[Plugin] [$] s4u MultiSlice
Postby hdpv » Sun Jun 30, 2019 4:50 am
s4u MultiSlice v1.0.0
Multi Slice,Cut,Detach Selected Objects(Faces,Groups or Components).
3
hdpv
PluginStore Author
PluginStore Author
Re: [Plugin] [$] s4u MultiSlice
Postby srx » Sun Jun 30, 2019 8:20 am
Is this an upgrade to SU4You Slice plugin?
www.saurus.rs
srx
Postby hdpv » Sun Jun 30, 2019 12:35 pm
this is the new plugin.
hdpv
PluginStore Author
PluginStore Author
Postby dtrarch » Mon Jul 01, 2019 8:33 pm
Hi VI
Just a super improvement.
Bread and butter for everyday use.
How about a MULTI PATH version.?
Draw path and then slice
:thumb: :thumb: :thumb:
dtrarch
Premium Member
Premium Member
Postby hdpv » Fri Jul 05, 2019 11:22 am
Hi Dave!
Draw path and Double click or Enter or Select First Point for Close Selection.
hdpv
PluginStore Author
PluginStore Author
Postby glro » Sat Jul 06, 2019 2:33 pm
hdpv wrote:s4u MultiSlice v1.0.0
i was looking for a plugin that would select components inside a closed contour
for example the components closest to the tank
but this plugin does not select, it cuts along the contour
would it be possible to add an option "select without cutting?"
the native selecting box is rectangular only, and in some cases, it is not sufficient
glro
Postby hdpv » Fri Jul 12, 2019 2:47 pm
Hi Glro!
I plan do a new plugin for this issue. s4u_Crop_Selection,
Select objects within Polyline ,Window and invert selection.
hdpv
PluginStore Author
PluginStore Author
Postby dtrarch » Sat Jul 13, 2019 8:54 pm
Thanks Vi :thumb:
Dave
dtrarch
Premium Member
Premium Member
Postby glro » Tue Jul 16, 2019 9:03 am
hdpv wrote:Hi Glro!
good news !
this function is missing in sketchup
components totally inside the volume corresponding to the polyline projected on the perpendicular axis would be selected, just as the native function does it with a rectangle
the volume could also be based on a circle, instead of a polyline
waitng for s4u_Crop_Selection
glro
Postby LAUFERON » Sun Jul 28, 2019 8:05 am
Very useful plugin.
Is there a way to keep edges after cutting ?
The component loses its volume properties.
Redrawing lines "a la mano" of course... May be an automatic solution ?
Thanks for your job
Bruno
LAUFERON
Postby Dav_ID » Thu Jan 16, 2020 11:05 am
Hi there and happy new year !
Just few questions about really this cool tool :
I've tried it, but i had not enough time to try it before it expired
so,
Someone here know if it's possible to
1. add positive value (recovery) when cutting a component (like in SU4Panel)
2. add negative value (saw kerf) when cutting a component (like in SU4Panel)
3. add face to the section (after cutting)
... and eventually
4. cutting perpendicularly (normal) while being on 3D view ?
Thanks a lot !
David
Dav_ID
Postby JonFar » Fri Apr 10, 2020 1:24 pm
hi
I don't get how you do that last cut in the video
How does it snap to slice(or detach) right at half?
When I try to do that it just slices the lines from the viewer perspective (like in the move before that)
thanks
JonFar
Postby hdpv » Fri Apr 10, 2020 2:02 pm
Hold press Ctrl on Window ,Option on Mac
hdpv
PluginStore Author
PluginStore Author
Postby JonFar » Fri Apr 10, 2020 2:40 pm
thank you
sorry to bother you again, just one last question:
when I do that, it works almost perfect.. it just doesn't create any faces on the slices...
am I doing something wrong?
I have 'add section faces' on...
JonFar
Return to Plugins
Users browsing this forum: No registered users and 15 guests
