LibFredo6 - error message - can't install it
Postby phil8ships » Tue Aug 27, 2019 3:20 pm
several times I tried installing fredo 6 and get these error messages any idea what is going wrong
I am still using the old pro 8 and it says it's compatible with it - I don't want to upgrade to newer ones because everything in tools will change to different shapes and different new look which will be difficult to adjust
the error message below that I get
can't convert Range into IntegerError Loading File Fredo6_!LibFredo6.rb
no implicit conversion to float from nilError Loading File Fredo6_FredoCorner.rb
no implicit conversion to float from nilError Loading File Fredo6_FredoScale.rb
no implicit conversion to float from nilError Loading File Fredo6_FredoTools.rb
no implicit conversion to float from nilError Loading File Fredo6_Souvenir.rb
phil8ships
Re: LibFredo6 - error message - can't install it
Postby fredo6 » Tue Aug 27, 2019 7:12 pm
First, it would be good to indicate on which platform, Windows or Mac, you run Sketchup, either in your profile or in your message.
Second, you should indicate where you get these error messages: in a dialog box at startup, in the Ruby console.
Third, there should be line numbers in the message referring to the rb file. They are useful to troubleshoot.
Fourth, you should describe the circumstances of the problem: Is this after a new installation of Sketchup 8? Or a new installation of LibFredo6? or an upgrade of LibFredo6?
I can run LibFredo6, FredoScale and FredoTools with no problem on Sketchup 8 (Windows). Note that FredoCorner and Souvenir only support Sketchup 2016 and above.
So your errors may be due to a problem with the installation of those in Sketchup 8.
Fredo
fredo6
PluginStore Author
PluginStore Author
Return to Plugins
Users browsing this forum: nihiru and 2 guests
