Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11
Postby driven » Mon May 02, 2011 4:48 pm
Fredo6 wrote: But it may not be true with other unzip utilities.
it's empty, but in there on the mac as well, Stuffit Expander...
john
driven
PluginStore Author
PluginStore Author
Postby massimo » Mon May 02, 2011 4:57 pm
I use 7-zip and there is an empty JPP_Dir_17 folder once unzipped.
Oh and :thumb: :thumb: Fredo. :)
massimo
Postby thomthom » Mon May 02, 2011 5:00 pm
I just used Windows to open the file. I don't use third party applications for zip files. No need.
PluginStore Author
PluginStore Author
Postby TIG » Mon May 02, 2011 5:21 pm
Here's a screenshot of the current archive which I just opened in AlZip - the v1.7 folder IS still there... :?
It also contains no files...
Global Moderator
Postby hgdn » Mon May 02, 2011 5:29 pm
Fredo6,
Thanks so much for upgrading already useful toy!
Have a nice day!
hgdn
Postby Frederik » Mon May 02, 2011 7:15 pm
I see the same folder structure in WinZip v14.5...
The JPP_Dir_17 is empty, but it's there...
Any way... Thanks A LOT for this... :)
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby fredo6 » Mon May 02, 2011 10:21 pm
I just posted a 'fresh' zip file in the main post.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby TIG » Mon May 02, 2011 10:23 pm
I can confirm that the unwanted empty v17 folder is no longer in the zip file :D
Global Moderator
Postby winnie70020807 » Wed May 11, 2011 11:01 am
thanks~
winnie70020807
Postby RizkySyahputra » Wed Jun 01, 2011 3:56 am
it's amazing :thumb: :berserk: :berserk: :berserk: :berserk: :P
RizkySyahputra
Re: [Plugin] Joint Push Pull - v2.0a - 16 Jul 11
Postby fredo6 » Sat Jul 16, 2011 5:08 pm
NEW RELEASE
version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
Note that the parameter "angle of influence" is no longer used.
See main post for download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Rich O Brien » Sat Jul 16, 2011 6:33 pm
Thanks Fredo. Much appreciated :thumb:
Rich O Brien
Administrator
Postby baz » Sun Jul 17, 2011 2:11 am
Great stuff Fredo, thanks.
Baz
I am both an early bird and a night owl, I am some form of permanently energized dragon.
baz
Re: [Plugin] Joint Push Pull - v2.0b - 17 Jul 11
Postby fredo6 » Sun Jul 17, 2011 10:36 am
NEW RELEASE
version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
Version 2.0b also includes the Italian translation
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Fri Jul 22, 2011 11:48 am
:thumb: :thumb:
PluginStore Author
PluginStore Author
Postby pep75 » Mon Jul 25, 2011 9:11 am
:berserk:
Fredo is the man!
grtzzz
Pep
pep75
Postby niks » Thu Aug 18, 2011 1:29 pm
just wanted to say THANK YOU :knockout:
niks
Postby BBLV » Sun Aug 28, 2011 5:58 pm
Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
Example of desired finished result:
BBLV
Postby mitcorb » Mon Aug 29, 2011 12:08 pm
Hi, BBLV:
You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool.
mitcorb
Top SketchUcator
Postby rock1 » Mon Sep 05, 2011 1:42 pm
using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
rock1
Postby Rich O Brien » Mon Sep 05, 2011 2:00 pm
With face and tool selected...
Press TAB to open dialogue box
Choose Finishing Options
Pick option
Rich O Brien
Administrator
Postby rock1 » Mon Sep 05, 2011 2:07 pm
Rich O'Brien wrote:With face and tool selected...
Pick option
I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :?
rock1
Postby Dave R » Mon Sep 05, 2011 3:50 pm
What is your question? Your image doesn't show anything useful as far as a problem is concerned.
Global Moderator
Postby TIG » Mon Sep 05, 2011 4:23 pm
It's not a telepathic tool - just erase lines and faces that YOU don't want!
Global Moderator
Postby fredo6 » Mon Sep 05, 2011 6:16 pm
rock1 wrote:using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
yes it works like a Ctrl+pull.
Actually, doing like the native push pull is much more complex for:
- creating holes
- merging the surfaces after push pull
Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen.
I suggest you simply erase the unwanted lines.
Fred
fredo6
PluginStore Author
PluginStore Author
Postby rock1 » Tue Sep 06, 2011 8:16 am
Fredo6 wrote:Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen.
Fred
In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol:
rock1
Postby massimo » Tue Sep 06, 2011 9:25 am
If I understood well can't you just use the "vector pushpull"? Anyway here you have the behaviour of the three tools.
massimo
Postby thomthom » Tue Sep 13, 2011 9:46 am
Feature request: Option to disable the Context Menu.
PluginStore Author
PluginStore Author
Postby TIG » Tue Sep 13, 2011 9:58 am
thomthom wrote:Feature request: Option to disable the Context Menu.
+1 :thumb:
[I have already tweaked my copy so that there's no context-menu, as there are already too many things clogging mine up!]
Global Moderator
Postby thomthom » Tue Sep 13, 2011 10:11 am
Yea - I use to tweak it myself. But for each update I need to do it all over again.
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: dace, hbanya, kenzo333 and 8 guests
