[Plugin][$] S4u_Slice
Postby hdpv » Mon Sep 22, 2014 5:22 am
S4u_Slice
Slice,Cut,Detach objects -Set plane by 2 points , 3 points or by Object -Add section faces .Create Group Section.
- Set plane by 2 points, 3 points or by Edge,Face,Guide line,Axis
- Add section faces
- Select Objects and Section Plane for Create Group Section
(Put Create Group Section in the new layer and show only in the selected Screen)
Shortcut:
Ctrl (Alt on Mac) > Lock Zaxis
Alt (Control on Mac) > Set plane by Object
Tab > Change cut side
Shift > Lock Section Plane
https://www.youtube.com/playlist?list=PLfw9P5m29pNSVVyM_IFwyfUcsLQNQB_Ux
7
hdpv
PluginStore Author
PluginStore Author
Re: [Plugin] S4u_Slice_v1.0.0 (update 22 Sep 2014)
Postby Krisidious » Mon Sep 22, 2014 7:38 am
:thumb:
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby function » Mon Sep 22, 2014 10:48 am
ah great! this is like super-zorro. the detach also feature is also very clever
S4u_Samurai
function
Postby hdpv » Mon Sep 22, 2014 11:53 am
Thanks,
Samurai is nice name, :)
hdpv
PluginStore Author
PluginStore Author
Postby chris87 » Mon Sep 22, 2014 1:04 pm
Load error (sketchup 8 pro) :
Erreur de chargement du fichier E:/3D/SKETCH-UP-PRO-8/Plugins/s4u_slice/s4u_slice_menu.rb
(eval):418:in `require': compile error
(eval):251: syntax error, unexpected ')', expecting '='
(eval):418: syntax error, unexpected kEND, expecting $endErreur de chargement du fichier s4u_slice.rb
chris87
Postby pilou » Mon Sep 22, 2014 2:28 pm
From the video seems the volumes resulting not "solid" ! ?
Top SketchUcator
Postby hdpv » Mon Sep 22, 2014 3:24 pm
Thank Chris87! I have fixed it,try again
Hi Pilou!
It's only add line on face,no solid.
hdpv
PluginStore Author
PluginStore Author
Postby chris87 » Mon Sep 22, 2014 4:17 pm
hdpv wrote:Thank Chris87! I have fixed it,try again
Hi Pilou!
Thank you.....it works fine now !
Great plugin !!!
chris87
Postby g.moggel » Mon Sep 22, 2014 8:14 pm
hi
trying this with a fairly complex model where zorro always fails. will report back.
its really awesome and promising. tried it out in a small file with a few components inside groups and other components - a lot of nesting - and it works fine.
thx so far.
mo
g.moggel
Postby hdpv » Tue Sep 23, 2014 2:24 am
Good news,Mo!
I like Zorro but sometime it's cause crash sketchup.
so I make this plugin
hdpv
PluginStore Author
PluginStore Author
Postby pbacot » Tue Sep 23, 2014 3:28 am
testing in Mac
Error Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/s4u_slice/s4u_slice_menu.rb
undefined method `instance_variable_defined?' for S4U:ModuleError Loading File s4u_slice.rb
Top SketchUcator
Postby hdpv » Tue Sep 23, 2014 3:59 am
Hi Pbacot!
i'm not yet testing in Mac but this error is from ruby function.
You can test this version
hdpv
PluginStore Author
PluginStore Author
Postby pbacot » Tue Sep 23, 2014 6:05 am
Great. Thanks! This seems to work on the Mac--as I understand the plugin so far.
Top SketchUcator
Postby pilou » Wed Sep 24, 2014 12:24 pm
Cool one! :)
Ps Don't work very well with cylinders! ;)
Random Painter By Chris Fullmer (not sure that it's works in 2014! :roll:
Exploded View by CPlassais / Pilou
Top SketchUcator
Postby within » Thu Sep 25, 2014 7:31 am
Would be great "Cap hole" option after "cut" and "detach". Excellent plug-in! Thanks!
within
Postby pilou » Fri Sep 26, 2014 11:08 am
Done for the Slice 2.0 ;) Soon released!
:thumb: :fro:
Just a question : when you slice a volume in 2 parts A & B
How choice to keep B ? In your video you keep A ;) (minute 0.10)
Edit : found! Just draw the line slice from top to bottom or bottom to Top !!!
Excellent! :ugeek:
Top SketchUcator
Re: [Plugin$] S4u_Slice_v2.0.0 (update 27 Sep 2014)
Postby hdpv » Sat Sep 27, 2014 7:49 am
Thank Pilou for review!
I have updated s4u_Slice v2.0.0
hdpv
PluginStore Author
PluginStore Author
Postby sumaster » Sat Sep 27, 2014 6:29 pm
HI Su for you,
thank you . . . . . . . :) :thumb: :thumb: :thumb:
Thank you,
SUmaster
sumaster
Postby balci58 » Sun Sep 28, 2014 1:20 pm
perfect plugin, thank you hdpv. Great work!
balci58
Re: [Plugin][$] S4u_Slice_v2.0.0 (update 27 Sep 2014)
Postby g.moggel » Fri Oct 03, 2014 5:57 pm
this really is amazing. i tried some more and i can say bravo. shut up and take my money. seriously though where can i buy and when will the trial expire?
i have a huge model and trying to slice it in one piece makes su crash. but taking larger groups by groups its working amazingly well. thanks soooo much. all the best.
mo
g.moggel
Postby hdpv » Sat Oct 04, 2014 1:09 am
hdpv
PluginStore Author
PluginStore Author
Postby deaneau » Tue Oct 07, 2014 6:28 am
hdpv wrote:Thanks Mo!
Please send paypal: suforyou.vn @ gmail.com 7$ to get it.
Hello hdpv,
what do you think about, to write the minimum donation price in your plugin´s info?
this will help SketchupUsers (professional or hobbyist) to calculate and find important infos faster.
thank you Dean
MADE, BORN AND LIVING IN BERLIN
Big Thank You to all Programmers
Some German words are so long that they have a perspective. M.Twain
deaneau
Postby hdpv » Tue Oct 07, 2014 9:13 am
Hello Dean!
According to me ,there is no minimum donation.
This plugin is for sell .This price is definite after trial.(~7$)
hdpv
PluginStore Author
PluginStore Author
Postby deaneau » Tue Oct 07, 2014 2:42 pm
hdpv wrote:Hello Dean!
sorry i need new glasses, in the first tread you have have written the price.
looks useful, is v1.0 payware,too?
tnx Dean
deaneau
Postby dtrarch » Tue Oct 07, 2014 6:56 pm
Just a super plugin and well worth the $7. :thumb: :thumb: :thumb:
SuperZorro 4u
dtr :)
dtrarch
Premium Member
Premium Member
Postby hdpv » Wed Oct 08, 2014 10:56 am
Thanks Dave! :oops:
@Dean
v1.0 is no exist :)
If you like it ,send to your mail.
hdpv
PluginStore Author
PluginStore Author
Postby JClements » Wed Oct 08, 2014 3:19 pm
I suppose if this could be adapted to be non-destructive to the original geometry (it wouldn't do any slicing), then user could draw quick section planes.
JClements
Premium Member
Premium Member
Postby hdpv » Thu Oct 09, 2014 2:20 am
I think that is like RichSection plugin and Slap plugin.
My plugin is like Zorro,to be destructive to the original geometry.
hdpv
PluginStore Author
PluginStore Author
Postby mejlgren » Mon Jan 05, 2015 10:17 pm
Just installed s4u_slice more than one time and it keep saying "please update new version".
What is wrong?
Best regard
John
mejlgren
Postby hdpv » Wed Jan 07, 2015 9:08 am
Hi John!
Sorry,link on SketchUcation store had expired.
You have to install (trial or purchase) direct from Sketchup: Menu - Windows -> Extension WareHouse
http://extensions.sketchup.com/en/content/s4u-slice
hdpv
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: dinomvasconcelos, Flysurfer, fredo6, hafza jamshaid, parkmijung, tranmyduyen and 15 guests
