by gnome_mo » Wed Feb 14, 2018 1:18 pm
Pants wrote:Fredo,
Hope you got time for this, because it feels so close...anyway, can you confirm that you're able to make up new stencils and have them work as "punches?" I've found this only works for me if I use your "stock" three sample stencils - the ones you provided as defaults. It lets me pick a new shape that turns yellow and shows all signs of being ready to make a hole, but when I double-click, or try to "orient," etc...no hole results...just a "time elapsed" display.
I also have some Sketchucation plugins-vs-extensions issues/possible confusion. Plugin manager shows current 2/4 version. Later, after finding I was still having problems, I noticed the SUcation Extensions manager still showed the old version (now disabled). I keep thinking there's a need to delete/uninstall old versions, not just disable. Apparently one can disable a plugin and still find that it shows up as the old version, active, but in the SUcation extensions manager. Confusing, to me, anyway.
Mahalo - Dave
I have the very same problem. Haven't managed even all default shapes, circle yes and polygon yes, but rectangle doesn't drill. Neither does my shape. (Rougly - looks like letter "T"). I'm trilling through a floor made of 700 planks. Pants, did you manage to drill yours?
gnome_mo
- Name: gnome_mo
by pilou » Wed Feb 14, 2018 1:42 pm
With any image or file it's difficult to say something!  Else I see no dificulties to make some drills on floors, walls etc... Just select before your objects then call the crazzy VisuHole!  One of my favorite when you can't use Boolean function who don't existing on the Make Versions!  Here all object is a Group, and view Front Face (will be the same if wall was a floor ! So from View Top) GIF8VISUVISU.gif Will be of course the same if the form was a "T"  the_same_T.jpg
- Top SketchUcator
- Name: Pilou
- Operating system: Windows
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: hobby
- Level of SketchUp: Advanced
by gnome_mo » Wed Feb 14, 2018 2:25 pm
gnome_mo
- Name: gnome_mo
by pilou » Wed Feb 14, 2018 2:44 pm
With a file its' very more easy to answer! Always post a file is the Golden Rule! It's because your objets are not VOLUMES!!! They have no bottom!  They are not homogeneous! It's more difficult for VisuHole! Your objets must be "manifold" without space between us! So draw them "pasted" like my drawing above then use VisuHole then Exploded view" X,Y!
- Top SketchUcator
- Name: Pilou
by gnome_mo » Wed Feb 14, 2018 3:10 pm
I didn't think that was the problem, since it drilled simple circle, no problem. But I really need those spaces between them, is it at all possible?
gnome_mo
- Name: gnome_mo
by pilou » Wed Feb 14, 2018 3:15 pm
Seems you can't! GIF_nono.gif But if you draw a rectangular box between the 2 existing that will works!  So not a big deal if you know that from the beginning!  Just erase the "Joint(s)" at the end!
- Top SketchUcator
- Name: Pilou
by pilou » Wed Feb 14, 2018 3:25 pm
- Top SketchUcator
- Name: Pilou
by jeff1harmed » Wed Apr 24, 2019 5:25 pm
I downloaded and installed VisuHole_v1.4b. I got random results on curved surfaces, and frequent crashes on SU2017. Great potential but unrealised in my case and I had to uninstall
jeff1harmed
- Name: Jeff Dahmer
- SketchUp version: 8
- SketchUp use: woodworking
by TIG » Wed Apr 24, 2019 6:15 pm
Did you also install the latest Lib Fredo ?
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
by kochmichi86 » Tue Oct 08, 2019 11:05 am
I have a problem with trying to bend small letters (1cm) on a cylinder as the picture shows in the attachement. Could anyone help ?
kochmichi86
- Name: Michael
- Operating system: Mac
- SketchUp version: 2019
- License type: Pro
by TIG » Tue Oct 08, 2019 7:04 pm
No attachment !
If your object is too small, then SketchUp can't cope. Points closer that 1/1000" - as might be created by your tiny sizes and processes - are deemed to be coincident. Then the tiny edges aren't created and their faces are also lost !
Try Scaling things up x10 or more and see if that helps ??
- Global Moderator
- Name: TIG
- License type: Pro
by ACWN » Fri Feb 07, 2020 8:02 pm
For some reason I'm having trouble making a stencil. It seems that when I attempt to make a multi-shaped stencil (such as to drill 4 holes of equal size and spacing through a tube), I cannot select the group. Or, if I'm able to, it does not correctly make the stencil.
I've attached the most recent stencil I'm trying to make. The goal is to punch out the holes and leave behind what would be a frame. Yes, I now realize I can go about it a different way, but my problem with making a stencil still stands and I need to know if its something I'm doing thats incorrect or what. So to that end, I've also included a clip of what I'm doing to make the stencil and the results.
So this current stencil is already 60' tall, so it should be large enough but as you can see in the clip, it doesnt trigger like it should.
Can someone tell me whats going on? Thanks!
ACWN
- Name: Daniels
- Level of SketchUp: Beginner
by pilou » Fri Feb 07, 2020 10:57 pm
Hello You must click a single face or a group or a component of something planed to the XY axes for make a stencil!  Can be of course at any z but must be // to xy plane! So your vertical one is impossible! GIF_horizontal.gif
- Top SketchUcator
- Name: Pilou
by fredo6 » Fri Feb 07, 2020 11:38 pm
Actually, you can pick the stencil in any plane, which is given by the face you click.
But don't click-drag, when you do that. Just click-release
fredo6
- PluginStore Author
- Name: Fredo6
- SketchUp version: 2018
- License type: Pro
- SketchUp use: interior design
by pilou » Fri Feb 07, 2020 11:53 pm
Cool!  So I was half wrong!
- Top SketchUcator
- Name: Pilou
by ACWN » Sat Feb 08, 2020 1:15 am
fredo6 wrote:Actually, you can pick the stencil in any plane, which is given by the face you click.
It doesnt show it very well, but I was actually doing just that right at the beginning of the video. Right around 12 - 14 seconds, when I put the mouse to the center of the group and suddenly get the demo shapes. If I click-release, nothing happens. Uploaded a new movie to show. However when I flip it so its laying flat like Pilou says to, I get it right away.
ACWN
- Name: Daniels
by fredo6 » Sat Feb 08, 2020 11:40 pm
When the stencil is based on a group or component, I was lazy to assume that the Z axis was to be sued as the plan for the stencil. I made a change in LibFredo6 v9.5f to treat more general cases. Fredo
fredo6
- Name: Fredo6
- License type: Pro
- Robot
Return to Plugins
