3D Truss Models
Re: 3D Truss Models
Postby medeek » Wed Mar 30, 2016 9:51 pm
The gable end truss as shown is structural, just to clarify. I will probably go with what I have shown as modeled unless there are any objections.
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Thu Mar 31, 2016 8:17 am
Six possible end details for a flat truss (Pratt 4 panels), there are probably others but these seem to be the most common:
1.) Mansard w/ Parapet
2.) Parapet
3.) Mansard
4.) Overhang
5.) Cantilever
6.) None
Both Mansard configurations can also have an optional overhang as shown. The Parapet configuration should allow for customizing the thickness of the parapet wall.
View model here:
https://3dwarehouse.sketchup.com/model. ... d2044182ad
This truss type with its many end configurations would work well with an HTML UI, that is the direction I will be going with future user inputs and interfaces since the ability to customize is unlimited.
With the flat trusses I will initially offer both Howe and Pratt with the ability to utilize a low slope or zero slope.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Fri Apr 01, 2016 6:14 pm
Version 1.4.8 - 04.01.2016
- Added Mod Fan common truss type.
- Structural outlookers (vert. & horz.) enabled under advanced roof options for Common (Mod Fan) truss type.
View model here:
https://3dwarehouse.sketchup.com/model. ... 93296cca33
With the addition of the Mod Fan (Triple Fan) the line up of common trusses is complete. I still need to add in raised heels and structural outlookers for some of the configurations.
Theoretically I could add in additional configurations of the Fink and Howe truss types for extremely large roofs but the largest I've ever seen is a raised heel Quad Fink (10/9). Large spans beyond 70'-80' are probably not practical as far as a single span common truss roof. At that point you pretty much go with large flat roofs with interior columns and girders and all steel construction (think Walmart or Cosco).
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sun Apr 03, 2016 7:56 am
Tray truss algorithm:
A more complex algorithm would be required for a non-centered tray.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Mon Apr 04, 2016 8:54 am
Tray Trusses working now I just need to enable gable ends and advanced options:
Note the three large trusses are all 36' span with different tray widths and different web triangulations.
View model here:
https://3dwarehouse.sketchup.com/model. ... 8869f692b6
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Mon Apr 04, 2016 8:04 pm
More configurations:
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Tue Apr 05, 2016 6:24 am
Version 1.4.9 - 04.04.2016
- Added Tray truss type, configurations: (AUTO).
- Metric input enabled for tray truss type.
- Added gable end trusses for tray truss type.
The next truss type I would like to add is the coffer truss but I don't have a lot of good examples or shop drawings of this truss type. Any examples of a coffer truss would be most welcome.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Mon Apr 11, 2016 4:16 pm
Version 1.5.0 - 04.11.2016
- Added Mono Scissor truss type, configurations: (2/2, 3/3).
- Metric input enabled for mono scissor truss type.
- Added gable end trusses for mono scissor truss type.
- Structural outlookers (vert. & horz.) enabled under advanced roof options for Mono Scissor (2/2, 3/3) truss types.
When the raised heel option is selected the pitch of the bottom chord may equal the top chord creating a half vaulted parallel chord truss.
View model here:
https://3dwarehouse.sketchup.com/model. ... c21ec12a3d
Raised heels are also enabled for this truss type, the combination of structural outlookers (vert & horz.) with the raised heel (wedge, slider, vert) makes for some interesting combinations and for some challenging logic/programming in order to get it all right.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Thu Apr 14, 2016 6:55 am
Updating the hip roof module so that an appropriate wireframe is displayed while using the roof positioning tool:
I will roll a revision once I've finished updating all of the rafter roof types with updated wireframes (preview graphics).
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby juju » Thu Apr 14, 2016 8:13 am
thanks!
juju
Premium Member
Premium Member
Re: 3D Truss Models
Postby medeek » Sun Apr 17, 2016 8:12 am
Version 1.5.1 - 04.16.2016
- Added Dutch Gable Rafter Roof (all advanced options enabled).
- Added wireframe (temporary) graphics to the roof positioning tool for rafter roofs.
View model here:
https://3dwarehouse.sketchup.com/model. ... 4bc4c1f1e7
I still need to setup ceiling joists for hip and dutch gable roofs.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sun Apr 17, 2016 8:52 pm
A nested dutch gable roof created with the plugin. The roof is initially generated by creating three dutch gable primitives and then deleting and trimming certain elements. The most time consuming is the creation of the two valley rafters. I think it might be helpful to have some sort of valley rafter tool if I can figure out a good way of doing that.
View model here:
https://3dwarehouse.sketchup.com/model. ... 208c9d93ef
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Mon Apr 18, 2016 5:43 am
Looking at the half hip roof next. Fairly cut and dried but I'm a little undecided how to handle the birdsmouths cut of the hip rafter where it intersects the discontinuity of the gable wall. I will probably use the same birdsmouth cut on the half hip rafters as the other common rafters of the roof.
View model here:
https://3dwarehouse.sketchup.com/model. ... a4e07b9997
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby pilou » Mon Apr 18, 2016 9:58 am
Remember this ;)
Speedy Galerie
Top SketchUcator
Re: 3D Truss Models
Postby medeek » Mon Apr 18, 2016 9:12 pm
Per user request:
Version 1.5.2 - 04.18.2016
- Added energy/raised heels for small span attic trusses (less than 24 ft.), 1 variant: vertical w/ strut.
- Added some additional logic to improve the triangulation of the upper attic of attic trusses.
When I get some more time I will add in slider and wedge raised heel options for the attic truss type but at that moment it is low priority since most users seem to favor a fairly tall raised heel when utilizing it with attic trusses.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Thu Apr 21, 2016 8:47 am
Version 1.5.3 - 04.20.2016
- Added Mono Cathedral truss type, configurations: (2/2, 4/4).
- Metric input enabled for mono cathedral truss type.
- Added gable end trusses for mono cathedral truss type.
- Structural outlookers (vert. & horz.) enabled under advanced roof options for Mono Cathedral (2/2, 4/4) truss types.
- Added Mono Scissor truss type, configuration: (4/4).
View model here:
https://3dwarehouse.sketchup.com/model. ... 05eb1288f9
I manually modeled this truss type about two months ago and I have been meaning to add it in, finally got it done tonight.
Manually created model here:
https://3dwarehouse.sketchup.com/model. ... bfa780ee7f
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby juju » Thu Apr 21, 2016 9:21 am
juju wrote:how's the manual coming along?
juju
Premium Member
Premium Member
Re: 3D Truss Models
Postby medeek » Fri Apr 22, 2016 5:07 am
The plugin is in such a state of flux it doesn't make a whole lot of sense to invest a lot of time into the manual until things stabilize a bit more. The section I originally wrote now needs a complete rewrite.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Fri Apr 22, 2016 5:21 am
Version 1.5.4 - 04.21.2016
- Added a graphical user interface (GUI) for the selection of the truss type in the "Draw Roof Truss" sub-menu.
- GUI can be toggled with previous drop down menu within global settings.
As you can see there is only one global setting at the moment but now that I have the interface and back end properly setup it won't take much to add in a number of other global values. At some point I will probably have enough parameters that I will need to enable some sort of tabbed html front end for the global setting menu.
With html web dialog boxes I am not sure how well they work on a Mac, the whole sync vs. async issue is a real problem for web dialogs and Macs. I only test on a PC so I can't guarantee 100% compatibility on a Mac. So far I haven't had too many complaints.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Fri Apr 22, 2016 8:02 pm
I will probably add in the Barrel Vault and Clerestory truss types sometime next week as time allows however after that I don't really have any specific truss types that need to be added unless someone has one they would like to see added. I guess I'm starting to run out of trusses... never thought I would see that day.
The next area that will probably get some focus is the various hip truss sets. I'm also looking at the dormer module as and a related plugin for wall framing.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Wed Apr 27, 2016 10:10 am
Here is a preview of the Geometry Input (GUI) menu for the upcoming gambrel attic truss.
Notice the preview pane which gives a basic profile of the truss and attic space. I still need to add some dimensions and some other symbols (pitch, bearing walls, etc...) to the preview graphics but it is mostly there and functioning quite admirably.
The GUI is html with javascript and SVG (scalable vector graphics) for the image. The nice thing is that changing any of the inputs will instantly update the dimensions and preview image allowing one to fine tune the truss geometry before proceeding further. For gambrel roofs this ability to adjust the proportions of the roof relative to each other is very important in my opinion. See my previous gambrel study here:
http://design.medeek.com/resources/trus ... study.html
Since the menu is primarily composed of html, javascript and SVG you can actually beta test it external to SketchUp here:
http://design.medeek.com/resources/gamb ... attic.html
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Thu Apr 28, 2016 11:29 pm
Updated screenshot of the gambrel attic menu:
This is getting pretty close to the final form that this menu will take.
It's actually really amazing what can be done with SVG and javascript, definitely not my forte but after this exercise I feel like I can probably construct anything with this combo if required.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby facer » Fri Apr 29, 2016 12:31 pm
Medeek,
Menu works fine.
Do you have a "reset" to return to original values?
The "Max Truss Height" I assume is the red dashed line in the diagram.
To add clarity would a small red dash line after the menu text help?
Seems you are enjoying yourself, keep up the good work.
facer
Premium Member
Premium Member
Re: 3D Truss Models
Postby medeek » Fri Apr 29, 2016 1:08 pm
Version 1.5.5 - 04.29.2016
- Added Gambrel Attic truss type, configurations: (AUTO w/ piggyback trusses).
- Added a graphical user interface (GUI) for gambrel attic geometry input.
A reset button would be useful to return the GUI to the default values. There is still a lot of work to be done with the gambrel attic truss type:
- Advanced Options
- Gable Trusses
- Default or Reset Button
- Metric Input
View models here:
https://3dwarehouse.sketchup.com/model. ... a62628ae95
https://3dwarehouse.sketchup.com/model. ... 04622f194a
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Fri Apr 29, 2016 9:17 pm
With the graphical menus you will notice a slight delay once the "submit" button is clicked. This is to allow for a quick display of a status message, however I'm finding this delay to be annoying and may eliminate it altogether to speed the use of the new GUI.
Also note that with gambrel attic trusses the non-graphical geometry menu is still an option if you turn off the GUI flag in the global settings. For some people this may be easier but I think the new preview pane is a major design asset when it comes to this type of roof.
I'm thinking it might be useful to implement this same type of preview/GUI for regular attic trusses so that one can preview the configuration before committing. Now that I've been down this road once it won't be such a struggle. Most of the other truss types are fairly simple and a preview image is probably not warranted unless the users say otherwise.
I feel that the preview window goes a long way in helping explain what each term is in the input geometry menu but I may also add in some pop up windows (?) that display diagrams or other explanatory notes to help the less educated users.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sat Apr 30, 2016 7:21 am
This is the level of detail I am aiming for with the advanced options for gambrel attic roofs (minus the truss plates):
Notice the structural outlookers with gable end trusses and the prow roof (option). I've got my work cut out for me.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sat Apr 30, 2016 7:57 am
The updated truss yard:
Sixteen different truss profiles currently available within the Medeek Truss Plugin:
- Common
- Monopitch
- Attic
- Scissor
- Tail Bearing
- Dual Pitch
- Bowstring
- Bow Barrel
- Polynesian
- Cambered
- Cathedral
- Tray
- Mono Scissor
- Mono Cathedral
- Gambrel Attic
- Floor (System 42)
View model here:
https://3dwarehouse.sketchup.com/model. ... c27bf7ac9b
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Tue May 03, 2016 11:05 pm
I am wondering how many of your designers/architects/contractors/builders out there have used Open Joist products?
http://www.openjoisttriforce.com/
I was thinking I might add their product line to the Floor Joist/Truss module.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Wed May 11, 2016 9:37 am
Version 1.5.6 - 05.11.2016
- The plugin now automatically checks for updates.
- Option added in Global Settings to adjust frequency of "check for updates" or to disable this feature entirely.
I've also added in the Open Joist (TriForce) floor truss but it is not quite ready for release so I have disabled it until the next version release.
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby JQL » Wed May 11, 2016 11:37 am
Hi again medeek,
I haven't used open joist yet but I will.
The only problem I see with it is that it's idea is very interesting but I think fire regulations don't allow for it to be visible.
I might be wrong in some cases though, so I'm waiting for them to show up in front of me.
Keep up your excellent work!
JQL
Premium Member
Premium Member
PreviousNext
Return to Plugins
Users browsing this forum: BEST_RAUM, kingyun, makigane, nuwuanda, tranhuuhung and 20 guests
