[Plugin] [$] S4U Divide
Postby hdpv » Mon Dec 14, 2015 4:56 pm
S4u Divide v1.2.0
-Add French by Pilou
Divide faces follow 2 directions.
Shortcuts key:
- Tab : Toggle X axis ,Y axis
- Ctrl+Click (on Win) OR Alt+Click (on Mac) : Set Origin
- Double Click : Reverse Axis
- After select Match Grid menu:
Ctrl+Click (on Win) OR Alt+Click (on Mac) : Select Source Grid
Click : Select Destination Grid
Trial and Purchase:
http://extensions.sketchup.com/en/content/s4u-divide
Or:
http://sketchucation.com/pluginstore?pln=s4u_divide
suforyou.vn@gmail.com
http://extensions.sketchup.com/en/user/6256/store
My plugins
hdpv
PluginStore Author
PluginStore Author
Re: [Plugin] [$] S4U Divide
Postby pejmantayebi » Tue Dec 15, 2015 5:57 pm
hello hdpv ...
it is not compatible with 2015 !!!
I just 2015 pro , I tried to copy its files from 2016(make) to pro ... but there were some errors about RBE file ... I could not understand what does it mean ...
Just a simple request : please Make it compatible with 2015 ... ( or elder versions if possible )
Please !! :|
thanks a lot for your awesome tools ...
best regards
pejmantayebi
Postby sicksickisck » Tue Dec 15, 2015 7:48 pm
OSOM
sicksickisck
Postby pilou » Tue Dec 15, 2015 8:18 pm
French Language! :)
Rename it as your convenience! :ugeek:
Speedy Galerie
Top SketchUcator
Postby hdpv » Wed Dec 16, 2015 2:31 am
Merci Pilou!
My plugins
hdpv
PluginStore Author
PluginStore Author
Postby cuttingedge » Wed Dec 16, 2015 7:35 am
great useful plugin to speed things up
cuttingedge
Postby hdpv » Wed Dec 16, 2015 1:13 pm
pejmantayebi wrote:hello hdpv ...
Please !! :|
best regards
It's support 2014 and later,now.
My plugins
hdpv
PluginStore Author
PluginStore Author
Postby olishea » Wed Dec 16, 2015 10:10 pm
how does it look on a sphere? or a torus?
oli
olishea
Premium Member
Premium Member
Postby pilou » Thu Dec 17, 2015 1:56 am
Why not? :enlight:
It's strictly the same!
Faces are only more small so reduct the sizes! (Right Click/ Context Menu)
Speedy Galerie
Top SketchUcator
Postby hdpv » Thu Dec 17, 2015 2:49 am
now,it's not support sphere and torus automatic.
You are just modifier by manual.
My plugins
hdpv
PluginStore Author
PluginStore Author
Postby Macho3001 » Tue Dec 29, 2015 8:26 pm
Hi HD!
Great plugin, I have purchased it. Though it would have been brilliant if it could work on organic lofted surfaces as a single face (not multiple faces), so that panelization could be done. It would then be used in conjunction with edges to tubes and joint push pull plugins for generating building skins and facades, and models could be imported into Revit for construction drawings. Is it possible?
Great plugin !! No doubt.
Ar. Nitin Sharma
3DADS
'Leadership, by Design'
3rd Dimension, Architecture Design Studio
Macho3001
Postby hdpv » Wed Dec 30, 2015 7:45 am
Thank Nitin Sharma!
I also want Divide can work on Surface(mesh,sphere,cylinder...)
I think about Revit's divide tool but it's complex.
Maybe I will add a function for surface(1 direction) as a single face.
Cheers
My plugins
hdpv
PluginStore Author
PluginStore Author
Postby bsfranza » Sat Jan 02, 2016 9:29 am
if you make it working with surfaces - even limited in one direction or something like that - that would be super =) !!!
bsfranza
Postby rv1974 » Tue Oct 04, 2016 7:16 pm
is it possible to add random mode (with user defined min\max values)?
rv1974
Return to Plugins
Users browsing this forum: neresnando, riki06 and 12 guests
