Double Offset
Double Offset
Postby Pixero » Fri Feb 09, 2018 11:22 am
Is there a plugin that works like the offset tool but offsets the edge to both directions at once?
Pixero
Re: Double Offset
Postby samnorth » Fri Feb 09, 2018 12:11 pm
Perhaps Offset Loops [hidden] in dropdown menu of Quad Face Tools? Use Control key to get the dual offset. I think TT said previously it's still in development and it's not very robust.
tut here from Winning with SU
https://www.youtube.com/watch?v=1fwkI_shOcQ&t=641s
samnorth
Premium Member
Premium Member
Re: Double Offset
Postby pilou » Fri Feb 09, 2018 1:20 pm
Sure! :)
By Sdmitch : MULTIPLE Offsets has this function inside! And many more! ;)
Speedy Galerie
Top SketchUcator
Re: Double Offset
Postby Pixero » Fri Feb 09, 2018 2:07 pm
Thanks for the ideas. The Offset loops keep crashing for me and the multiple offset script isn't in "realtime" like the offset tool in SU but I'll look into them.
Pixero
Re: Double Offset
Postby pilou » Fri Feb 09, 2018 2:33 pm
Maybe you can ask Sdmitch to modify its plugin for have repetition of the function at each new selection ?
Speedy Galerie
Top SketchUcator
Re: Double Offset
Postby CadFather » Sat Feb 10, 2018 8:36 pm
TIG's offset can do it - i modified the code to repeat the steps one positive and one negative values. works well, though there are some odd imprecisions.
https://sketchucation.com/forums/viewtopic.php?p=331303#p331303
let me know if you want the code pasted in too
Quarr-IT - SketchUp Training from the Master.. http://quarr-it.com/
CadFather
PluginStore Author
PluginStore Author
Re: Double Offset
Postby Pixero » Sun Feb 11, 2018 10:06 am
Yes please post the modified code.
Pixero
Re: Double Offset
Postby CadFather » Sun Feb 11, 2018 10:31 pm
hope TIG is ok with it:
main 2 routines:
Code: Select all
@@dist=nil
 def initialize(dist=nil)
   @toolname="extrudeEdgesByOffset"
   if dist==0
     puts 'Extrude Edges by Offset' + ': Offset cannot be 0.'
     return nil
   end#if
   model=Sketchup.active_model
   ss=model.selection
   edges=[]
   ss.each{|e|edges << e if e.class==Sketchup::Edge}
   if not edges[1]
     if not dist
       UI.messagebox('Extrude Edges by Offset') + (': Must Select >=2 Edges.')
     else
       puts 'Extrude Edges by Offset' + ': Must Select >=2 Edges.'
     return nil
   end#if
   verts=[]
   edges.each{|e| verts << e.vertices}
   verts.flatten!
   verts.uniq!
   pts=[]
   verts.each{|v| pts << v.position}
   cop=true
   vec=Geom::Vector3d.new(0,0,0)
   edges[0..-2].each_with_index{|e,i| vec=e.line[1].cross(edges[i+1].line[1])}
   vec=Z_AXIS.clone if vec.length==0 ### all in line
   plane=[pts[0],vec]
   pts.each{|p|
     if not p.on_plane?(plane)
       cop=false
       break
   if not dist
     if not cop
       UI.messagebox('Extrude Edges by Offset') + (': Edges must be coplanar.')
       return nil
     @@dist=0.to_l if not @@dist
     Sketchup::set_status_text(("Extrude Edges by Offset")+": "+("Distance: "), SB_PROMPT)
     results=inputbox(["Distance: "],[@@dist],"Extrude Edges by Offset"+"...")
     return nil if not results
     if results[0]==0
       UI.messagebox('Extrude Edges by Offset'+': Offset cannot be 0!'+"\n"+"Try again"+"...")
       return nil if not results or results[0]==0
     end#if
     @@dist=results[0]
   else ### dist passed as arg
     if not cop
       puts 'Extrude Edge by Offset'+': Edges must be coplanar.'
       return nil
     @@dist=dist.to_l
   end#if
   model.start_operation("Extrude Edges by Offset"+' '+@@dist.to_s)
   dist=@@dist
   group=model.active_entities.add_group()
   ents=group.entities
   if edges.length==verts.length ### looped
     tface=ents.add_face(pts)
    fverts=tface.outer_loop.vertices
    fpts=[]
      0.upto(fverts.length-1) do |a|
         vec1=(fverts[a].position-fverts[a-(fverts.length-1)].position).normalize
         vec2=(fverts[a].position-fverts[a-1].position).normalize
         vec3=(vec1+vec2).normalize
         if vec3.valid?
            ang=vec1.angle_between(vec2)/2
            ang=180.degrees if vec1.parallel?(vec2)
            vec3.length=dist/Math::sin(ang)
            t=Geom::Transformation.new(vec3)
            if fpts.length > 0
               if not (vec2.parallel?(fpts.last.vector_to(fverts[a].position.transform(t))))
                  t=Geom::Transformation.new(vec3.reverse)
            fpts << fverts[a].position.transform(t)
     nface=ents.add_face(fpts)
      tface.erase! if tface.valid? and dist>0
      nface.erase! if nface.valid? and dist<0
      face=nil; ents.each{|e|face=e if e.class==Sketchup::Face}
      face.reverse! if face.normal.z<0
      ol=face.outer_loop
      verts=ol.vertices if dist<0
      il=(face.loops-[ol])[0]
      verts=il.vertices if dist>0
      verts.each_with_index{|vert,a|
                vec1=(verts[a].position.vector_to(verts[a-(verts.length-1)].position)).normalize
            vec2=(verts[a].position.vector_to(verts[a-1].position)).normalize
            if vec3.valid?
               ang=90.degrees if vec1.parallel?(vec2)
               vec3.length= -dist/Math::sin(ang)
                    p=verts[a].position
               pt=p.transform(t)
                    ents.add_line(p,pt)
      tr=Geom::Transformation.new()
      len=ents.length
      len.times{ents.intersect_with(true, tr, ents, tr, true, ents.to_a)}
      cedges=[]; ents.each{|e|cedges << e if e.class==Sketchup::Edge}
    else ### open ended
      edges.each{|e|ents.add_line(e.start.position, e.end.position)}
      edges=ents.to_a
      es=[]
      ee=[]
      se=[]
      edges.each{|e|
        if not e.start.edges[1]
          es=e.start
          ee=e.end
          se=e
          break
        elsif not e.end.edges[1]
          es=e.end
          ee=e.start
          se=e
          break
        end#if
      nedges=[se]
      verts=[es,ee]
      (edges.length-1).times{
        edges.each{|e|
          next if nedges.include?(e)
          if e.start==ee
            verts << e.vertices
            ee=e.end
            nedges << e
          elsif e.end==ee
            verts << e.vertices
            ee=e.start
            nedges << e
      verts.flatten!
      verts.uniq!
      opts=[]
        if a==0 #special case for start vertex
            v=verts[a].position.vector_to(verts[a+1].position).normalize
            f=dist/dist.abs
            t=Geom::Transformation.rotation(verts[0].position, vec, 90.degrees*f)
            vec3=v.transform(t)
            vec3.length=dist.abs
            opts << verts[a].position.transform(vec3)
       elsif a==verts.length-1 #special case for end vertex
            v=verts[a-1].position.vector_to(verts[a].position).normalize
            f=dist/dist.abs
            t=Geom::Transformation.rotation(verts[a].position, vec, 90.degrees*f)
            vec3=v.transform(t)
      else
            vec1=(verts[a].position.vector_to(verts[a+1].position)).normalize
            if vec3.valid?
               if not vec2.parallel?(opts[-1].vector_to(verts[a].position.transform(t)))
               opts << verts[a].position.transform(t)
      end#if
      begin
        nedges=ents.add_edges(opts)
      rescue
        nedges=[]
      pts=[]
      verts.each{|v|pts << v.position}
      ents.erase_entities(edges)
      begin
        edges=ents.add_edges(pts)
      rescue
        edges=[]
      pts.each_with_index{|p,i|ents.add_line(pts[i],opts[i])}
      len=ents.length
      cedges.length.times{
        ents.to_a.each{|e|
          next if e.class!=Sketchup::Edge or not e.valid?
          e.find_faces
      ents.to_a.each{|e|e.reverse! if e.class==Sketchup::Face and e.normal.z<0}
    end#if
    model.commit_operation
# CREATE  REVERSE GROUP
     model.start_operation("Extrude Edges by Offset - Reverse Side"+' '+@@dist.to_s)
   dist=@@dist*-1
   ents=group.entities
    fpts=[]
         if vec3.valid?
            if fpts.length > 0
      ol=face.outer_loop
            if vec3.valid?
                    p=verts[a].position
               pt=p.transform(t)
                    ents.add_line(p,pt)
      len=ents.length
    else ### open ended
      edges=ents.to_a
      es=[]
      ee=[]
      se=[]
      edges.each{|e|
          es=e.start
          ee=e.end
          se=e
          break
          es=e.end
          ee=e.start
          se=e
          break
        end#if
      nedges=[se]
      verts=[es,ee]
        edges.each{|e|
          if e.start==ee
            verts << e.vertices
            ee=e.end
            nedges << e
          elsif e.end==ee
            verts << e.vertices
            ee=e.start
            nedges << e
      verts.flatten!
      verts.uniq!
      opts=[]
            f=dist/dist.abs
            vec3=v.transform(t)
            f=dist/dist.abs
            vec3=v.transform(t)
      else
            if vec3.valid?
      end#if
      begin
      rescue
        nedges=[]
      pts=[]
      begin
      rescue
        edges=[]
      len=ents.length
        ents.to_a.each{|e|
          e.find_faces
    end#if
  Sketchup.send_action("selectSelectionTool:")
  end#def
CadFather
PluginStore Author
PluginStore Author
Return to Plugins
Users browsing this forum: No registered users and 7 guests
