[Plugin] TIG-layer_material_tools
Postby TIG » Fri Dec 05, 2014 6:10 pm
I have updated my own brand-new version of Didier's toolset, which:
Make Materials from Layers and Layers from Materials, and Set Materials from Layers and Layers from Materials.
Version 1.0 is now available from the PluginStore.
Download
Global Moderator
Re: [Plugin] TIG-layer_material_tools
Postby thelorax » Fri May 08, 2015 12:26 am
TIG,
I just wanted to thank you personally for this script. Trimble removed the (use color by layer materials) option from the 3ds export dialog, which breaks a method I've used for moving files between sketchup and max for years now. your script is the only way now to get the layer info into max. I don't know ruby, but I wrote a pretty sweet maxscript for exchanging files between sketchup and max. If you use max let me know.
thanks!
chris
thelorax
Postby Repsaj1975 » Thu Apr 18, 2019 9:56 am
Hi TIG,
This plugin worked fine in SketchUp2017 but in SketchUp2018 it isn't working anymore
Using it to import a dwg
Then making materials from layers
And finally set materials from layer names
Is there al solution?
Repsaj1975
Postby TIG » Thu Apr 18, 2019 3:41 pm
This is an old plugin.
Can you explain how it is 'not working' ?
Errors loading ?
Errors when running ?
If you run it with the Ruby Console open do you see error messages ? etc...
Please give full details...
It works fine for me...
Global Moderator
Postby JanaVS » Thu Sep 12, 2019 12:51 pm
TIG wrote:This is an old plugin.
Errors loading ?
Hello,
I uploaded 2 documents that show in detail how is this plugin working in 2017 version and not working in 2018 version. This is exact the same model that I tested on.
I practically do the same thing in both cases only the results are different.
If you have any idea how can I make this work, please let me know.
Thank you!
JanaVS
Postby TIG » Fri Sep 20, 2019 4:02 pm
It seems to report the changes the same in both versions ?
So can you check the materials actually get made in the 'failing' model.
Also can you check in it, what material should be associated with an object on a layer - and what Entity Info says it has...
What are your View / Style settings ?
Are there differences between these in the two SketchUp versions ?
Can you post an example SKP that I can test...
You didn't seem to run it with the Ruby Console open ?
Any error messages ?
Global Moderator
Return to Plugins
Users browsing this forum: ajojingonly, kalamae and 7 guests
