[Plugin] SketchyFFD (Updated 20130203)
Re: [Plugin] SketchyFFD (Updated 20130203)
Postby nguyenanhducarc » Fri Apr 25, 2014 3:55 am
THank you!
i love you.! ♥
nguyenanhducarc
Postby jemoto » Fri May 02, 2014 3:24 pm
Hi all,
I struggle a bit with this plugin; after manipulating the control points and closing the group, I cannot see an "Update FFD" menu item. I believe an earlier poster had the same issue. Can anyone help? Thanks.
jemoto
Postby john2 » Tue Dec 02, 2014 3:06 pm
jemoto wrote:Hi all,
Ditto :!: :!: I am also facing the same problem. I just installed and tried to use this plugin.
john2
Postby PeterF » Thu Jun 18, 2015 6:56 pm
I am having the same problem. I have tried installing every version of the script and there is no 'Update FFD' menu button. The other FFD submenu is there though. I'm using Sketchup Make 2015. Has anyone solved this problem?
PeterF
Postby TIG » Thu Jun 18, 2015 7:19 pm
Install the latest version.
Then, at the risk of déjà vu read: viewtopic.php?p=485421#p485421
It all works from the context-menu - given a suitable selection...
But remember that it is an old creaky plugin, from way back yore...
Global Moderator
Postby PeterF » Thu Jun 18, 2015 7:25 pm
Thanks for the reply. I have tried installing every version and none of them have that button. The rest of the submenu is there like I said, but when you adjust the control points, nothing happens and there is no update button.
Is there a newer plugin that works better than this then? I haven't found another that can twist and warp organic shapes like this one is supposed to.
PeterF
Postby pilou » Thu Jun 18, 2015 10:05 pm
Works perfectly in the 2015! :D
Else you have FredoScale by Fredo6 who makes the same! ;)
Speedy Galerie
Top SketchUcator
Postby PeterF » Thu Jun 18, 2015 10:22 pm
Ok never mind. I installed it again for the 5th time and it works for some reason!
PeterF
Postby Fabtins » Wed Jul 08, 2015 4:58 pm
Fantastic tool sir!
I've just started using it. Its working amazingly well but when i open(double click) the control point group to alter control point locations for deformation, the object i'm working on vanishes leaving only the control points behind. The transformation done is taking place but I only see it on the object after i click close group. Can you help me figure what i'm doing wrong? I've attached the screenshots for reference.
Fabtins
Postby TIG » Wed Jul 08, 2015 5:33 pm
When you edit a Group or Component you can set the rest of the model to be 'hidden', OR not.
See:- View > Component Edit > Hide Rest of Model - toggle it ON/OFF
Sometimes hiding the rest of the model is useful, but sometimes you want to see it - as in this case !
Global Moderator
Postby pilou » Wed Jul 08, 2015 6:07 pm
You can also use the Structure function for easy use of this plugin! ;)
Click on the image for see animation!
Speedy Galerie
Top SketchUcator
Postby TIG » Wed Jul 08, 2015 6:21 pm
Structure [FR] == Outliner [EN]
Global Moderator
Postby muten86 » Sun Jul 26, 2015 10:58 pm
thanks
muten86
Postby bong2x » Mon Sep 14, 2015 8:11 am
thank you for your kindness and brilliant idea.
:thumb:
bong2x
Postby earl » Mon Nov 09, 2015 9:04 am
Im having a problem. i cant find the plugin installed in my sketchup. (SU2013) I already tried intalling the rbz file inside sketchup and pasting rb file in the plugins folder but the plugin wont show up even if i close and open sketchup again. hope u can help me. TY
earl
earl
Postby TIG » Mon Nov 09, 2015 2:30 pm
Why are you messing on with an RBZ ?
This is an old plugin - putting the RB file [latest version] inside the Plugins folder and restarting SketchUp ought to be all you need...
But if you want to use an .RBZ, you must make a .ZIP of the lone .RB and then change its file-type to .RBZ - use Preferences > Extensions > Install Extension... on that RBZ and it's put into the Plugins folder for you...
But have you [re]read the Usage instructions ?
This tool - when properly installed - works from the context-menu, but only when you have a suitable group selected...
Here are its instructions again...
- Create a group with all the geometry you wish to deform. This group should contain just faces and/or lines.
- Right click the group and select one of the options in the FFD submenu. Either 2x2 or 3x3 or NxN FFD. Depending on the size of the model it could take a while (seconds I hope). At the end you should see a new group containing nothing but control points
- Open the control point group and move the control points as you wish. The object should deform as you move the points. NOTE: it can take a long time for complex models. Look at the status bar in the lower left to see the status of the deformation.
Global Moderator
Postby hepf » Sun Jun 19, 2016 7:05 pm
Thank you Chris. I was drawing the half dome of Maxentius basilica, and needed just that.
hepf
Postby ithil » Wed Feb 22, 2017 3:13 pm
Hello
I'm a little bit corrected your plugin
Now It supports polygons.
He checks the creation of new edges. And converts the resulting triangles in polygon.
Strings 534-538
5
ithil
PluginStore Author
PluginStore Author
Postby pilou » Wed Feb 22, 2017 3:51 pm
Cool and seems you mix some other plugins for help it! :)
In the past have only points was a little esoteric! :mrgreen:
But we had only that for deform a volume with powerful!
Speedy Galerie
Top SketchUcator
Postby pilou » Wed Feb 22, 2017 7:20 pm
In the same order of idea !
TGi 3D must be make something similar! ;)
(a free version is existing)
Speedy Galerie
Top SketchUcator
Postby facer » Thu Feb 23, 2017 12:31 am
TGI 3D - Free Version
http://www.tgi3d.com
Note:
Tgi3D SU Amorph Training Edition has the same functionality of Tgi3D SU Amorph, except that it has a limit on the number of vertices to work with. It is still fully functional and will let you experience and appreciate all the features of Tgi3D SU Amorph. Download (Win | Mac)
facer
Premium Member
Premium Member
Postby nickweboffer » Wed Sep 27, 2017 10:10 am
i am running 2016 SU on my macbook air, and the FFD plugin doesn't seem to function. I am missing options in the right-click menu. and when I manipulated the points, nothing happened.
nickweboffer
Postby kaouther alimi » Sat Dec 09, 2017 9:15 pm
Please can you help me to solve this problem..I've downloaded the script but it doesn't work because of 'Unsigned Author'
kaouther alimi
Postby TIG » Sat Dec 09, 2017 10:07 pm
kaouther alimi wrote:Please can you help me to solve this problem..I've downloaded the script but it doesn't work because of 'Unsigned Author'
It's an old plugin.
So it won't be 'signed'.
If you set SketchUp's Extension Loading Policy to be 'Unrestricted', then it should load - always presuming that it's still compatible with the current SketchUp version...
Global Moderator
Postby kaouther alimi » Sun Dec 10, 2017 9:57 am
Thank you for your reply..But the problem still here..Please can you give me a similar plugin to FFD sketchy.It would be really helpfull for me.Thanks for you time
kaouther alimi
Postby pilou » Sun Dec 10, 2017 1:15 pm
There is Vertex Tools by Thomthom
and also Stretch by Aera by Tak2hata
Speedy Galerie
Top SketchUcator
Postby Goodspeeder » Thu Dec 14, 2017 1:54 pm
Once I create the control points, I can't seem to grab or sellect them. Working on a mac if it matters.
Would appreciate any help on this because it looks like an awesome plugin.
FIgured it out.
1. double click ffd control points in outliner window
2. be sure to check unlock edges in right click ffd context window
I'll leave this here on the chance others are having the same issue
Goodspeeder
Postby TIG » Thu Dec 14, 2017 2:14 pm
Goodspeeder wrote:Once I create the control points, I can't seem to grab or select them. Working on a mac if it matters
They are inside a group, so edit the group and you can then select them individually, or multiply holding Shift etc, or by fence etc...
Global Moderator
Postby fusioncraft » Wed Jan 17, 2018 5:34 pm
Hi, I am new to Sketchup and installing plugins and extension.
I'm unable to install the ruby Script in my Shetchup 2016. The plugin isn't loading. I have copied and dragged the file into my Plugins folder. Path - /Users/Praveen/Library/Application Support/SketchUp 2016/SketchUp/Plugins
Looking for some kinda guidance from the community on what I've done wrong
fusioncraft
PreviousNext
Return to Plugins
Users browsing this forum: Anna_Source, Godrin Grimlock, Not Me, shamim674 and 20 guests
