[Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, Emboss)
• Page 2 of 3 • 1, 2, 3
Re: [Plugin] VisuHole - v1.1a - 19 Oct 14 (Drill, Carve, EmbNEW RELEASE: VisuHole v1.2a - 04 Feb 15
VisuHole 1.2a fixes a major bug preventing to drill when the cursor is positioned on a Guide line, Guide point or Edge over the target face. See main post of this thread for Download of VisuHole. Fredo
Re: [Plugin] VisuHole - v1.2a - 04 Feb 15 (Drill, Carve, EmbSuper! Works very fine on Guides Line, Guides points!
![]() No news for a Gizmo size just before drawing the Stencil ? ![]() But something is always wrong on the edge sides! ![]() Works on the edges as soon as there is a little angle! ![]() But when pararall not! ![]()
Re: [Plugin] VisuHole - v1.2a - 04 Feb 15 (Drill, Carve, Emb@pilou
The problem for border edges is different. It deals with the fact that the stencil is usually partially outside of the shape. VisuHole only accepts to drill if the pivot point is inside the shape. No I need to fix that as well. Fredo PS: for the Gizmo, it is on my list. VisuHole is actually not a finished plugin, but I don't know when I will resume work on it.
Re: [Plugin] VisuHole - v1.2a - 04 Feb 15 (Drill, Carve, EmbThanks, Fredo...I look forward to punching with surgical precision.
Aaaaaaaaaaaaaah! Damned! Un effet collatéral! ![]() ça progresse, ça progresse! ![]()
Re: [Plugin] VisuHole - v1.2a - 04 Feb 15 (Drill, Carve, EmbFredo,
Hope you got time for this, because it feels so close...anyway, can you confirm that you're able to make up new stencils and have them work as "punches?" I've found this only works for me if I use your "stock" three sample stencils - the ones you provided as defaults. It lets me pick a new shape that turns yellow and shows all signs of being ready to make a hole, but when I double-click, or try to "orient," etc...no hole results...just a "time elapsed" display. I also have some Sketchucation plugins-vs-extensions issues/possible confusion. Plugin manager shows current 2/4 version. Later, after finding I was still having problems, I noticed the SUcation Extensions manager still showed the old version (now disabled). I keep thinking there's a need to delete/uninstall old versions, not just disable. Apparently one can disable a plugin and still find that it shows up as the old version, active, but in the SUcation extensions manager. Confusing, to me, anyway. Mahalo - Dave Re: [Plugin] VisuHole - v1.2a - 04 Feb 15 (Drill, Carve, EmbDave,
I would need to have your model with - the shape to drill - the set of faces to be used as a stencil. That would help me to troubleshoot Fredo
I just PM'd you...thanks - Dave Re: [Plugin] VisuHole - v1.3a - 13 Nov 15 (Drill, Carve, EmbHi to every one, only to mention that the last version of visuhole(1.3a) crashed in sketchup 2016 last version for mac and the way to replicate the issue is this:
1. Make a cube 2. Make a little circle to use with drill option 3. Put the circle at the corner vertex of the cube to make some kind of chamfer effect by clicking twice (to fix position and establish the axis). 4. Make the procedure number 3 one more time in another corner vertex of the cube and... that's it!, sketchup 2016 (last ver.19913 for mac) completely crashed and bugsplat appears. To be sure that the problem isn't for incompatibility with another plugin, I disabled all other stuff before test the plugin and the same thing occurred. Anyway, the whole collection of fredo6 plugins are the best I have seen, I know this is only a stupid bug that could be fix it soon... Thanks for your wonderful work and the spectacular plugins you do guys. My Machine: ************ Macbook pro (mid-2012) with OS X El Capitan 10.11.2 8GB RAM 1GB Nvidia 650gt 512GB SSD Re: [Plugin] VisuHole - v1.3a - 13 Nov 15 (Drill, Carve, EmbHello Fredo
No progress in this domain ? Will be fine for Grooves with complex path! ![]()
Re: [Plugin] VisuHole - v1.3a - 13 Nov 15 (Drill, Carve, EmbPilou,
That would be a different plugin, because groove have a 3D shape in general. I think sdmitch has done something already. Fredo
Re: [Plugin] VisuHole - v1.3a - 13 Nov 15 (Drill, Carve, EmbGrooving (edge extruding) is for sure in Top of the most missing features (among true curves,saving in background, and multiple curves as one profile path for example). None of existing scripts is close to workable level (say, comparable to JPP)
Re: [Plugin] VisuHole - v1.3a - 13 Nov 15 (Drill, Carve, EmbI am having problems with this program in drilling more that one hole. I have a pair of 4x4x1/2 angles next to each other, 1" apart. I mark each hole location with a guide point. I can make one hole, but cannot make any other of the holes.
I would like to mark all the holes, like 10 to 20 and just run down the line drilling holes into the angle at each guide point location. Things I have tried. 1. guide points in and out of group selection and using a line end to mark the locations. 2. Separte groups selected or grouping both angle group in one large group. 3. If I click on the "Recurse from..." selection after each hole I can continue making one another hole. After this new hole I need to click on one of the "Recurse from..." to make another hole. 4. Note, if I make a the second selection that is not on a guide point I can make a hole, but I cannot make two selections using the guide points as reference. Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] VisuHole - v1.3a - 13 Nov 15 (Drill, Carve, EmbKen,
Could you post the model. I am not sure I understand well, so it will help me to figure out. Many thanks Fredo
Re: [Plugin] VisuHole - v1.3a - 13 Nov 15 (Drill, Carve, EmbFredo
OK, here is the model. It has four version of the angles. 1. Blue is the two angles 1" apart 2. Yellow is the angles with a guide line and guide points where the holes are to be drilled 3. Red is the failure, after one hole on the guide points. 4. Green is what success should looks like. I can continue making holes if I keep selecting the "Recurse...." option. If I don't do the re-clicking of the "Recurse..." button, I never get the blue bonding box of a group, just the ghost lines. With the ghost lines I cannot make another hole. Hope this help. Fight like your the third monkey on Noah's Ark gangway.
OK. Got it. and it makes a lot of sense. Just a bug I will fix. Thanks for signaling. Fredo
Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, EmbNEW RELEASE: VisuHole v1.4b - 12 Oct 17
VisuHole 1.4b is a miantenance release: - fix a problem where pre-selection was lost after an operation - certified SU2017 - Support of Hi-res screen - compatibility OSX High Sierra Note: v1.4a, published also on 12 Oct had a bug left. So better take v1.4b The fix for Pre-selection concerns a bug signaled by Ken. See main post of this thread for Download of VisuHole. Fredo
Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, EmbThanks you Fredo. It works just like I need.
Short story. I have had this plugin on my computer for sometime, I never could get it to drill consistance holes. So I started this new project and I have way to many holes to drill holes as I have been doing. So I made a concerted effort to learn the plugin. I knew the problem was with me, because no one else was complaining. Than I found one of my problems, the "group in" and "group out". Didn't quite understand what was happening there. Figured that out and watch the video over and over. Trying to see the exact setup in the menu. The other times I just gave up, had stuff to do. But this time I just kept at it. Then I found the post about guidelines and guide points. Then I knew it should work with more that one guideline or point. So now I knew I wasn't the problem. I am grateful for all of your plugins. Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, EmbJuste un souhait qui n'est peut-être pas réalisable : est-il possible que VisuHole n'explose pas les courbes, arcs et autre cercles, et ainsi ne pas perdre les inférences et autres renseignements disponibles dans "Info sur l'entité" ? D'avance merci. Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, Emb
Not obvious, but I'll think of it in a next version. Fredo
Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, EmbBonjour Fredo, et merci d'avoir bien voulu prendre ma demande en considération, mais sachez que ce n'est pas une obligation, mais simplement une suggestion, surtout qu'il est possible de ressouder manuellement ces arcs et cercles, pour retrouver facilement, par inférence, leur centre par exemple (très utile, entre autre, pour la cotation).
Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, Embcutting crossing window\polyline would be amazing spin-off. Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, Emb
And on top of that, it does a chamfering of the intersection! ...and keep everything as a solid! what else?
Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, Embactually when I thought for 2nd time (after first wows!) I realized it hardly can be a precise tool- not so suitable for archviz (my case). could be good for conceptual doodling.
hehe don't you start.. from 31m00s- grooving ![]() or even better: Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, EmbI feel like playing in the schoolyard when seeing these videos.
Must be a trick, because the first time I played with Blender, I gave up after 2 hours and never came back.
Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, Embwell after watching those ones I have rough idea what indians felt seenig gunned conquistadors on horses for a first time
![]() Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, EmbI have some some great uses for this plugin in my modeling, thanks. But when using Drill thru with nested components I get expected results. When using carve I do not see the colors of the nested components. To see the colors I would need to go clean up the model. Is this to be expected with this plugin or operator error? Top model in my example has been cleaned up.
Yes, when the carving has the same size that the component, you need some cleanup of the thin faces left over by VisuHole. Unfortunately, the intersection in Sketchup is not always predictable for these special cases, and also, since components are separate, you may not want the cleanup. Fredo
Re: [Plugin] VisuHole - v1.4b - 12 Oct 17 (Drill, Carve, EmbThanks for all your plugins and your support!
Users browsing this forum: camilobeltran98, chnaydgdu and 20 guests
