[Plugin] Add Icons [for all SU files on mac]
Postby driven » Wed Feb 18, 2015 12:15 am
this has been evolving for a long while, but here it is...
I have now added it to the plugin store...
Download
or visit the Plugin Store for a little more info...
If you have any other versions you should upgrade after a manual 'move to trash' of the older files...
The manual deletion is required as I changed a lot of the filenames...
please give feedback, so i can put this to bed, before my wife kills me...
v1.0.2: updated to fix v8 ruby bugs...
changed the Toggling of windows size to enhance the process...
john
driven
PluginStore Author
PluginStore Author
Re: [Plugin] Add Icons [for all SU files on mac]
Postby Dave R » Wed Feb 18, 2015 3:23 am
Excellent work, sir!
Global Moderator
Postby driven » Wed Feb 18, 2015 3:51 am
cheers dave,
don't know why I cant find it in the plugin store yet...
I probably did something amiss loading the details...
I'll chase it up tomorrow...
john
driven
PluginStore Author
PluginStore Author
Postby Dave R » Wed Feb 18, 2015 3:53 am
Go to bed and worry about it when the sun is shining. Or at least supposed to be shining. ;)
Global Moderator
Postby gilles » Wed Feb 18, 2015 10:14 am
I get this loading SU:
Error Loading File jcb_Add_Icon.rb
undefined method `[]' for #<LanguageHandler:0x10ccfca8 @strings={}>
SU V 8.0.14345
gilles
Top SketchUcator
Postby Rich O Brien » Wed Feb 18, 2015 10:41 am
@john
you don't go live until this is green.
it allows you to pull down or publish extensions whenever you wish.
Rich O Brien
Administrator
Postby driven » Wed Feb 18, 2015 2:58 pm
gilles wrote:I get this loading SU:
SU V 8.0.14345
cheers gilles,
I recently changed it to use 'langhandler' for translations, but forgot 'langhandler' changed at v14...
As a test, could you try this from 'Ruby Console'
EDIT: code is now added to v1.0.2...
Add Icon should then work...
john
driven
PluginStore Author
PluginStore Author
Postby driven » Wed Feb 18, 2015 7:43 pm
@gilles
I found a few other v8 issues which I've 'almost' sorted out...
can I PM you another version, when done?
the making of icons is working, but the window resizing [used for improving them] needs a tweak...
john
driven
PluginStore Author
PluginStore Author
Postby driven » Wed Feb 18, 2015 11:33 pm
driven wrote:this has been evolving for a long while, but here it is...
 DOWNLOAD
john
driven
PluginStore Author
PluginStore Author
Postby Rich O Brien » Thu Feb 19, 2015 5:16 pm
Download
john
Rich O Brien
Administrator
Postby gilles » Thu Feb 19, 2015 6:57 pm
The symlink is there but no change, error when loading.
Pm me any version you want to test with SU8. :thumb:
gilles
Top SketchUcator
Postby driven » Thu Feb 19, 2015 7:04 pm
@gilles,
I got v8 back up and running so the new v1.0.2 in the Plugins Store should now work...
can you test it to make sure?
I also have a translation plugin if you want to try it?
john
driven
PluginStore Author
PluginStore Author
Postby gilles » Fri Feb 20, 2015 9:16 am
driven wrote:@gilles,
john
It does not work.
inside jcb_Add_Icon.rb I read: add_icons_on_mac.version = '1.0.1'
gilles
Top SketchUcator
Postby driven » Fri Feb 20, 2015 1:01 pm
gilles wrote:...inside jcb_Add_Icon.rb I read: add_icons_on_mac.version = '1.0.1'
oops... I just re-uploaded, and then downloaded the .rbz to check that it is now the 1.0.2 version...
sorry about that...
john
driven
PluginStore Author
PluginStore Author
Postby gilles » Fri Feb 20, 2015 7:35 pm
Sorry,
Erreur de chargement du fichier jcb_Add_Icon.rb
undefined method `[]' for #<LanguageHandler:0x10bccff4 @strings={}>
Don't pull out your hairs. :mrgreen:
gilles
Top SketchUcator
Postby driven » Fri Feb 20, 2015 7:39 pm
gilles wrote:Don't pull out your hairs. :mrgreen:
I've got quite a lot, and it's working on v8 for me so it's some silly uploading issue...
I'll PM my copy
john
driven
PluginStore Author
PluginStore Author
Postby greatoe » Fri Mar 20, 2015 5:08 pm
For the latest version 1.0.2, I noticed that a solid white colour is added to the backgound of the icon, and if my SketchUp window is not square, red bars will be added to the top and bottom, or left and right of the icon.
The "set window to square" button/function seems not working, I'm on SketchUp 2015 and OS X 10.10.3.
I was using an early version of your script, and was pleased with it while it generates icons with transparent background.
When I wanted to generate an icon, I use a window management tool (named Window Tidy) to set my SketchUp window to nearly (but not exactly) square to have the best icon result.
May I ask for the transparent background back, and get rid of the red bars?
The old version I use was running good, but I do like the batch function of adding icons to Layout files and skm file.
greatoe
Postby driven » Fri Mar 20, 2015 5:31 pm
hi
I added the 'Red' banding so you can quickly see that a 'better' icon is available by using 'Make Square',
I am looking at adding some user preferences that will let you set the band color to any or transparent...
but first, get 'Set Square' working is quite critical...
It may be a locale issue, do you use 'en-US' for SU or other...
if you could run a couple of test's in 'Ruby Console' we can try and work out the issue...
use 'Select All' >> Copy >> Paste in 'Rudy Console' >> hit 'Enter/Return'
Code: Select all
    class  Change
    @plist = (ENV["XPC_SERVICE_NAME"]).split('.')[0..-2].join('.')
    def self.vpw
      Sketchup.active_model.active_view.vpwidth
    def self.vph
      Sketchup.active_model.active_view.vpheight
    def self.win_read
      %x(defaults  read  #{@plist}      "NSWindow Frame SketchUpDoc")
    def self.frame_read
      %x(defaults  read  #{@plist}     "Sketchup.MainFrameSize")
    def self.win_write(arry)
      %x(defaults  write  #{@plist}      "NSWindow Frame SketchUpDoc" #{arry})
    def self.frame_write(hash)
     %x(defaults  write  #{@plist}     "Sketchup.MainFrameSize" -string "#{hash}")
    def self.su_window
      win_read.chomp!.split(' ').map{|e| e.to_i}
    def self.main_frame
      frame_read.chomp!.gsub(/[\{\}]/, '').split(', ').map{|e| e.to_i}
    SUD = win_read.dup.chomp!   if not defined? SUD
    SMF = frame_read.dup.chomp! if not defined? SMF
    @@revert = false if not defined? SUD
type = %x(defaults read com.apple.print.PrintingPrefs DefaultPaperID).chomp!
p Sketchup.get_locale
p @plist
p SUD
p SMF
p [vpw, vph]
p type
nil
this should return your machines version of this...
"en-US"
"com.sketchup.SketchUp.2015"
"189 651 977 526 0 0 1920 1177 "
"{{37, 608}, {977, 569}}"
[977, 473]
"iso-a4"
and hopefully show me what's going wrong...
if you can paste that info back here, that a start...
I'm working on batch mode at the moment as there are issues with versions other than v2015...
john
driven
PluginStore Author
PluginStore Author
Postby greatoe » Sat Mar 21, 2015 1:27 am
hi john,
here's the result:
"en-US"
"73 40 1810 1137 0 0 1920 1177 "
"{{73, 4}, {1810, 1173}}"
[3620, 2124]
nil
ps. I'm on a 15" retina display macbook pro.
greatoe
Postby driven » Sat Mar 21, 2015 1:39 am
cheers,
I think I see the issue, SU shows the 'retina' values but system shows 'traditional' sizes...
in yours this two double...
[3620, 2124]
on mine it stays the same...
[977, 473]
I need to add a check for retina, and will post a test file...
john
driven
PluginStore Author
PluginStore Author
Postby driven » Sat Mar 21, 2015 1:47 am
what does this return on retina...
Code: Select all
UI::WebDialog::new.screen_scale_factor
john
driven
PluginStore Author
PluginStore Author
Postby greatoe » Sat Mar 21, 2015 1:57 am
2.0
greatoe
Postby driven » Sat Mar 21, 2015 2:00 am
greatoe wrote:2.0
excellent...
I'll add that inn
john
driven
PluginStore Author
PluginStore Author
Postby driven » Sat Mar 21, 2015 2:08 am
if you paste the code block below first, then JcB::SetWindowSize::Change.set_2_square
does it 'go' square?
then up arrow in 'Ruby Console' >> return
does it revert?
Code: Select all
=begin
Copyright 2015, john@drivenupthewall.co.uk
All Rights Reserved - for now...
=end
module JcB
  module SetWindowSize
    class  Change
    @scale = UI::WebDialog::new.screen_scale_factor.to_f
    def self.vpw
      Sketchup.active_model.active_view.vpwidth / @scale
    def self.vph
      Sketchup.active_model.active_view.vpheight / @scale
    def self.win_read
    def self.frame_read
    def self.su_window
    def self.main_frame
      def self.default_paper
       ##'shipped' ratios with a few international paper sizes...
       ratios = { 1.0=>'Square', 1.294=>'US Letter', 1.333=>'US Architectural',\
                          1.414=>'A Series (ISO 216)', 1.647=>'US Legal'}
       if type.include? 'Letter'
         ratio = 1.294
       elsif type.include? 'Arch'
         ratio = 1.333
       elsif type.include? 'iso'
         ratio = 1.414
       elsif type.include? 'Legal'
         ratio = 1.647
       else
          prompts = [($add_icon_strngs["Select your Paper Type"])]
          defaults = []
          ratios.map{|k,v| defaults << v }
          choose = defaults.join(',').gsub(',', '|')
          input = UI.inputbox(prompts, [defaults[0]],[choose],  ($add_icon_strngs[" You have no 'default' Printer set "]))
           if input.include? 'Letter'
             ratio = 1.294
           elsif input.include? 'Arch'
             ratio = 1.333
           elsif input.include? 'iso'
             ratio = 1.414
           elsif input.include? 'Legal'
             ratio = 1.647
           else
             ratio = 1
       @ratio = ratio
      def self.process_window
        su_window
        sul = su_window[0] # left top corner
        suo = su_window[1] # left bottom corner
        suw = su_window[2] # width
        suh = su_window[3] #
        mcl = su_window[4] #
        mco = su_window[5] #
        mcw = su_window[6] #
        mch = su_window[7] #
        new_doc = "#{sul} #{suo} #{@new_width} #{suh} #{mcl} #{mco} #{mcw} #{mch}"
        main_frame
        mfa = main_frame[0]
        mfb = main_frame[1]
        mfc = main_frame[2] # width
        mfd = main_frame[3]
        new_mf = "\{\{#{mfa}, #{mfb}\}, \{#{@new_width}, #{mfd}\}\}"
        mod_path = Sketchup.active_model.path
        Sketchup.active_model.select_tool(nil)
        Sketchup.active_model.close_active
        Sketchup.send_action('closeDocument:')
          if not @@revert
            frame_write(new_mf)
            win_write(new_doc)
            @@revert = true
          else
            win_revert
       mod_path != '' ? Sketchup.open_file(mod_path) : Sketchup.send_action('newDocument:')
      def self.win_revert
            frame_write(SMF)
            win_write(SUD)
            @@revert = false
      def self.set_2_print
        default_paper
        @new_width = (vph * @ratio)
        @@revert = (vpw.between?( @new_width - 3, @new_width + 3 ))
        process_window
      def self.set_2_square
        @new_width = vph
        process_window
      class AddIconWindowObserver < Sketchup::AppObserver
        def onQuit
          revert = JcB::SetWindowSize::Change.class_variable_get(:@@revert) || false
          SetWindowSize::Change.frame_write(SMF) if revert
          SetWindowSize::Change.win_write(SUD)   if revert
         # Attach the observer
         Sketchup.add_observer(AddIconWindowObserver.new)
    end # change
  end # module
#  JcB::SetWindowSize::Change.set_2_square
driven
PluginStore Author
PluginStore Author
Postby greatoe » Sat Mar 21, 2015 4:24 am
1) I pasted the code, hit return
ruby console return "True";
2) JcB::SetWindowSize::Change.set_2_square, return
and SketchUp ask me if I want to save my current work;
3) I click "yes"
ruby console return the following:
Error: #<NoMethodError: undefined method `attribute_dictionary' for nil:NilClass>
/Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:189:in `onContentsModified'
if I click "no"
ruby console return:
Error: #<TypeError: reference to deleted Attribute>
/Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:203:in `each'
/Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:203:in `block in onContentsModified'
SketchUp:1:in `call'
then the window of my current work is closed, while SketchUp is still running;
then I click the SketchUp icon on the Dock, a blank/new SketchUp window pops up, which is square.
4) I press up arrow in ruby console then return
the new SketchUp window revert to previous size, but a little different with its position on screen.
greatoe
Postby greatoe » Sat Mar 21, 2015 4:32 am
5) up arrow >> return again
the new blank SketchUp window go square;
the new blank SketchUp window revert its size, but goes to a new position on screen;
I kept doing this, results are same: the new blank SketchUp window do go square and revert, but the position on screen is changing.
greatoe
Postby greatoe » Sat Mar 21, 2015 4:38 am
6) I draw something in the new blank SketchUp window, save the file.
the "square - revert with different position" circle goes on.
7) I close SketchUp, open it again (with and without an existing file), I do 1) and 2), the result is same as 3).
greatoe
Postby driven » Sat Mar 21, 2015 11:35 am
cheers for that comprehensive testing,
Is that the latest version of jbb_layers_panel that's causing the errors?
for some reason it's observers are being triggered by closing and re-opening the SU window...
If you temporarily disable it does this code run without issue?
In Preferences, do you have 'new windows' set to 'cascade'?
If so does after deselecting that does the top corner still move?
I do have a completely different 'new' way of changing the window width, but that also needs more testing...
john
driven
PluginStore Author
PluginStore Author
Postby greatoe » Sat Mar 21, 2015 4:32 pm
the latest version 1.0.2 and a previous version work same;
how to temporarily disable the observers?
yes 'new windows' are set to 'cascade', deselecting this solved the window moving problem
greatoe
Postby driven » Sat Mar 21, 2015 4:46 pm
greatoe wrote:the latest version 1.0.2 and a previous version work same;
I was meaning the version of 'layer panels' it's throwing those errors, if you disable it then it's observers shouldn't run...
I can turn that on and off in code so I'll add it in...
I'd forgotten that dave had that problem on another version...
driven
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: mvm1990 and 18 guests
