Foundation Plugin
Re: Foundation Plugin
Postby medeek » Thu Mar 05, 2020 10:21 am
Version 1.5.7b - 03.05.2020
- Updated the polyline stemwall draw tool to terminate (point selection) with the "End" key instead of the "Enter" key.
- Updated the strip footing draw tool to terminate (point selection) with the "End" key instead of the "Enter" key.
For now the point selection termination will be either the down arrow or the "End" key. Using the "Enter" key causes a conflict when the user is manual entering a dimension for a segment length (key in the dimension and then click enter). Until I can figure out how to resolve this conflict this will be the key assignment for terminating both polyline stemwall and strip footings.
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Mar 05, 2020 4:46 pm
Version 1.5.7c - 03.05.2020
- Added the "Enter" key method to the strip footing and polyline stemwall draw tools for point selection termination.
After a couple of tries I think I've finally got it right now. One should be able to use the Enter/Return key to terminate point selection as well as still use the down arrow (for users who are in the habit of using the down arrow now). I apologize on the back and forth on this fix, sometimes things just don't go as smoothly as planned.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Apr 28, 2020 2:19 am
Version 1.5.8 - 04.27.2020
- Added a Global Reset button in the General tab of the Global Settings.
- Plugin files switched from .rbs to .rbe encryption.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Fri May 15, 2020 10:52 pm
Version 1.5.9 - 05.15.2020
- Fixed a bug when the Auto Assign Materials parameter was turned off.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu May 28, 2020 8:52 pm
Version 1.6.0 - 05.28.2020
- Added a footing concrete layer in the Global Settings under the "Layers" tab.
- Fixed a bug for metric templates with the strip footing tool and the polyline stemwall tool.
Note, that if you want the footing concrete layer to remain the same as the rest of the foundation (ie. stemwall) you can always assign it to the same layer name: "fnd_conc"
Also note, that any and all of these layer names are user configurable, the names shown are just default names I have assigned, the user can utilized their own naming convention that suites their workflow.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Aug 30, 2020 3:12 pm
After giving this suggestion some additional thought:
I think I will introduce two additional parameters for stemwall foundations which will make them more applicable for use as retaining walls in foundation design.
The two parameters will be:
Ftg. Bar Development: None, Hook, Full Ext., Full Int.
Ftg. Offset: 0.0 in (default)
Currently footings are drawn symmetrically with respect to the foundation wall, this will enable the user to offset the footing in or out (+/-).
3
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Aug 31, 2020 6:28 pm
Version 1.6.1 - 08.31.2020
- Added a footing offset parameter to polyline stemwalls.
- Enabled options for 90 deg. footing hooks for vertical rebar in polyline stemwall.
View model here:
https://3dwarehouse.sketchup.com/model/ ... Foundation
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Oct 10, 2020 5:33 am
Version 1.6.2 - 10.09.2020
- Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby juju » Sat Oct 10, 2020 10:15 am
medeek wrote:Version 1.6.2 - 10.09.2020
your website isn't reflecting the new version yet
User avatar
juju
Premium Member
Premium Member
Postby medeek » Sat Oct 10, 2020 12:20 pm
It should be showing version 1.6.2 now.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby juju » Sat Oct 10, 2020 5:35 pm
medeek wrote:It should be showing version 1.6.2 now.
not yet, and I did press "F5" so the page would load fresh
User avatar
juju
Premium Member
Premium Member
Postby medeek » Sat Oct 10, 2020 5:56 pm
Try it now.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby juju » Sat Oct 10, 2020 6:00 pm
medeek wrote:Try it now.
working now :thumb:
User avatar
juju
Premium Member
Premium Member
Postby medeek » Fri Oct 23, 2020 6:08 am
Version 1.6.3 - 10.22.2020
- Fixed a bug in the strip footing "Outline" edit menu.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: caillou, dongoc, Godrin Grimlock, grypa2000, Hossinh2, mauriciolage, Mercuriel, Not Me and 18 guests
Visit our sponsors:
