[Plugin] JS Random Move
Postby Pixero » Mon Nov 04, 2019 1:39 pm
A plugin that can move selected entities randomly within range in one, two or three axis.
https://sketchucation.com/pluginstore?p ... andom_Move
You can also take a look at my plugin Chaos that moves, scales and rotates randomly.
viewtopic.php?f=323&t=71774
Pixero
Re: JS Random Move
Postby rv1974 » Mon Nov 04, 2019 1:53 pm
Does it work with global \ local axis?
rv1974
Re: JS Random Move
Postby Pixero » Mon Nov 04, 2019 2:06 pm
Global...for now.
Pixero
Re: JS Random Move
Postby rv1974 » Mon Nov 04, 2019 2:32 pm
There's over 9000 free randomizators (move\scale\rotate) avaible for 3ds Max (working with local\global axes). I'm pretty shoked after almost 20 yers there's none in SU :?
Missing it so much
rv1974
Re: JS Random Move
Postby Pixero » Thu Nov 07, 2019 10:58 am
rv1974 wrote:I'm pretty shoked after almost 20 yers there's none in SU.
There is now. :D
Updated to 1.1 with World axis, Current axis and Local axis movement.
A tip if you want to move a defined distance and NOT random is to set the low and high values to the same. Also note that the values can be negative so for example it can be Low: -100 and High: 100.
Pixero
Re: JS Random Move
Postby rv1974 » Thu Nov 07, 2019 11:47 am
Hi Pixero and thanks for sharing! Could the script memorize last used inputs ('Use' and 'Axis' parts? Wouldn't it be cool if it was non-modal?
P.S. in addition, please check PM.
rv1974
Re: JS Random Move
Postby Pixero » Thu Nov 07, 2019 11:51 am
I'll look into it.
Pixero
Re: JS Random Move
Postby Pixero » Fri Nov 08, 2019 1:10 pm
v1.1.1 Small fix so that the plugin remember last used values.
Pixero
Return to Plugins
Users browsing this forum: Google Bot, manok and 11 guests
