Error in Profile builder 3
Postby deaneau » Mon Aug 19, 2019 11:33 am
Profile Builder produces an error
in the secound picture: PB3 will not work with profiles 1-1-7mm. At 1,8mm the profile is broken.
thank you
https://1drv.ms/u/s!AoU3tpJxqmvto3fSKun ... 7?e=JRWFhG
MADE, BORN AND LIVING IN BERLIN
Big Thank You to all Programmers
Some German words are so long that they have a perspective. M.Twain
deaneau
Re: Error in Profile builder 3
Postby pbacot » Mon Aug 19, 2019 8:50 pm
Could this be the small face limitation in SketchUp not PB. Try: Make a component of your work. Make a copy of the component and scale up 1000x. Perform the operation on the big copy of the component. Check that changes were made correctly in the original instance of the component.
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby deaneau » Wed Aug 21, 2019 3:52 am
ProfileBuilder2 have not this problem (1mm profil in the foreground)
deaneau
Postby Whaat » Fri Aug 30, 2019 7:26 pm
Can you try changing the extrude mode to Follow Me? You might get better results.
Can you please post the SKP file so I can test it? A lot of extrusion improvements were made in PB3 but there are some unusual situations that could give you strange results (eg. very small profiles combined with certain types of extrusion paths)
Thank you very much for the feedback
Whaat
PluginStore Author
PluginStore Author
Postby deaneau » Thu Sep 05, 2019 7:57 am
deaneau
Postby Whaat » Fri Sep 06, 2019 12:04 am
I'm not sure why PB2 worked, but PB3 has trouble with this due to a combination of the small scale of the model and also the type of path. There seems to be an issue with PB3 when extruding along a circular path where the path's axis is horizontal. The issue will not always occur. It depends on a number of things so this is somewhat of a corner-case that you have discovered.
We have logged this issue and will try to fix it in a future update. Thank you for bringing it to our attention.
As a workaround, avoid using very small profiles and try not to extrude around a circular path that has a horizontal axis.  It will more likely work if you extrude along a circular path where the axis of the circle points vertical.  Then, after creating the Profile Member, rotate it and move it into the proper position.
Whaat
PluginStore Author
PluginStore Author
Return to Plugins
Users browsing this forum: anana and 9 guests
