[Plugin][$] S4u_Slice
Re: [Plugin][$] S4u Slice
Postby hdpv » Sat Apr 25, 2015 4:55 pm
hdpv
PluginStore Author
PluginStore Author
Re: [Plugin][$] S4u_Slice_v3.0.0 (update 25 April 2015)
Postby bsfranza » Sun Apr 26, 2015 9:53 am
awesome plugin!!!!
keep up the great work!
bsfranza
Postby Esense3d » Mon Apr 27, 2015 8:31 pm
Hello
Can not try (expired) but Translate to German
Esense3d
Postby cotty » Sat Jun 13, 2015 8:38 am
Very nice plugin!
One suggestion: a one-click-undo for the slicing would be nice.
cotty
Top SketchUcator
Postby hdpv » Sat Jun 13, 2015 9:26 am
Thanks!
I use Ctrl_Z for undo.
hdpv
PluginStore Author
PluginStore Author
Postby pilou » Sat Jun 13, 2015 1:37 pm
French version! ;)
Speedy Galerie
Top SketchUcator
Postby pilou » Tue Jun 30, 2015 8:17 am
Sure i can make an horizontal Detach or cut more! but... :)
Speedy Galerie
Top SketchUcator
Postby hdpv » Mon Jul 06, 2015 2:18 am
my slice is very sharp,it can detach a face to 2 faces. :)
This is special case.I will try fix it.
hdpv
PluginStore Author
PluginStore Author
Postby Bob James » Fri Sep 09, 2016 12:45 pm
S4USlice is enabled and activated but when I try to use it I get the License Expired error.
Extension Warehouse lists it in my extensions as enabled.
This is the second time I've gone through this rain dance :(
What's wrong this time?????
Purchased From:
Trimble Navigation Ltd.
TIN# 94-2802192
Netherlands VAT # NL003257447B01
Billed to:
________________________________________
Robert James
4159 Constellation Road
Lompoc
CA, 93436
United States
Order Details:
Order Confirmation Number: 636688
Transaction Date: July 2, 2015 3:08:30 AM EDT
Vendor Web Store: HUYNH DUONG PHUONG VI
Your order includes the following items:
Qty Item No. Description Unit Price
1 x ea643527-4b89-45da-a8f6-c79994cd15e3 s4u Slice 3.3.1 $9.00 US
Bob James
Premium Member
Premium Member
Postby hdpv » Sat Sep 17, 2016 4:00 pm
Sorry! Sketchup checks the license.
I don't know this error.
hdpv
PluginStore Author
PluginStore Author
Postby Bob James » Sun Sep 18, 2016 11:38 am
hdpv wrote:Sorry! Sketchup checks the license.
Are you going to attempt to find out? It would be nice if an extension I paid for would not be identified as expired.
Bob James
Premium Member
Premium Member
Postby hdpv » Mon Sep 19, 2016 2:59 pm
You try uninstall then reinstall.
http://help.sketchup.com/en/article/3000264
Your licenses is not expired.
or If you want install and active by manual(not on Extension WareHouse) i will send the file *.rbz to you.
hdpv
PluginStore Author
PluginStore Author
Postby Bob James » Tue Sep 20, 2016 4:02 pm
Extension Warehouse identifies Slice as enabled, but when used Slice is shown as expired.
Seems like the only thing left to do :D
Bob James
Premium Member
Premium Member
Postby rv1974 » Thu Feb 02, 2017 1:27 pm
Hdpv, would it be possible to add a 'multi-point' (not just by 2\3 points we have now) cutting mode?
rv1974
Postby ithil » Wed Jun 07, 2017 9:52 am
Hello!
Many thanks for your plugin.
I'm just happy with him =)
My work accelerated even more.
ithil
PluginStore Author
PluginStore Author
Postby srx » Sat Sep 02, 2017 8:21 am
Hi. Congratulation on making one of the most useful Sketchup plugins.
I have an idea to make it twice time useful :)...simply by adding inverse function. So it could not only trim SU geometry, but also extend it using the same logic in picking 2 point lines, faces or 3 point faces...
Even more useful would be possibility to select a few faces, or curved surface as an "edge" for trimming, or extending.
It would be powerful feature.
www.saurus.rs
srx
Postby makro88 » Thu Aug 29, 2019 6:16 pm
Hi, I've just purchased this extansions but after 3-4 inputs where it works correctly, it says "S4u_slice is not yet Activated. Do you have the Activaiton file?"
Any solution?
edit:
I'm in touch with the developer, he's being super helpful.
Apparently it's an issue linked to the extension warehouse, as I cannot use it within sketchup (it appears to be offline)
makro88
Previous
Return to Plugins
Users browsing this forum: Arleon, dboymuthafuqa, fredo6, piyushbarve06, shiwawa2020, WelyssonFW and 13 guests
