Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17Re: [Plugin] Joint Push Pull - v1.5 - 02 Sep 10Any chance of a new option to thicken a wall on both sides and delete the original wall in one step please?
Would allow for example tracing the centreline of a complex wall from Google Earth, (eg. the walls of a house) then thickening it in one step. At present it is difficult to achieve. You have to thicken it in one direction by half, then thicken it the other way by the same amount. Problem is when you do the second step it leaves the original faces there, or at least the outlines, even if you specify delete original faces, meaning you wind up with a line down the centreline of the wall top and bottom which you then have to delete. For a long complex wall that can be painful. Re: [Plugin] Joint Push Pull - v1.5 - 02 Sep 10Another request please. An option to say borders on external faces EXCEPT THE BOTTOM FACE. When thickening a wall for example, a face on the bottom is often not wanted since it will be sitting flat on the Google Earth surface.
Just don't select the bottom face. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Joint Push Pull - v1.5 - 02 Sep 10Regarding your issue with Joint PushPull not staying orthogonal, Use either VectorPushPull or NormalPushPull as other options. You can predefine the path the PushPull will follow with a line segment or by example with a nearby line already in the model.
That is, if I understood your problem. I take the slow, deliberate approach in my aimless wandering.
I do not know what you mean. I do not select the bottom face. I select the single vertical faces and push-pull them one direction. Faces get created all round and top and bottom. Without deselecting the selected faces I then push-pull them in the opposite direction. There is no way of not creating the bottom faces. But the problem is the outlines of the original faces remain on the top and bottom, along with numerous other lines generated by the push-pull. How do I prevent them? One thing I tried was pulling the faces in one direction with "Delete original faces" on and "No Borders". I then used the Cleanup plugin to delete all the orphaned edge lines from the original faces. I then reselected all the faces and tried to pull them in the opposite direction using Thickening and Borders on Outer Faces Only. It does not work. When you pull the wall in one direction using thickening, the original faces stay selected. If you then pull them in the other direction without deselecting them, they all move in the correct direction. If you do the first push-pull with no borders and delete original faces they do not stay selected. After you do the cleanup, you reselect them and try to pull them in the other direction but it does not work properly. Some of them pull the correct direction. Others pull the opposite way (the same direction as the first push-pull operation) meaning those parts of the wall end up offset from where they should be. Re: [Plugin] Joint Push Pull - v1.5 - 02 Sep 10I've been trying to extrude a wasching bowl by 12mm. The JPP crashes on me every time I do this no matter whether I try it on my XP machine at work or my Mac at home. Is this a bug, or too many faces?
Kind regards, Napper Re: [Plugin] Joint Push Pull - v1.5 - 02 Sep 10Napper
It's an awkward shape to JPP... I can't get a good result either ![]() Here's an alternative method... As it's a solid you can use Jim Foltz's 'shell' @12mm, then temporarily hide the top of the original outer-shell, PushPull the top of the new solid inner-shell up ~50mm so it will pierce the outer-shell's top, intersect both groups' geometry together, and then erase the unwanted parts in them, explode the two groups together and re-group as one, smooth it... ![]() TIG
Re: [Plugin] Joint Push Pull - v1.5 - 02 Sep 10Hi TIG,
this worked quite well, actually! I had to redo it, as I had given you the inner shell and needed an outer shell but that was good practice, actually... ![]() ![]() Napper Re: [Plugin] Joint Push Pull - v1.5 - 02 Sep 10Hi - thanks for all your hard work! This is such a useful, well designed tool!
Re: [Plugin] Joint Push Pull - v1.6 - 22 Apr 11NEW RELEASE
version 1.6 - 22 Apr 11: bug fix - better respect of offset distance in case where the surface is composed of faces with sharp angles. See main post for download. Fredo [Edit: I fixed the link to the download thread. TIG...]
This will be great! Thanks! ![]() ![]() ![]() ![]() --
SketchUpNoobie: the complete noob in all things SketchUp. Re: [Plugin] Joint Push Pull - v1.6 - 22 Apr 11
nice! works very well on my test case (which previously failed with v1.5). thanks for the update! dotdotdot
Re: [Plugin] Joint Push Pull - v1.6 - 22 Apr 11hey fredo
i've come across an instance where v1.6 is freezing sketchup and 1.5 handles it just fine.. i'm not sure if the problem is in something i'm doing wrong, something mac specific, or what. i'll attach the .skp (v8).. the two faces i'm having problems with are the ones painted orange. thanks [edit -- removed file] [and maybe someone else can try this with jpp v1.6 on windows (or mac to see if it's repeatable for them as well)] Last edited by jeff hammond on Mon Apr 25, 2011 3:35 pm, edited 2 times in total.
dotdotdot
Re: [Plugin] Joint Push Pull - v1.6 - 22 Apr 11Hi Fredo, Jeff's file fails on 10.5.8 as well, I'll attach the txt file john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Joint Push Pull - v1.7a - 25 Apr 11NEW RELEASE
version 1.7a - 25 Apr 11: Fix a major bug of v1.6 which was causing a freeze of Sketchup in some situations. If you installed v1.6, It is strongly recommended to move to JPP 1.7 See main post for download. Fredo
Re: [Plugin] Joint Push Pull - v1.7a - 25 Apr 11hi Fredo,
works on Jeff's skp on 10.5.8 now... cheers john learn from the mistakes of others, you may not live long enough to make them all yourself...
Indeed, I have just had to update JPP as I had freezing with a model. Many-many thanks, Fredo, for this excellent tool and the constant upgrades! ![]() Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11NEW RELEASE
version 1.8a - 01 May 11: Better respect the offset distance in case where the surface is composed of faces with sharp angles. In V1.8, this works also when there is an imposed plane set by Ctrl-Arrow. See main post for download. Fredo
![]() ![]() ![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11The JPP_Dir_17 folder is required?
I think not - as it contains nothing that's not already in the new 18 version ?? V18 works OK for me without v17... ![]() TIG
Re: [Plugin] Joint Push Pull - v1.8a - 01 May 11I got confused because the zip file contained the 1.7 files as well as the 1.8...
Tom, Are you sure? Which unzip program do you use? It is true that I took a copy of the 1.7 zip file, emptied it, and then insert the 1.8 files. With Winzip, there is no problem. But it may not be true with other unzip utilities. Fredo
Users browsing this forum: harun555444, wallacepinheirowp and 13 guests
