Fredo is the man!
grtzzz
Pep
[Plugin] Joint Push Pull - v2.0b - 17 Jul 11Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11 Fredo is the man! grtzzz Pep
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11just wanted to say THANK YOU
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Hi, BBLV:
You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11With face and tool selected...
Press TAB to open dialogue box Choose Finishing Options Pick option
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11What is your question? Your image doesn't show anything useful as far as a problem is concerned.
Inspecting mirrors is a job I could easily see myself doing.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11It's not a telepathic tool - just erase lines and faces that YOU don't want!
yes it works like a Ctrl+pull. Actually, doing like the native push pull is much more complex for: - creating holes - merging the surfaces after push pull Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen. I suggest you simply erase the unwanted lines. Fred
In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol:
If I understood well can't you just use the "vector pushpull"? Anyway here you have the behaviour of the three tools. Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Feature request: Option to disable the Context Menu.
+1 [I have already tweaked my copy so that there's no context-menu, as there are already too many things clogging mine up!] TIG
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Yea - I use to tweak it myself. But for each update I need to do it all over again.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11I keep getting an error when trying to extrude a few curved letters...
"General Error: cannot complete the transformation" Can someone give it try it a try and see if maybe it is something on my end? Steps to reproduce: 1. Open groud 2. Select All. 3.Click on JPP (J) [ Erase Original, border on all, make group, 30 deg] 4.Click on edge, pull, type 2", Enter >Error. Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11try booleenhelper.rb or scale X 1000 enter 2000" and it works here
john
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Interesting. I could do one letter at a time at the current size. I selected about half of them and tried it and got a Bug Splat.
I tried doing limited groups of letters. The center row went fine as did the first two thirds of the top row. When I tried to do the last batch of letters in the top row, Splat! Inspecting mirrors is a job I could easily see myself doing.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11I got splats on the 'r 'in 'marian' and 'heart'.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11At original size it Bugsplats big time! [probably a 'tiny facets issue' on the small curved edges in the R - but why not the P or & ?]
But Scale x100 and then JPP 200" [on the whole thing at once], then Scale back down x0.01m to get this good/swift outcome Please, register (free) to access all the attachments on the forums. TIG
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Scaling helped. Thanks!
Never thought it make a difference... is because SU doesn't like expressions with number like 0.00000000000000000000000000000000002003 ?
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11great plugins ! I use it a lot! Thank you !!!
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11I just got that "transformation" error as well.
While the attached SKP is documented, here's what happened. There are 2 errors depicted in the attached model. 1 - I tried to thicken (using JPP preset at 90 deg) the housing by .1 inch. Error. I read this thread and scaled up 10X, same result. If I do the hub and flanges separately, it works, but there is a mess to clean up. 2 - When I thicken any pair (or more) faces that are at an angle to each other, and any face has a hole in it, the hole thickens at some median angle, not perpendicular to its face. The circle on the thickened face is also distorted into an oval/ellipse. There is one other transformation error I've noticed as well, but seems to happen in specific repeatable cases where the transformation logic is simply stumped for a good solution. Ya kant code for every case.... bin-der dundat. I'll post a separate model of that problem if wanted. So now in those cases I know where to look and do a quick and simple fix. Believe me, JPP is a Golden Ruby I cannot live without. ![]() Apologies... First post I forgot the SKP file. Please, register (free) to access all the attachments on the forums.
__________________
jgb
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11My apologies if this was answered before, but is it possible to use this plugin to uniformly add thickness to a cylinder-like object? I created it by pulling a circle (and then scaling it at several points) and now would like to add some thickness to the currently hollow object, as it is going to be 3D printed. I am, in essence, trying to pull all the outside surfaces at a perpendicular angles.
Many thanks!
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Yes. Use the Joint Push/Pull (not the Vector). Select the surface of the cylinder and using the JPP tool, click on any face in the selection. It will outline in red. Pull it up as thick as you want, or more accurately, pull up a short distance and type the thickness to the Measurements box. Press <Enter> to get a preview, then <enter> again to complete the thickening.
Depending on the defaults you have for JPP, it may or may not form a group of the thickened section. You can explode the group if you want. __________________
jgb
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11@helios: Not to disparage such a fine tool as Joint Push/Pull, but a possible alternative is Pipe Along Path. Slightly different methodology, but similar result.
Yes, but PAP is not a tool for this problem. I use PAP a lot and its main advantage is making a tube or pipe along an arbitrary path. There are a few other solutions available to thicken the surface of a cylinder, or any shape, either in a straight line or a path. Follow-me is a so-so useful tool for a non-linear path. Making a circle with both inner and outer diameters then extruding the outer ring is probably best, but linear paths only. However, JPP is the only tool I know of that will equally thicken all surfaces, linear or not, and even bent/wavy surfaces, which was the case indicated by @helios. Think of an hour-glass. __________________
jgb
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Thank you for the quick replies! It looks like this plugin is what I am after.
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11Thank you very much.
Used to feel very good. Sorry. Not good at English.
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
