[Plugin] S4u Make Face
Postby hdpv » Thu Oct 23, 2014 2:14 am
S4u Make Face v3.0.2
-Support Sketchup 2016 Signed Extension Policy.
-Language : Français,Espagnol,German
S4u Make Face v3.0.0
Fix Bug
link download:
http://sketchucation.com/pluginstore?pln=s4u_MakeFace
http://extensions.sketchup.com/en/content/s4u-make-face
S4u Make Face v2.0.0
-Optimization
-Espagnol language.
S4u Make Face v1.0.0
Select edges for Make Faces
Automatic exclude edges that its won't make face.
link download:
s4u_makeface_v1.0.0.rbz
5
hdpv
PluginStore Author
PluginStore Author
Re: [Plugin] S4u Make Face
Postby Oxer » Thu Oct 23, 2014 4:00 pm
Thanks for the plugin, here the Spanish Language
es.zip
http://www.oxervision.blogspot.com/
Oxer
Postby Krisidious » Thu Oct 23, 2014 4:18 pm
SCHWEEEET!
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby pilou » Thu Oct 23, 2014 9:54 pm
Does this normal?
Removal is not automatic : you must Press the Key Delete function?
Speedy Galerie
Top SketchUcator
Postby Box » Thu Oct 23, 2014 11:23 pm
Pilou I think you'll find it's just slightly incorrect wording.
The plugin automatically retains the selection of the loose edges so they can be easily deleted.
It would actually be counterproductive in many cases if the edges were automatically deleted without giving you a choice.
3
Postby JQL » Thu Oct 23, 2014 11:31 pm
Box wrote:Pilou I think you'll find it's just slightly incorrect wording.
That is one of the features that makes this different from any other plugin for face making I know of...
Well done!
JQL
Premium Member
Premium Member
Postby hdpv » Fri Oct 24, 2014 2:36 am
Thanks Oxer! I will add it new update version.
Hi Pilou! My word is incorrect.
"That is one of the features that makes this different from any other plugin..." is my mind. :)
hdpv
PluginStore Author
PluginStore Author
Postby ideas_arte » Fri Oct 24, 2014 4:02 am
Oxer wrote:Thanks for the plugin, here the Spanish Language
es.zip
¡Muchas gracias Oxer!
ideas_arte
Postby JQL » Fri Oct 24, 2014 8:49 am
hdpv,
I noticed there's no menu entry for this plugin. Is this true? Can you make one?
I'm asking for this as it would be great to assign a shortcut to the tool...
Thanks,
João
JQL
Premium Member
Premium Member
Postby hdpv » Fri Oct 24, 2014 9:15 am
Hi JQL!
Menus PLugins>> Suforyou >> Make Face
I have update the s4u_MakeFace 2.0.0
-Optimization
-Espagnol language.
hdpv
PluginStore Author
PluginStore Author
Postby JQL » Fri Oct 24, 2014 9:20 am
Nice!
JQL
Premium Member
Premium Member
Re: [Plugin] S4u Make Face v2.0.0
Postby ken » Fri Oct 24, 2014 1:08 pm
OK, downloaded the new version, V2.0.0. Was testing the plugin. Now after the installation, if I use the plugin, Sketchup has bug splat after closing. And installing this plugin was the only operation in Sketchup I have done this morning. If I open Sketchup and do not use this plugin, Sketchup closes correctly.
As for an error code, none displayed. Just the Bug Splat form as shown.
Note the prior version did not cause a bug splat.
Houston we have a problem.
Ken
ken
Premium Member
Premium Member
Postby Box » Fri Oct 24, 2014 3:38 pm
Yep, I can confirm what Ken says, it is a repeatable bugsplat.
Postby hdpv » Fri Oct 24, 2014 4:10 pm
Hi all!
I have post the version 1.0.0 while i find this error.
hdpv
PluginStore Author
PluginStore Author
Postby mokhtar » Wed Nov 26, 2014 9:06 am
First, Thanks so much for you job on plugins HDVP, really all the plugins that you did so amazing and very useful :).
Second, I wanted to ask you about a problem in S4U MakeFace 2.00 because really i can't resolve it, I don't why it don't make all the edges and just some edges like its appear in the attachment ?
mokhtar
Postby Box » Wed Nov 26, 2014 11:11 am
At a guess it looks like you are trying to work at too small a scale.
If the piece is very small the faces can't form.
Try scaling up by 10 and trying again.
Postby hdpv » Thu Nov 27, 2014 2:03 am
@mokhtar : Can you post your sketchup file?
hdpv
PluginStore Author
PluginStore Author
Re: [Plugin] S4u Make Face v3.0.0
Postby hdpv » Mon Apr 27, 2015 4:50 pm
Update s4u MakeFace v3.0.0
FixBug crash Sketchup!
hdpv
PluginStore Author
PluginStore Author
Postby Esense3d » Mon Apr 27, 2015 8:44 pm
Thank You
German Language File
Esense3d
Postby pilou » Fri May 29, 2015 1:19 am
French UI ;)
Speedy Galerie
Top SketchUcator
Postby hdpv » Fri May 29, 2015 1:59 am
Thanks! I will add soon!
hdpv
PluginStore Author
PluginStore Author
Postby Pherim » Tue Nov 24, 2015 5:00 pm
I get an error on loading with the newest version on SU2016, both when installed via Extension Store and manually:
Error Loading File s4u_makeface/s4u_makeface_loader.rb
Could not find included file 's4u_makeface/s4u_makeface_loader.rb'
Pherim
Postby pilou » Tue Nov 24, 2015 5:38 pm
Works with any problem! Loaded by the first post file on the 2016! :D
S4u Make Face v1.0.0 + Free Visualizer + SU IVY
Speedy Galerie
Top SketchUcator
Postby TIG » Tue Nov 24, 2015 5:47 pm
The author needs to change his files and remake the RBZ [v3.0.1] and get it re-signed/republished...
The base-level 's4u_makeface.rb' which sets up the extension has a path set for the extension's loader to be:
BUT that file does NOT exist !
There are two files added by the signing process:
's4u_makeface/s4u_makeface_loader.rbe'
's4u_makeface/s4u_makeface_loader.rbs'
If the base-level 's4u_makeface.rb' were to say:
's4u_makeface/s4u_makeface_loader'
it will work - however, editing this file manually breaks the signing hash!
So v2016 won't like it unless it's running in 'Unrestricted' mode.
So it must be done by the author and re-signed.
This is a typical error caused by the new and unfortunately half-baked v2016 signing process which has been introduced.
An author testing his code with all .RB files in the subfolder will find it works, but making the RBZ with them included and then signing it, will then fail unless the specified loader path is left 'open ended' - i.e. it does not include a file-type suffix, and IF the author chooses any encryption at all - i.e. RBS or RBE - because only unencrypted RB files will work.
The new signer does not allow a mixture of RB and encrypted files [that used to be possible].
Also [at least at the moment] the signer perversely allows the author to add both types of encrypted files [RBS and RBE] into the same signed RBZ - although RBS works in ALL SketchUp versions anyway and publishing in RBE only protects the author's IP when there is no RBS version out there... ill-advisedly shipping them together means any 'hacker' can easily see inside the RBS anyway, and compromise the RBE's encryption.
Of course, publishing only RBE means the extension won't work in anything other than >=v2016 !
Also, if the signed RBZ includes encrypted files, then it may currently not be exempt from malicious tampering !
If someone were to [ill-adisedly] add their own 's4u_makeface/s4u_makeface_loader.rb' file that would NOT break the signing hash check in v2016, AND if the loader looks for an open-ended path [with no file-type specified], then the RB will load instead of the encrypted versions and this could do something wicked [it's RB/RBE/RBS load-order, with mo check on the signed/hashed files - at the moment ! ] - but of course unless you stupidly got the RBZ from an iffy site it should all be OK - but that's more to do with the source being trustworthy - like EWH or the SketchUcation PluginStore - rather than the RBZ being signed, which unfortunately on its own could offer only illusory assurance...
Global Moderator
Postby pilou » Tue Nov 24, 2015 5:51 pm
In fact I had loaded the V 1 and not the V3 from the first post!
Else I have the same error message when I load the V3! :oops:
Speedy Galerie
Top SketchUcator
Postby hdpv » Wed Nov 25, 2015 5:46 am
Thanks ALL,
I fixed it.
Please try again!
hdpv
PluginStore Author
PluginStore Author
Postby Pherim » Wed Nov 25, 2015 8:12 am
Thank you! :thumb:
Pherim
Postby pilou » Wed Nov 25, 2015 9:54 am
Now works fine! V 3.02 :fro:
Speedy Galerie
Top SketchUcator
Postby TIG » Wed Nov 25, 2015 2:19 pm
BUT now the RBZ is no longer signed, and the two files inside it are no longer encrypted.
That RBZ will only work under v2016's 'Unrestricted' policy.
If you are happy to leave the files as RB, it still needs signing.
But if you have published in error then you need to tidy up your subfolder, in code inside the loader RB ? to delete those now rogue RB files in the subfolder, because otherwise these will remain in the subfolder after the new version is installed AND the older RB files will load in preference to any RBS in there !
That's also because you now have an open-ended file-path [no file-type suffix] in the loader RB...
Global Moderator
Postby hdpv » Thu Nov 26, 2015 2:35 am
TIG wrote:BUT now the RBZ is no longer signed, and the two files inside it are no longer encrypted.
Sorry! I don't understand this.
hdpv
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: rhande and 7 guests
