Foundation Plugin
Re: Foundation Plugin
Postby medeek » Fri Sep 06, 2019 7:23 pm
I'm interested in putting the new polyline stemwall tool through its paces. If you have a fairly complex foundation plan that you think I should try and model please email me a PDF of it.
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Fri Sep 06, 2019 10:24 pm
Version 1.4.2 - 09.06.2019
- Fixed a bug with the rebar in closed loop stemwall assemblies.
Critical bug fix, I strongly suggest upgrading to this version of the plugin.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Sep 07, 2019 5:27 am
I've moved to the complex roof development but there are still a number of glaring holes in the foundation plugin. To get a better feel for how well it would work I modeled up a foundation for a residence that I did some local engineering for a couple of years ago:
View model here:
https://3dwarehouse.sketchup.com/model/ ... undation-1
Really the only manual edits that were required was the blockouts for the garage doors and the footings for the porch roofs. The following list summarizes some areas that need further development:
1.) Need some sort of option for garage door block outs.
2.) Need the ability to create holes in stemwalls (crawl access, windows, doors)
3.) Add interior footings to regular slabs, similar to the interior footing tool for slab-on-grade foundations.
4.) Stemwall opening tool should also remove any conflicting rebar (boolean subtraction).
5.) Still need to add the tool for a simple polyline footing (ie. porch footing shown). The workaround is to create a stemwall and then manually delete the stemwall leaving the footing portion.
I'm also thinking about creating a material list table that summarizes quantities, similar to the legend I generate in the electrical plugin.
So much to do, I really need a whole team of developers to get everything done I need to do.
What would be interesting to know is how much time it would take to manually model up the equivalent geometry, also bear in mind that there would be no parametrics available so if you need to adjust something it would require considerably more time and effort to make that change. With the plugin if I need to adjust something like anchor bolt spacing I simply edit the assembly with a right click and the changes are instantaneous.
Modeling time was about 30 minutes. Most of that time was transcribing dimensions from a large, crumpled set of paper plans. The rest of the time was largely spent on fiddling with the garage door block outs and then trimming the rebar back. As it stands now I do think the plugin offers some significant time savings but there is much that remains to be done.
4
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby pbacot » Sat Sep 07, 2019 6:14 am
Impressive perseverance, talent, and dedication!
3
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby medeek » Sat Sep 07, 2019 8:35 pm
Combining a slab-on-grade with a stemwall footing (with steps):
View model here:
https://3dwarehouse.sketchup.com/model/ ... -and-Steps
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Sep 08, 2019 8:05 am
Version 1.4.3 - 09.07.2019
- Enabled the "Draw Strip Footing" tool with the following advanced options: rebar, drain pipe.
Similar to the polyline stemwall tool you can create closed loop polylines (polygons) as well as simple linear sections of footing.
Similar to the polyline stemwall tool the point selection of the tool is terminated with the "DOWN" arrow key.
The horizontal bar option is shown in the menu but is currently not enabled. I need to give this option some additional consideration before I make it live.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Sep 08, 2019 5:35 pm
After working through the complex foundation on Friday, and having to manually create stemwall blockouts for garage doors I've come to the conclusion that a stemwall blockout tool is critical to the success of this plugin.
I guess I'm just a lazy 3D modeler, but even having to push/pull a blockout is too much work for me and then it ultimately breaks the parametrics of that particular stemwall assembly, so manual edits should be avoided whenever possible.
Yet another toolbar:
Like the Wall plugin the Foundation plugin is starting to collect quite a few toolbars, this will be the sixth toolbar for this plugin. I'm starting to run out of screen real estate, I may have to do something about that, I'm not sure what yet.
The problem is that the plugins need to be able to do a lot of things, so there are a lot of tools and each operation/function needs its own icon or button to instigate it. I've managed to wrap some functions into context menus but some operations are better presented as a direct icon in my opinion.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Sep 09, 2019 10:58 am
First look at some column footings (spread footings) with and without pedestals:
I've decided not to add the column portion into the Foundation plugin, that will be part of the Wall plugin.
I just need to add a bit of rebar into these assemblies and then I will roll a new version.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Sep 09, 2019 9:36 pm
Version 1.4.4 - 09.09.2019
- Enabled the "Draw Column Footing" tool with the following footing types: spread footing, spread footing w/ pier.
- Added transverse and longitudinal rebar for column footings.
- Added the Stemwall Blockout toolbar and icons.
The Draw Column Footing tool is the 4th icon on the main toolbar.
This is a really easy tool to use, I highly recommend upgrading to the latest version to take advantage of it.
The blockout toolbar has been added however these tools will not be functional until the next release.
With the pier option enabled I would be interested in adding in options for vertical rebar (with hooks) and possibly hoops, but I first would like some more feedback in this regard.
3
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby pbacot » Mon Sep 09, 2019 9:43 pm
How is this integrated with the rest of the Foundation--or does it just create an isolated component from which you position copies into the model?
Top SketchUcator
Postby medeek » Mon Sep 09, 2019 9:53 pm
pbacot wrote:How is this integrated with the rest of the Foundation--or does it just create an isolated component from which you position copies into the model?
This tool creates separate footing assemblies within the model. It is separate from the rest of any other foundation assemblies.
These footing assemblies can be edited and moved anywhere within the model.
View model here:
https://3dwarehouse.sketchup.com/model/ ... h-Pedestal
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Sep 10, 2019 1:57 am
For concrete piers resting on a spread footing I was kind of thinking something along these lines for the rebar:
However, one would probably want the vertical bars to hook into the spread footing rather than terminate as shown.
Parameters might be something like:
Vertical Bars: Yes/No
Vert. Bar Dia.:
Vert. Bar Qty.: 2,4,6,8
Hoop Bars: Yes/No
Hoop Bar Dia.:
Hoop Spacing:
Let's try to avoid taking it to this extreme though:
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Sep 10, 2019 3:27 am
Probably something more along these lines:
View model here:
https://3dwarehouse.sketchup.com/model/ ... bar-Test-2
If you look closely at the model you will notice that the texture/material on the vertical bars is a bit of a mess where they flare out to meet the spreading footing. Special attention will be required to make sure the initial follow me operation is done on the X-Y plane and then the bars are rotated up into the vertical position.
Does this type of rebar detailing look useful? Sometimes I need to use a bit of restraint so I don't take things to far, but if this is something that would find some utility I can add the additional rebar options in.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Sep 11, 2019 12:54 am
Version 1.4.4b - 09.10.2019
- Added vertical and hoop rebar for column footings with round or square piers.
Sorry, useful or not, that pier rebar was just too tempting to pass on. When you enable piers and rebar you are now presented with an additional section with options for vertical and hoop rebar within the pier. Square piers are currently limited to two, four or eight vertical bars, round piers are limited to the following number of bars: 2, 4, 6, 8, 10, 12.
If you need more than twelve vertical bars then you are probably not designing a residential structure.
I'm not a concrete guy (haven't done a lot of reinforced concrete engineering, mostly lumber and timber), so this is kind of my best guess at what is appropriate for residential work. If you need specific details changed up, please let me know.
Square pier with eight vertical bars:
I'm also thinking about adding in sonotube footings/piers (no spread footing) with an option for a bell shaped footing:
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Sep 11, 2019 10:38 pm
Version 1.4.5 - 09.11.2019
- Added Sonotube footings to the "Draw Column Footing" tool.
- Added a flared "Bell" footing option for sonotube footings.
- Added vertical and hoop rebar for sonotube footings.
When you toggle the "bell" option on I have the vertical rebar bend 90 degrees as shown and extend to the perimeter of the bell (ground clearance maintained).
Sonotube footings without a bell option have vertical bar as shown.
View model here:
https://3dwarehouse.sketchup.com/model/ ... e-Footings
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Sep 12, 2019 2:44 am
Version 1.4.5b - 09.11.2019
- Added the option to place a double mat of rebar within a spread footing (top & bottom).
Note that the top mat is identical in size and spacing as the bottom mat.
View model here:
https://3dwarehouse.sketchup.com/model/ ... ete-Column
3
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby juju » Thu Sep 12, 2019 12:20 pm
juju wrote:thanks for the efforts!
the toolbars for your extensions are becoming rather elaborate and taking up a bit of toolbar / screen space, any chance you could implement a single initiation button/icon instead and have a secondary open when the primary has been triggered, much like Fredo does some of his extensions?
medeek wrote:Hmmm, you might be on to something with this.
I agree that the amount of toolbars has multiplied quite rapidly as I keep adding more features to each plugin, it does take up quite a bit of screen real estate now.
Thank you for the continued efforts Nathan! I see the toolbars are steadily increasing, any chance you can look into the request / suggestion above?
juju
Premium Member
Premium Member
Postby medeek » Thu Sep 12, 2019 3:47 pm
I am looking into this further. Again, not entirely sure on the best possible solution but I will see if I can either consolidate or provide some other system.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Sep 14, 2019 5:45 am
First look at the blockout tool and its results:
Now I just need to have it trim out the rebar and remove anchor bolts that are in the way.
I'm also including an option to have it remove anchor bolts or not remove them in the case that for some reason you don't want to remove anchor bolts that clash with the opening.
I'm going to assume that designer would always want to trim the rebar out and the insulation, but I could also be mistaken on this and might need to provide a couple more options that allow for toggling this behaviour on and off for each blockout.
The edit and delete functions seem to be stable, I just need to get on the move tool and make it work similar to the move tool for openings in the Wall plugin.
The blockout label is on the hidden layer and toggles on and off automatically with the blockout tools.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Sep 14, 2019 8:32 am
First look at rebar trimming and anchor bolt removal:
Now I just need to get the move function working correctly and I think this new set of tools is ready for prime time.
And yes, when you insert blockouts the plugin is correctly calculating the decreased volume of concrete or CMU blocks for the stemwall.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Sep 14, 2019 9:07 am
CMU stemwall with blockouts:
I think this plugin is finally beginning to coalesce into a legitimate extension.
Still, a few more items remain that need attention but I will need to put those on the back burner for a couple of months while I turn my attention to the truss and wall plugins. The biggest items are:
1.) Doors and Windows in foundation walls.
2.) Internal footings for basic slabs (not slab-on-grade)
3.) Finish integrating the Medeek Estimator with this plugin
4.) Engineering (footing calcs primarily), see example here: http://design.medeek.com/resources/foot ... ULATOR.pdf
5.) Retaining walls with engineering
6.) Additional interior bearing types
7.) Move/Stretch tool for SOG and Stemwall foundations
These are the big items that come to mind right now. The actual list is probably four times this list in size. Please let me know what additional features or improvements you would like to see.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Sep 15, 2019 12:05 am
Version 1.4.6 - 09.14.2019
- Enabled the "Draw Blockout" tool for polyline stemwalls.
- Enabled the "Edit Blockout" tool for polyline stemwalls.
- Enabled the "Move Blockout" tool for polyline stemwalls.
- Enabled the "Delete Blockout" tool for polyline stemwalls.
I will put out a short tutorial demonstrating this new tool even though it is mostly self explanatory.
One to thing to note is that this tool only works for the "new" polyline stemwalls. I'm not sure yet what I'm going to do with the old stemwall tool. Basically everything you can do with old tool you can achieve with the new polyline tool (with the exception of joist pockets). I will need to give this some more thought.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Sep 15, 2019 1:47 am
Tutorial 7 - Blockouts in Polyline Stemwalls (8:35 min.)
Unfortunately, I forgot to demonstrate the CMU option with the blockouts, so I will leave that up to the user to try that out for themselves.
If you are using stemwall foundations at all this newest feature is critical in my opinion. Manually creating blockouts in your stemwalls renders the parametric ability of the plugin mute, hence this latest addition was necessary.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Sep 15, 2019 2:05 am
It just occurred to me that the method/algorithm I use to remove rebar for a blockout can also be used to remove slab rebar or mesh from a slab depression. Now I have a solution for the slab depression reinforcement problem.
The only potential issue I see with this is the shear number of solids (reinforcement) that may need to be trimmed, especially if the user has specified wire mesh. I will give this some additional consideration and see if it will work.
It also just occurred to me that a stemwall opening (door & window) tool is very similar to the tool I just created and I can probably utilize almost 90% of the code I just created to quickly put together a tool for creating openings in stemwalls. So much for a relaxing Saturday evening and Sunday, I’ve got this.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Sep 15, 2019 4:20 am
What is the convention for calling out openings (windows and doors) in a basement foundation plan?
Do you list the actual size or is it similar to floor plans where you are using the nominal sizes (ie. 3040, 3068, etc...) but the actual opening is something entirely different?
To be honest, in my neck of the woods I don't see very many basement plans because of our high water table, most everything is stemwall foundations with crawl spaces.
Also would it be useful to have the plugin provide window and door bucks? If so what should that geometry look like?
As far as the actual window and doors, my plan is to eventually split out the window and door module from the wall plugin so that it can also be utilized to place windows and doors into basement walls.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Sep 15, 2019 4:59 am
As nearly I can tell the convention for doors and windows in basement plans is the same as in regular framing, so here is my proposed solution for openings in foundation walls:
Note that the header height is measured from the top of the door or window opening with the RO taken into account.
So for example a standard 3068 door would have an actual opening width of 38" and an actual opening height of 82.5" (blockout dimemsions), assuming the rough opening dimensions given. Assuming that a 4" slab is poured on the top of the footing then the header height would need to be 84". The height of the top of the door opening measured from the top of the footing would be 80" + 4" + 2.5" = 86.5"
Correct me if any of this goes counter to common practice.
However, another way of dealing with the door may be to actually blockout the foundation all the way to the footing so that the 4" slab extends through the doorway (I've seen it done both ways). In this scenario you still want the door height (80") to remain the same so that the callout is still given as 3068, however to maintain the vertical position of the door within the foundation wall the vertical RO would need to change to 6.5" and the header height would need to be 80".
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Sep 15, 2019 7:05 am
The seventh and hopefully final toolbar (at least for now):
This toolbar will allow the user to create, modify, move and delete openings (two types: doors, windows) within polyline stemwalls.
Once this toolset is added the plugin I think most of my major functionality issues with the plugin will be resolved.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Sep 15, 2019 7:51 am
The proposed parameters for Stemwall Openings (with default values):
Opening Type: Door (default), Window
Opening Width: 36"
Opening Height: 80"
Header Height: 84"
Horz. RO Offset: 1.0"
Vert. RO Offset: 2.5"
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Sep 16, 2019 3:51 am
Version 1.4.7 - 09.15.2019
- Enabled the "Draw Opening" tool for polyline stemwalls: Windows and Doors
- Enabled the "Edit Opening" tool for polyline stemwalls.
- Enabled the "Move Opening" tool for polyline stemwalls.
- Enabled the "Delete Opening" tool for polyline stemwalls.
- Fixed a bug with the Edit Blockout tool menu.
Similar to the blockout tools this new feature only works with polyline stemwalls as noted in changelog.
If you have a lot of rebar in your foundation walls and a lot of openings in those walls then the plugin will have a lot of boolean subtraction to do in order to trim out the rebar as shown, this will cause a performance hit but should not be unreasonable on an adequately equipped PC or Mac. For older machines one way around this is to only toggle rebar on as a final step after all of your other edits to the foundation wall are complete.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Sep 16, 2019 5:11 am
Tutorial 8 - Windows and Doors in Polyline Stemwalls (8:31 min.)
design.medeek.com
medeek
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: dvd63, Olgadesigner and 20 guests
