Bin Packing
Does this is yet existing ?
Say I have a rectangular surface 500500 units (can be any x,y)
Constraints is just to have the maximum of surfaces given : here 126126- all not 126*126 must be rectangular surfaces!
So something like that : all that is not 126*126 must be rectangular surfaces!
Will be fine if each surface can be also exported as png files
Hi Pilou, I am curious about your question, and am not sure if, you did not explain it well or if I am stupid Could you please give the question with a context like, what you are trying to solve and why, so I can work out which theory is correct
Say I have a Photo: X*Y (X & Y >126)
how trim it for have the maximum of pieces of 126*126?
Trim must be Vertical & Horizontal (as shown on my previous post)
All must be trimed, number of all pieces must be smaller as possible
Photo must be rebuilt with all pieces like a puzzle
Is that more clear ?MagicaVoxel : it's free!
Context is for this crazzy prog where you can't import images biggest than 126*126 pixels!
But you can import any number of images for assembly them !
minute 2.10 --> topshop is used but with result of images of same size images
I want use any size of the start image!Here I import an unic image of 126*126 pixel: the tulips' field must be grow!
