Power Toolbar (2.5) - fix for 2019
Re: Power Toolbar 2015 (2.3)
Postby Rich O Brien » Wed Nov 09, 2016 1:05 pm
Ciao Max!
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby CadFather » Wed Nov 09, 2016 1:08 pm
Ciao Rich, hope you're good! : )
Quarr-IT - SketchUp Training from the Master.. http://quarr-it.com/
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby Pherim » Sun Nov 20, 2016 9:57 pm
CadFather wrote:aware of the glitch with extrude and 2017. busy at present, but as soon as i get some time to dive into the code again, i'll post a working update
Great! Looking forward to it!
Pherim
Postby CadFather » Mon Nov 21, 2016 9:35 am
posted a new update - should be working with 2017 (thanks to TIG).
also just to let you know, i hope to be working on a fuller update sometime in the new year.
Cheers
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby Pherim » Mon Nov 21, 2016 10:00 am
Great, thank you!
Pherim
Postby shri » Thu Dec 08, 2016 8:44 am
this plugin makes my work faster..thanks alot
shri
Postby onzki » Thu Jan 19, 2017 8:30 am
LOL, I was too lazy to read! I miss that one. I'll charge this to my Duh moments.
[/hr]Dell Precision T5600. SKU 2018 Pro. AutoCAD 2013. Landscape design firm. Hong Kong
onzki
Postby nickweboffer » Fri Apr 28, 2017 12:40 pm
hi
I have installed and uninstalled several times but the whole powerbar just doesn't show up in my SU 2015. what are my options?
nickweboffer
Postby juju » Tue May 02, 2017 7:38 am
nickweboffer wrote:hi
did you remember to go to View > Toolbars and check that the toolbar is selected?
User avatar
juju
Premium Member
Premium Member
Postby Pherim » Mon Jun 19, 2017 4:04 pm
Hello,
I have a small issue with one of the functions and I wonder if anything can be done about it. It's about the "Equalise Curves" tool, which is very handy in certain situations, but whenever I use it, one end of the curve moves a little. I am only using "Divide by number", not by length, but it happens in both modes. Is it possible to change it so that both ends stay in their original position? Or is there another plugin which can do that? Unlike other tools in this collection, I can't find a corresponding separate plugin for this function. And for example Fredo6's Curvizard can only simplify contours by angle, but not equalise the segments.
Pherim
Postby CadFather » Mon Jun 19, 2017 11:18 pm
Hi Pherim, i'll have a look at it, though that might be a while as i'm away
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby Pherim » Tue Jun 20, 2017 9:47 pm
Thank you! Also, sometimes it does not redraw the curve, but it just disappears.
Then I get this error in the Ruby Console:
Code: Select all
Error: #<ArgumentError: Not enough points - at least 2 required>
C:/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:3841:in `add_curve'
C:/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:3841:in `main'
C:/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:578:in `block in <module:Max_Coppoletta>'
SketchUp:1:in `call'
Pherim
Postby vzynsky » Wed Sep 13, 2017 1:35 pm
JHS powerbar 2.4 + su17! What was the problem? :?
vzynsky
Postby GoodWin_2203 » Mon Apr 09, 2018 2:24 pm
thanks for the wonderful plugin! very useful. I have a problem with the "extrude lines" tool. it does not work correctly. when I specify the height to which you want to squeeze a curved line, it does not squeeze it out, but simply moves it with copying. Do you know why this is so?
GoodWin_2203
Postby majid » Fri Apr 20, 2018 7:49 am
Silly question: Does it work with the latest SU?
My V-Ray book for architects: https://goo.gl/cz1oRc
User avatar
majid
Top SketchUcator
Postby young77 » Thu Jan 31, 2019 8:59 am
Hi…
I have a question about extrude line in JHS Power Bar plugin. I have tried to create a line and select the line, then click on extrude line in that plugin, but it didn’t extruded as seen in youtube tutorial, it was only an offset from first to second point with the same line, there is no any extrusion at all. Please advise me how to correct my steps thanks.
please refers to my link : https://ufile.io/fk7et
young77
Postby valerostudio » Thu Feb 07, 2019 3:20 pm
Will we get support for 2019? It doesnt seem to be installing correctly.
valerostudio
Postby stefanozilio » Fri Feb 08, 2019 9:23 am
Only for Info, I used your bar a lot
Do you have the intension to update it for SU2019?
SZ
stefanozilio
Postby CadFather » Sat Feb 09, 2019 11:06 am
Yes, hope to work on an update sometime soon, time is a bit short but I will.
also if problems, please try to be as specific as possible.
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby CadFather » Sat Feb 09, 2019 11:34 am
ok, try this - a quick fix so it loads. first test seems fine. so let me know if you encounter issues..
later i'll have a proper look at the script and update it properly - thanks
Powerbar Fix for 2019.rbz
5
User avatar
CadFather
PluginStore Author
PluginStore Author
Re: Power Toolbar 2015 (2.5) - update
Postby atelierpaar » Mon Feb 11, 2019 5:39 pm
Hello,
I hope this chat also relates to jhs powerbar.
After intalling SU 2019 I get the following errorcode :
Fehler beim Laden der Datei C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:7367: Invalid return in class/module body
return nil
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in `load'
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in `<module:JHS_powerbar>'
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:7:in `<module:Max_Coppoletta>'
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in `load'
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in `register_extension'
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in `<module:JHS_powerbar>'
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:8:in `<module:Max_Coppoletta>'
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:7:in `<top (required)>'
unfortuantely I have no clou how to fix this.
Any suggestions ?
thanks
Uli
User avatar
atelierpaar
Postby juju » Mon Feb 11, 2019 6:33 pm
atelierpaar wrote:Hello,
return nil
Any suggestions ?
thanks
Uli
Uli, is this with the file provided in the post directly above yours? (see below for quote).
CadFather wrote:ok, try this - a quick fix so it loads. first test seems fine. so let me know if you encounter issues..
User avatar
juju
Premium Member
Premium Member
Re: Power Toolbar (2.5) - fix for 2019
Postby CadFather » Tue Feb 12, 2019 12:15 pm
yes Uli, as Juju said - make sure you have the latest update - i have no errors on my machine
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby stefanozilio » Tue Feb 12, 2019 4:51 pm
Thanks, the bar is going to work in 2019
stefanozilio
Postby valerostudio » Wed Feb 13, 2019 3:49 pm
CadFather wrote:yes Uli, as Juju said - make sure you have the latest update - i have no errors on my machine
Not sure what it could be. I have uninstalled all previous versions, reinstalled the update, it shows up in the Extension Manager as enabled, but no toolbar and the CADFATHER PACK doesn't show up in the Help menu either.
valerostudio
Postby CadFather » Wed Feb 13, 2019 4:06 pm
that's weird - at least if you got an error message - and i take it the location allows full access (not sure on mac)
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby atelierpaar » Wed Feb 13, 2019 9:21 pm
thanks to you all
after a fresh download everything is nice an shiny again
Uli
User avatar
atelierpaar
Postby valerostudio » Mon Feb 18, 2019 3:09 pm
CadFather wrote:that's weird - at least if you got an error message - and i take it the location allows full access (not sure on mac)
I went through all my 2019 plugins folders and made sure to delete everything, re downloaded the fix, and then reinstalled and I do have it working now. Thanks for your help and patience with this. I couldn't live without Powerbar!!!
valerostudio
Postby flyer_50 » Fri Feb 22, 2019 8:53 pm
thanks
working also for me
regars
flyer_50
Postby Dave R » Sun Mar 10, 2019 1:43 pm
Hi Max,
Can you put the latest version in the PluginStore? The one linked to there is out of date.
Thanks.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
cron
Who is online
Users browsing this forum: burkules, danieldckh, Google Bot, rochaeholanda_arq and 15 guests
Visit our sponsors:
