by Didier Bur » Tue Jul 23, 2019 4:08 pm
Hi all, I've updated my old plugin CompoSpray which is now live at the EW here: https://extensions.sketchup.com/en/content/composprayFaster, better, more reliable than before, compatible with SU2016 and higher, 14 different ways of spraying components. Enjoy  cs_2.gif cs_6.gif cs_mainDialog.jpg
Didier Bur Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
- Name: Didier Bur
- Operating system: Windows
- SketchUp version: 2020
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by juju » Tue Jul 23, 2019 8:33 pm
i'll be back.jpg Great work Didier, thank you!
juju
- Premium Member
- Name: Juju
- SketchUp version: 2021
- License type: Pro
by jenujacob » Thu Jul 25, 2019 1:01 pm
Thank you very much Sir Didier Bur!
jenujacob
- Name: jenujacob
- SketchUp version: 2018
- License type: Pro
by srx » Thu Jul 25, 2019 2:47 pm
Thank you Mr. Bur.  I am glad you on the road again. I noticed there is still an old bug with populating selected face - part of it is not populated, as it was masked, or something... Also when try to populate grass, I need to do it 5-6 times to reach the desired density. Would be nice to have pressure up to 1000%. Why not?
www.saurus.rs
srx
- Name: srx
- SketchUp version: 7
- License type: Free/Make
by db11 » Thu Jul 25, 2019 4:23 pm
With all of the discussion lately about sages and pros dropping off the SU map, it's great to see you back in the saddle and producing/updating plugins.
Your (renewed) contributions are much appreciated!
db11
- Name: Doug
- Operating system: Mac
- SketchUp version: 2019
- License type: Pro
by pbacot » Thu Jul 25, 2019 5:19 pm
Thank you very much!
- Top SketchUcator
- Name: pbacot
- SketchUp version: 2016
- License type: Pro
by HornOxx » Thu Jul 25, 2019 8:19 pm
Prima & 1000x Danke !!
never trust a skinny cook
HornOxx
- Name: HornOxx
- License type: Pro
by pilou » Fri Jul 26, 2019 12:05 am
Always innovative!
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
- SketchUp use: hobby
by chon » Fri Sep 13, 2019 8:42 am
Hello all,
Thanks Didier for this update.
I've got an issue : The plugin works fine when i install it in the C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2019\SketchUp\Plugins folder, but it doesn't work when i install it in my Fredo6's AdditionalPluginFolder.
If someone has an idea...
Many thanks for response.
SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
chon
- Name: chon
by Didier Bur » Fri Sep 13, 2019 10:38 am
Hi all, The path to the plugin is hard-coded in the script. So if you locate the plugin elsewhere than C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2019\SketchUp\Plugins\DBUR_Compo_Spray, it will not work. Sorry for the inconvenience, but what's the reason you want to install it with Fredo Tools ?
Didier Bur
- Name: Didier Bur
- License type: Pro
by chon » Mon Sep 16, 2019 8:20 am
Tanks for response Didier Bur wrote:Sorry for the inconvenience, but what's the reason you want to install it with Fredo Tools ?
The Fredo6's AdditionalPluginFolder is a small standalone script providing the capability to define one or several additional user-defined directories to load plugins in Sketchup. We use 4 licences of SU and it is really interesting to centralize all plugins in 1 place for updates or installations on the 4 machines at the same time. Edit : Compospray 1.4.2 was working fine with AdditionalPluginFolder after some corrections by TIG.
chon
- Name: chon
- Robot
Return to Plugins
