uses dedicated button for Chaos, but I cannot find it among available toolbars.
If I also may have a couple of suggestions for further improvement of the plugin (if you plan to keep developing it), these are:
- setting up steps for randomization, for example: 90 degrees rotation step in range of 0-180 degrees (which gives only 3 possible outcomes for entity rotation) or 1m move step in range of 0-5 meters (which gives 6 possible target positions for an entity),
- specify local center (origin) for scaling and rotation, different than component origin, for example: component base, component geometrical center, like in "CLF scale+rotate" plugin.
Einstein
Re: [Plugin] CHAOS
Postby TBoy » Tue Apr 14, 2020 3:07 am
Einstein, where this "dark theme" come from?
Is it on Windows?
TBoy
Re: [Plugin] CHAOS
Postby Einstein » Tue Apr 14, 2020 8:50 am
TBoy wrote:Einstein, where this "dark theme" come from?
Is it on Windows?
Yes, it's a theme for Windows 7 (not native but external, downloaded from internet) that affects appearance of SketchUp. I had to first patch system settings to allow installing external themes but it was easy. Note that the changed theme will affect some other program interfaces too, e.g. ArchiCAD, CorelDRAW, Notepad but not: Blender, Unity, MS Office, Autodesk programs.
If you write me a private message, I'll give you more precise instructions cuz it's an offtop now ;)
Einstein
Re: [Plugin] CHAOS
Postby pilou » Tue Apr 14, 2020 9:41 am
You have a little trick with Windows for inverse the display! ;)
DARK Interface For Windows no more puzzles to configure exotic user interfaces!
Windows settings (gear): Enable the "Invert Color" checkbox you can also enable "Magnifier" but...it will be automatic by the following shortcuts!
(you can use the search box to find the right Magnifier menu where there will be "Invert Colors")
Shortcuts:
Windows' Logo + "+" key
= Activates this Reverse Color Mode
Windows' Logo + "ESC" key
= Disable this Reverse Color Mode
here with my favorite prog! ;)
Speedy Galerie
Top SketchUcator
Return to Plugins
Users browsing this forum: BGG, jeffschmeff69, mujahidp786, pbacot, yepeto_1982 and 9 guests
