Medeek Wall Plugin
Re: Medeek Wall Plugin
Postby medeek » Tue Jul 14, 2020 8:54 am
Version 1.5.5 - 07.14.2020
- Enabled the gable wall tool with the ability to draw and edit shed walls.
View model here:
https://3dwarehouse.sketchup.com/model/ ... Shed-Walls
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Jul 14, 2020 3:22 pm
Updated todo list (as of July 14, 2020):
1.) Making the Window, Door and Garage Door modules work with generic walls, not just Medeek walls.
2.) Shear Wall module which will ultimately integrate with the engineering plugin.
3.) Presets for Garage Doors
4.) Move the Estimating module to the new Medeek Project extension, and further develop this module as it relates to the wall plugin.
5.) Start work on the integrated  Medeek Engineering  extension, start with window and door headers for vertical loads.
6.) Additional door and window types as requested (eg. bi-fold closet doors, sliding glass doors, pocket doors, double and triple single hung windows).
7.) Spend some time on the new tabs in the global settings, currently showing an Under Construction sign.
8.) Stair module permutations: U, L, T etc…
9.) Further “idiot” proofing of the plugins: (zero value, nil values, checking for impossible geometry, etc…)
10.) Wall Justification
11.) Interior trim added to Medeek Interior extension.
12.) Resume development of the Medeek Floor extension.
The list has gotten a lot shorter in the last couple of months. I'm excited to finally have a working shed and gable wall type, there is still a lot more work to be done with many more gable variants, but I will attack those as specific requests are made for each type.
I feel it is time to move back to the complex roof module but before I do I may look at the new number one on this list.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Jul 15, 2020 4:06 am
While I am still fresh with gable walls (and the code for this module) I am contemplating getting the hip variant done as well:
I've already got two votes in favor of it (myself and Larry Belk) however I want to put this out to everyone else and find out if it is of any interest, would you use this gable wall type?
It will probably take me about 3 or 4 days to make it happen or I can move on to other items in the list.
3
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Jul 16, 2020 9:41 am
Version 1.5.6 - 07.16.2020
- Updated the gable wall module to allow for zero wall height shed walls.
- Added triple single hung windows to the window module.
View model here:
https://3dwarehouse.sketchup.com/model/ ... ung-Window
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Jul 16, 2020 8:09 pm
I've been chiseling away at these plugins now for almost 5 years, granted I only started working full time on them since April 2018, but I do think they have evolved significantly even at that.
With that being said there is still much to do. Additional plugins (Floor, Interiors, Decks, Project, Engineering, RC, etc...) are needed to fully flesh out the building and all of its potential elements. At some point the engineering and estimating pieces also need to become a reality, this will take everything to a new level. Sadly I am still working on the design/architectural elements, but if all goes well I should have most of it wrapped up in a few more months and then begin the engineering and estimating pieces. I also want the ability to export elevations and sections quickly into Scenes and then they can be easily moved into Layout, I've got some good ideas on that. A DXF export utility for floor plans etc... would also be nice, there is so much one can do with the API, it is mind boggling.
Every day I get emails from customers and potential customers requesting various features or new plugins, obviously there is a demand for this sort of thing, my email inbox bears this out. Unfortunately, I am so over taxed just trying to knock out the things on my existing todo lists that many of these great ideas go by the wayside (some do eventually make it on to my lists).
For a concise summary of the recent updates:
http://design.medeek.com/resources/wall ... gelog.html
As they say though, the squeaky wheel gets the grease, if I get enough demand for a certain feature it tends to move it up the list. Please keep the feedback rolling in, it only makes the plugins better.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Jul 19, 2020 6:13 pm
So I'm looking at the hip wall again because I've had some further interest in it.
However, I'm trying to figure out the best way to frame the top plates, which variant is preferred:
Version 1:
Version 2:
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Jul 20, 2020 10:46 pm
First look at a hip wall with blocking:
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Jul 21, 2020 2:43 pm
Hip wall with insulation and blocking:
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Jul 21, 2020 7:04 pm
Hip wall with windows and doors:
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Jul 22, 2020 5:02 am
Version 1.5.7 - 07.21.2020
- Enabled the gable wall tool with the ability to draw and edit hip walls.
View model here:
https://3dwarehouse.sketchup.com/model/ ... Hip-Wall-2
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Jul 22, 2020 6:30 pm
Version 1.5.7b - 07.22.2020
- Updated the gable wall module to allow for zero wall height hip walls.
- Fixed a bug with the trimming of Simpson Strong-Tie wood shear walls (WSW).
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Jul 22, 2020 11:01 pm
Off the beaten path a bit today, had a discussion about engineering and the plugins, so it got me thinking about the engineering module and beams and headers. Some ideas on representing loads on beams below:
Not sure I like how the distributed loads are represented with a transparent PNG, it might be better to simply draw two connected arrows which represent the extent of the distributed load (start and end points along the length of the beam).
The colors represent different load types (ie. Dead, Live, Snow).
The magnitude will be represented by the height of the arrows and size of the arrow heads.
The loading diagrams will be placed on their own specific layer so they can easily be toggled on an off.
Initially I think it would be best to stick with just rectangular distributed loads, trapezoidal and triangular loads complicate things considerably. Notice how the loading is placed on the beam such that coincident loads are offset in the Y axis so they can be better visualized and not Z-fight each other.
This would be a significant upgrade to the plugins, allow the user to quickly calculate and check a beam or header, similar to doing a check in Weyerhauser's Forte or any other comparable engineering application.
The output would be something similar to my Beam Calculator here:
https://design.medeek.com/resources/bea ... culator.pl
However the output probably should be less verbose and more compact, similar to the one page output of Forte.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Jul 23, 2020 8:44 pm
Version 1.5.7c - 07.23.2020
- Fixed a bug with certain wall sheathing materials as applied to gable, hip and shed walls.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Aug 01, 2020 10:21 pm
Version 1.5.8 - 08.01.2020
- Fixed a bug with all wall assemblies when auto-assigment of materials is turned off in the global settings.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Aug 02, 2020 10:53 pm
Version 1.5.8b - 08.02.2020
- Added a semi-transparent polygon fill to the draw wall tool wireframe.
- Added an option for vertical ZIP Systems© 7/16" and 1/2" wall sheathing materials.
View model here:
https://3dwarehouse.sketchup.com/model/ ... thing-Vert
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Aug 18, 2020 10:47 am
Version 1.5.9 - 08.18.2020
- Added the "Basic Options" parameters to the Wall tab of the Global Settings.
I'm not sure why these parameters never got added to the global settings a long time ago but I guess better late than never.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Aug 19, 2020 2:33 am
Version 1.5.9b - 08.18.2020
- Fixed a bug with gypsum when applied to the end condition for interior shed walls.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Aug 19, 2020 11:50 am
Version 1.5.9c - 08.19.2020
- Fixed a floating point rounding error in the blocking and cavity insulation modules for all walls.
No bells and whistles tonight. Sometimes it's just about putting out the fires.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Aug 23, 2020 12:32 pm
Version 1.6.0 - 08.23.2020
- Enabled variable king stud and trimmer stud widths for garage doors (non-portal frame).
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Aug 24, 2020 12:26 am
Version 1.6.0b - 08.23.2020
- Added the ability to create, load and delete garage door presets within the Edit and Draw (HTML) Menus.
- Fixed a bug with reading in presets from the door and window edit menus.
3
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Aug 26, 2020 9:34 pm
Version 1.6.1 - 08.26.2020
- All gable wall types (gable, hip, shed) now include the option to enter in the wall slope as a pitch or angle.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Sep 01, 2020 4:04 pm
For completeness I think it would be a good idea to add the option for arched garage doors and dutch corners. The algorithms for arched doors already exist within the man door module and the geometry of dutch corners is very simple. Give me a couple of days and I will knock this one out.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Sep 02, 2020 2:46 am
Version 1.6.2 - 09.01.2020
- Added three additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Sep 06, 2020 10:04 am
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Sep 07, 2020 1:20 am
Version 1.6.3 - 09.06.2020
- Added (segmental) arched garage doors to the garage door module.
I still need to add the option for dutch corners.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Sep 08, 2020 3:27 am
Version 1.6.4 - 09.07.2020
- Added Dutch Corners to garage doors within the garage door module.
View model here:
https://3dwarehouse.sketchup.com/model/ ... rage-Doors
Now the garage door module feels a little more complete.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Fri Sep 11, 2020 3:20 am
Version 1.6.5 - 09.10.2020
- Added a parameter into the global settings to allow for adjustment of the size of labels and annotations.
- Added a parameter into the global settings to allow for adjustment of the font for text found within annotations and labels.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Fri Sep 11, 2020 8:55 pm
An example of a detached garage with arched doors set into a stemwall foundation:
View model here:
https://3dwarehouse.sketchup.com/model/ ... ched-Doors
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Fri Sep 11, 2020 10:46 pm
Tutorial 16 - Garage Doors (19:17 min.)
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Sep 15, 2020 9:05 am
Version 1.6.6 - 09.15.2020
- Fixed a bug with Tyvek and ZIP Systems sheathing when the sheathing is lapped at the corners (rectangular walls only).
design.medeek.com
medeek
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: arnilayshah, layalm11, uglydekill12 and 18 guests
