[Plugin] Add Icons [for all SU files on mac]
• Page 2 of 2 • 1, 2
Re: [Plugin] Add Icons [for all SU files on mac]sorry I didn't read your words carefully.
I removed jbb_layers_panel, no more error message in ruby console. however the close/open window issue remains: I paste the code and return JcB::SetWindowSize::Change.set_2_square and return SketchUp ask if I want to save my file no matter yes or no the window is closed I manually re-open the window, continue with up arrow return, window transform forward and backward works fine afterwards. Re: [Plugin] Add Icons [for all SU files on mac]
I've been adding a catch for that as well, so it waits for you to save... got it working for 'Unsaved' just need to add some code for modified ones as well... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Add Icons [for all SU files on mac]here's a test version that hopefully deals with the retina and other v15 issues...
set_square and set_printer should both deal with unsaved models or changes, but you then need to re-select the option... EDIT: removed test file PM me if you can do any testing and I'll send you a rbz... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Add Icons [for all SU files on mac]![]() luxurious way to add icons…nice one! however, the batch command doesnt work for me…i get the loading image, but this process continues forever. Where looks your plugin for, example, "*.skp" files? Else, thanks! oh, i forget : im on Mac 10.7.5, and use Su13 make Re: [Plugin] Add Icons [for all SU files on mac]
cheers, I got sick of waiting for native icons...
this is down to me not using v2013 anymore, and not having the time to go back in time to fix it... In batch mode, it should open a 'Finder' window that lets you look anywhere you want, it is best to target small collections, i.e. if I target 'Downloads' it will try process the 206 files without icons and if any are corrupt files it can crash SU, but I have also done folders with 500+ skps that I've created without any issues...
that is probably the issue, the single mode should work for any SU version, and some people can run batch mode in earlier versions, so it hard to figure out the problem... I'll try to find some time to revisit... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Add Icons [for all SU files on mac]like to donate thru paypal. your add icons plugin works. what is your paypal address. u can pm me. Thanks.
Re: [Plugin] Add Icons [for all SU files on mac]i have to resize the sketchup window size to a square , if i want the thumb nail to be square. otherwise, my thumnails are always with red bands. the square button doesn't work.
also, can you change the red color to white or grey? thanks
Re: [Plugin] Add Icons [for all SU files on mac]Hi sketchuh,
are you still on SU v15 , which version of osx do you run and do you have a retina display? I've been doing some more work on this, but it's not quite ready... can I PM you some test files? john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Add Icons [for all SU files on mac]yes john!
I am using sketchup 2015 on macbook pro retina 2013. and using the latest os system.
Re: [Plugin] Add Icons [for all SU files on mac]actually, when chose the batch mode, almost all other sktechup files would have square thumb nails, only one that is opened has red bands if the viewport is not square.
Re: [Plugin] Add Icons [for all SU files on mac]if you want to change the red to Finder off white, copy/paste this code into 'Ruby Console' and hit Return...
it should work without needing a restart of SU...
Re: [Plugin] Add Icons [for all SU files on mac]thanks, the red is changed.
just want to confirm do i have to resize the window to square in order to have the thumb nail square?
Currently, yes, and I don't know why the 'make square' button only works for some people... It may be because of Retina or system/SU language used... I have another way of doing it automatically, which 'batch mode' uses, but need some time to add it in and test... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Add Icons [for all SU files on mac]Finally SketchUp has added it's own icons for mac with the release of v17...
not the same quality [imho] but it's native and I can finally stop updating this plugin.... john learn from the mistakes of others, you may not live long enough to make them all yourself...
I've been using your plugin for years, thank you very much, John. It's good that SketchUp can make native icon for mac (again) now but I still prefer yours, which has larger resolution. And I think that 'file' frame in the icons SketchUp produce is useless and screen-landscape-consuming. Re: [Plugin] Add Icons [for all SU files on mac]
Hi driven, This plug-in is not working on macOS 10.15 Catalina. Is there a chance that you would like to make a fix? ![]() ![]() Re: [Plugin] Add Icons [for all SU files on mac]The latest MAC OS 'Catalina' does not support ANY current SketchUp version.
I know that SketchUp is working hard to release a new compatible update for version 2019 asap. BUT no earlier versions will ever be made fully compatible. Some might work, so will not - depending on how you use SketchUp etc. So having an old Plugin updated seems to be the least of your worries ! Please complete your User-Profile so we know more details about your setup... TIG
