[Plugin][$] S4u_Transformer
Postby hdpv » Fri Sep 26, 2014 4:05 am
S4u_Transformer v1.1.0
Select groups or components for Transformer(Scale,Move,Rotate,Color)
Trial and Purchase : http://extensions.sketchup.com/en/conte ... ransformer
Video tutorial:
http://youtu.be/oWnmTdX43C0?list=PLfw9P ... _7AiXmTiue
hdpv
PluginStore Author
PluginStore Author
Re: [Plugin$] S4u_Transformer v1.0.0
Postby JQL » Fri Sep 26, 2014 10:54 am
Breathtaking...
JQL
Premium Member
Premium Member
Postby Krisidious » Fri Sep 26, 2014 7:18 pm
I have no idea what I would do with it... But I like it.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby pep75 » Fri Sep 26, 2014 8:17 pm
One of the best plugins for Sketchup in years!!
pep75
Postby smuncky » Fri Sep 26, 2014 9:10 pm
wow! this is touching into rhino territory.
smuncky
Postby hdpv » Sat Sep 27, 2014 3:07 am
Thank all!
it's the same a game :)
hdpv
PluginStore Author
PluginStore Author
Postby Box » Sun Sep 28, 2014 8:31 pm
It's a great plugin but it has the annoying persistent toolbar problem. Could you look at adjusting it for your next update.
TIG wrote:
If an author has made his tool's loading code 'unfriendly' it will always open its toolbar, even if you last exited with that toolbar closed...
For example if a plugin has the overly simple code:
tb.show
Which always opens the toolbar, irrespective of your wishes !
To open a toolbar only if the user previously exited with it open [OR it's the first time it's used, e.g. a new installation] the loader code needs adjusting to read something like:
tb.show if tb.get_last_state.abs == 1 # TB_VISIBLE/NEVER
Which is the code used by the SketchUcation toolbar...
Postby Stinkie » Sun Sep 28, 2014 9:21 pm
Wow. :thumb:
Stinkie
Postby hdpv » Mon Sep 29, 2014 2:19 am
Box wrote:It's a great plugin but it has the annoying persistent toolbar problem. Could you look at adjusting it for your next update.
tb.show
maybe on Mac,on Win is no problem
I fix for next update,
hdpv
PluginStore Author
PluginStore Author
Postby Box » Mon Sep 29, 2014 7:25 am
I don't have a mac.
Postby hdpv » Mon Sep 29, 2014 8:00 am
i don't know this error,but this code is OK
"tb.show if tb.get_last_state.abs == 1"
hdpv
PluginStore Author
PluginStore Author
Postby Box » Mon Sep 29, 2014 8:28 am
I know nothing about coding so I gave you a quote from Tig when the issue came up before.
I just wanted to point out that your Plugin's toolbar was always popping up whether open or closed previously. I've just installed and tested your Slice plugin and it doesn't do it, so that suggest there is a difference in the code.
I don't mean this as a criticism, simply a bug fix.
Postby hdpv » Mon Sep 29, 2014 9:19 am
no difference in the code.I use Sketchup 2014,win64
this bug fix is no expect. :)
hdpv
PluginStore Author
PluginStore Author
Re: [Plugin][$] S4u_Transformer v1.0.0
Postby HornOxx » Fri Oct 24, 2014 11:51 am
hi HDPV,
first thank you for this great tool!
I have used it for some time and it worked great so far, but since a few days I get the message
that I should do an update as soon as I use the plugin (please see screenshot). This is the only plugin that causes this error by now.
I run SketchUp 2013 Pro and SketchUp 8 Free on Win7 64bit. I get this message on both versions.
any help is appreciated - thank you
never trust a skinny cook
HornOxx
Postby hdpv » Fri Oct 24, 2014 12:13 pm
Sorry HornOxx, This trial is expired.
hdpv
PluginStore Author
PluginStore Author
Postby Dave R » Fri Oct 24, 2014 12:20 pm
hdpv wrote:Sorry HornOxx, This trial is expired.
Could you change the wording in the message? That message doesn't indicate at all that the trial period has expired and that the user needs to pay up or discontinue the plugin. Perhaps you could change the message to something like, "Thank you for trying S4u_Transformer. The trial period has ended. Please go to [your website] to purchase the a license."
Global Moderator
Postby HornOxx » Fri Oct 24, 2014 12:36 pm
Sorry - how embarrassing to me!! ;-) I didn´t even notice that this is a purchase-plugin.
Regards to All
HornOxx
Postby hdpv » Fri Oct 24, 2014 4:13 pm
Thanks Dave!
hdpv
PluginStore Author
PluginStore Author
Postby Berserk » Fri Jul 14, 2017 7:39 am
This is incredible
Berserk
Postby pipinek » Sun Jun 16, 2019 12:13 am
To the Author (S4U).
Should it be any discount, upgrade price for the v1 users?
If yes how can one apply it?
pipinek
Premium Member
Premium Member
Postby hdpv » Mon Jun 17, 2019 8:49 am
Now,the update is free.
Mail to me if you purchased it.
hdpv
PluginStore Author
PluginStore Author
Postby rv1974 » Thu Oct 31, 2019 11:38 am
Hdpv, Say I have multiple components, some of them have scale -1 (=mirrored) on some axis, some do not. Is there way to take only those with scale -1 and flip it to 1?
Thank you
rv1974
Postby hdpv » Mon Nov 04, 2019 9:08 am
Hi rv1974!
s4u Transformer can't do it.
You try this code:
sel=Sketchup.active_model.selection
axis=[0,5,10]
s=sel.group_by{|e| e.transformation.to_a[axis.z]>0}.values[0] # you can change axis.x or axis.y
sel.clear
sel.add s
hdpv
PluginStore Author
PluginStore Author
Postby rv1974 » Mon Nov 04, 2019 9:59 am
Hdpv thanks for reply!
I tried the code- nothing happens. what am I doing wrong?
Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
<main>:4:in `add'
<main>:4:in `<main>'
SketchUp:1:in `eval'
rv1974
Postby hdpv » Tue Nov 05, 2019 8:21 am
First,You select all components.
hdpv
PluginStore Author
PluginStore Author
Postby rv1974 » Tue Nov 05, 2019 2:51 pm
IDK I select all and ... no magic happens
Sometimes I have no reply in Ruby console, sometimes diffrent errors.
In any case nothing flips to original
axis=[0,5,10]
sel.clear
sel.add s
<main>:4:in `add'
or
<main>:4:in `add'
Error: #<SyntaxError: <main>: syntax error, unexpected ':', expecting end-of-input
Error: #<TypeError: wrong argument ...
rv1974
Postby hdpv » Wed Nov 06, 2019 10:44 am
You change axis.z to axis.x
axis=[0,5,10]
s=sel.group_by{|e| e.transformation.to_a[axis.x]>0}.values[0] # you can change axis.x or axis.y
sel.clear
sel.add s
After,you use s4uTransformer with center origin and ratio scale x_axis: -1
hdpv
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Nov 06, 2019 1:42 pm
:o Wow! You are my hero! You see 3ds Max hates negative scale entities and it causes huge PITA.
May I humbly ask you to shape it as .rb?
And if you could merge with 'Reset Transformer' as one new script it'd be amazing.
Many thanks for assistance.
rv1974
Return to Plugins
Users browsing this forum: anishaabasnet, blww74, dezmo, kosugi123456789 and 26 guests
