[Plugin][$] VisuHole - v1.4b - 12 Oct 17
Postby fredo6 » Sun Sep 21, 2014 4:50 pm
# Permission to use this software for any purpose and without fee is hereby granted
# Distribution of this software for any purpose is subject to:
# - the expressed, written consent of the author
# - the inclusion of the present copyright notice in all copies.
REQUIREMENTS:
  • LibFredo6: v12.4a or above
  • Sketchucation ExtensionStore: v4.2.3 or above (for licensing)
  • Usage: Licensed under Sketchucation SCFLicense
    • Free Trial period (full features): 30 days from first usage
    • Perpetual license (3 seats): $12
    • Part of Fredo6Bundle2022 license (8 plugins): $40
Please UPGRADE to this latest version 1.4 if you run SU 2017.
VisuHole VisuHole is a suite of interactive tools dedicated to holes and extrusions on planar and curved surfaces. In the current version, VisuHole supports the following tools:
VisuHole can drill through one or several surfaces, including when embedded in groups or components. The scope of the selection can be specified implicitly or by pre-selection. A few additional options are available:
  • Material assignment: you can choose or pick a material in the model for painting the extrusions, tubes and stamped shapes
  • Grouping, with 2 modes:
    • GROUP IN for putting extrusions in groups in the selection context
    • GROUP OUT for putting all extrusions and tubes in a master group, without altering the original selection
  • Follow Surface for Carve and Emboss on curved surfaces, allowing to respect the shapes relative dimensions (versus Projection mode, where they would be distorted)
VisuHole - User Manual - English - v1.0 - 19 Sep 14.pdf
  • SU Version: SU6 and above
  • Language: English, French
    (thanks to all kind translators)
  • Menus: by default, it is installed in Tools > Fredo6 Collection > VisuHole
  • Icon toolbar: by Default ‘VisuHole’. One icon available for Stencil
  • The plugin is free, for private and commercial usage. There is a donation menu however.
There are now multiple ways to install scripts
- SCF Plugin Store (SU8 and SU13) - recommended method
- Unzip (all SU versions and for installations in an alternate Plugins directory)
- Extension Manager with RBZ files (SU8 and SU13)
Whatever way you install, you must end up with the following footprint:
The standard SU Plugins root directories are:
Windows SU8: C:\Program Files\Google\Google SketchUp 8\Plugins
Windows SU13: C:\Program Files\SketchUp\SketchUp 2013/Plugins
Windows SU14: C:\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
Mac SU8: Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/Plugins
Mac SU13: ~/Library/Application Support/SketchUp 2013/SketchUp/Plugins
Mac SU14: ~/Library/Application Support/SketchUp 2014/SketchUp/Plugins
CAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.
VisuHole can be installed in any directory, not just the Sketchup standard directory. Doing so will allow you to automatically share the same plugin version if you have several versions of Sketchup installed, and to avoid the security right restrictions for copying files to the system folders on Windows (like C:\program files). Just always make sure that the plugin folders and files are located in the same place as LibFredo6.rb.
See AdditionalPluginFolders for more information.
If you run SU8, SU13 or SU14, the strongly recommended installation method is to Autoinstall with the SCF Plugin Store tool.
Otherwise, you can download the VisuHole rbz file from the Plugin Store page for VisuHole.
IMPORTANT: Requires to download LibFredo6 7.8 or higher if not already installed
Note for SU6 and SU7 users, download the rbz file from the plugin store page, and change its extension from .rbz to .zip
Then:
1) Open the zip archive
2) Select All (Ctrl A)
3) Extract into the Sketchup Plugin Directory
4) Answer YES to OVERWRITE all existing files if any
5) Make sure you get the correct footprint (one rb file and one folder)
STENCILS
The object used for drilling or extruding is called a STENCIL. This is actually a set of 2D shapes, with or without holes.
In the current version, Stencils must be picked in the model. To enter the Pick Stencil mode, click on the button in the palette or press TAB. The main buttons palette will disappear. When you move the mouse on faces and components, a small axis system is displayed. The blue axis shows the direction for 2D projection (on faces it is simply the face normal).
  • Click on a Face or on a group / component to pick the stencil.
  • Click and Drag to pick and orientate the X axis
INFLUENCE OF SELECTION
If the picked face is at top-level (i.e. not embedded in a group or component), then the selection is taken as all connected faces. Note that by pressing CTRL, you can restrict the selection to the picked face or picked surface.
If the picked face belongs to a group or component, then the selection depends on the options selected in the button palette:
TOOLS and GENERAL PROCEDURE
The VisuHole tool can be selected in the button palette, along with their options:
Setting the direction of projection: by default it is the normal to the picked face. You can however impose a direction, either an axis or a custom normal (as in MoveAlong or DrawAlong). For custom direction, mouse over a face and either type ENTER or LONG-CLICK. Once the Z-axis is set, the other axes in X and Y are computed by default.
You may also set the Material options and Group options (see details later in this chapter).
Then, to execute the operation,
  • Either double click on a face
  • Or Click–Release–Move–Click–Release or Click-Drag-Release to set a different orientation of the X and Y axis.
Once the operation is executed, you can either proceed with another operation or modify the settings for the current operation. If you change any parameter in the buttons palette, the button “APPLY CHANGE” will be enabled. When pressing this button, VisuHole will undo the operation and redo it again with the new settings.
DRILLING
You can drill holes with or without tubes, and with edges or Guide lines
STAMPING
You can Stamp, Punch or Mark. The shapes are printed on the front faces.
CARVING / EMBOSSING
Carving and Embossing are controlled by an offset and a few options related to the direction of extrusion and flattening it.
By combining these options, you can create platforms in terrains
VisuHole 1.4b – 12 Oct 17: preserve the preselection across operations, certification SU 2017, support of hi-res screen, compatibility OSX High Sierra. There was still a bug in v1.4a
VisuHole 1.4a – 12 Oct 17: preserve the preselection across operations, certification SU 2017, support of hi-res screen, compatibility OSX High Sierra
VisuHole 1.3a – 13 Nov 15: maintenance release
VisuHole 1.2a – 04 Feb 15: fixes a major bug preventing to drill when Guide lines, Guide Points or Edge are over the target face.
VisuHole 1.1a – 19 Oct 14: release for support of non-ascii usernames in SU14
VisuHole 1.0a – 21 Sep 14: initial public release
14
fredo6
Premium Member
Premium Member
Re: [Plugin] VisuHole v1.0 - 21 Sep 14 [in Construction]
Postby cotty » Sun Sep 21, 2014 4:55 pm
Fantastic plugin! It deserves a donation and the award "plugin of the year".
Thank you!
5
cotty
Top SketchUcator
Re: [Plugin] VisuHole v1.0 - 21 Sep 14 (Drill, Carve, Emboss
Postby pilou » Sun Sep 21, 2014 5:18 pm
Yup a new cool one! :fro:
Top SketchUcator
Postby xiombarg » Sun Sep 21, 2014 10:21 pm
This is huge. Another must have.
-Mechanical engineering. Easy placement of connecting holes for interlocking or hinged elements. Any kind of embedded socket, hex nuts, washers, etc.
-Decorative elements that have repeating patterns. Interior design, ceramics, tiled ceilings, jewelry...
-Quick and easy panel lines.
xiombarg
Postby function » Mon Sep 22, 2014 3:24 am
mega
function
Postby feixia1127 » Mon Sep 22, 2014 3:41 am
Yup a new cool one!
feixia1127
Re: [Plugin] VisuHole - v1.0 - 21 Sep 14 (Drill, Carve, Embo
Postby Oxer » Mon Sep 22, 2014 2:05 pm
Incredible plugin!! :thumb:
I have done the Spanish Translation but there are some strings missing in the language file:
• Current Stencil
• Next Stencil in History
• Previous Stencil in History
• Pick a Stencil Shape in the Model
VisuHole_ES.lang.zip
http://www.oxervision.blogspot.com/
Oxer
Postby fredo6 » Mon Sep 22, 2014 2:46 pm
Oxer,
Thanks a lot. Actually, part of the strings are in LibFredo6.
Fredo
fredo6
Premium Member
Premium Member
Postby Oxer » Mon Sep 22, 2014 3:43 pm
I know it, I have uploaded the new Spanish Language for LibFredo6 v6.1a but these are missing strings to translate in VisuHole:
Code: Select all
• "Current Stencil"
• "Next Stencil in History"
• "Previous Stencil in History"
• "Pick a Stencil Shape in the Model"
• "PICK A STENCIL SHAPE"
• "Pick a Stencil Shape - Click / Release to pick or Click / Drag / Release to pick and orientate - Ctrl down to Force faces - Esc to cancel"
Oxer
Postby fredo6 » Mon Sep 22, 2014 4:18 pm
Oxer,
There seems to be a small problem, maybe for because of the '/'.
Still I was able to translate these strings to French. So I need to clarify.
Fred
fredo6
Premium Member
Premium Member
Postby Oxer » Mon Sep 22, 2014 4:23 pm
Thanks for the reply!
Oxer
Postby AcesHigh » Tue Sep 23, 2014 2:41 pm
Awesome, I will try as soon as I can.
Quick question before downloading it: saw the first minutes of the tutorial video... when moving the stencil shape over the surface you want to apply the stencil, it seems the stencil is "grabbed" by it´s middle.
Is it possible however to for example, move a stencil by it´s corner, and then position it precisely somewhere?
AcesHigh
Postby pilou » Tue Sep 23, 2014 3:34 pm
Yes of course! :enlight:
When you select a new stencil you choose its own origin and even its orientation! ;)
And when you draw it on the volume again position and orientation (on the volume) are possible! :ugeek:
A must indeed! :fro:
Top SketchUcator
Postby cotty » Tue Sep 23, 2014 5:44 pm
Is it possible to get the result in the back (one step) if you place the drill shape at a border?
cotty
Top SketchUcator
Postby fredo6 » Tue Sep 23, 2014 7:56 pm
cotty wrote:Is it possible to get the result in the back (one step) if you place the drill shape at a border?
Just make the rectangle a little bit higher. With exact dimensions, VisuHole has difficulty because it does know the original border faces stay.
Fredo
fredo6
Premium Member
Premium Member
Postby yiannis76 » Thu Sep 25, 2014 7:29 pm
I can not use this plugin.Whetever i try to do i get the attached error
yiannis76
Postby cotty » Sat Sep 27, 2014 8:04 am
Is it possible to snap the stencil shape (drill thru) to guide points, guide lines? Or to use the normal inference system for positioning the hole?
cotty
Top SketchUcator
Postby pilou » Sat Sep 27, 2014 10:55 am
You can yet with this little trick and if your face volume is Parallel to one axe! :idea:
Draw your guides lines crossing anywhere you want
Then call the Stencil and Press one of the the Keyboard Arrow (so x, y, z axis)
The snap will be fine on the crossing guides lines! ;)
Curiously don't work with a Guide Point on the surface but Yes if the Guide Point is on the empty space! :o
So put the Guide Point on Guideline(s) who will be itself on the surface volume! :)
Edit : seems you cant draw your stencil on any position on the space of one Guide Line!
So no need to press the Arrows'keys! :)
But not on their intersection! Even Drawn a Point Guide at the intersection first! :o
All must be on the surface of the volume! :ugeek:
Guide line(s) + Point Guide
Top SketchUcator
Postby optimaforever » Sat Sep 27, 2014 5:23 pm
WWWWWWWonderful script indeed! :D
optimaforever
Premium Member
Premium Member
Postby numerobis » Tue Sep 30, 2014 10:30 am
:ecstatic:
Fantastic plugin! (as usual ;) ) Thank you very much! :thumb:
numerobis
Postby pilou » Wed Oct 01, 2014 11:14 am
We have yet the rotation :thumb:
but...
... does this is possible ? :)
Will be very smart! :)
And a Gizmo with separated scale X, Y, Z super smart! :enlight:
Top SketchUcator
Postby Whaat » Thu Oct 02, 2014 7:08 pm
Congrats Fredo! Another great release! I am looking forward to playing with this one... :thumb:
Whaat
PluginStore Author
PluginStore Author
Postby Elibjr » Tue Oct 07, 2014 9:04 pm
Fredo this looks amazing! I can 't wait to play with this one!
Elibjr
Premium Member
Premium Member
Re: [Plugin] VisuHole - v1.1a - 19 Oct 14 (Drill, Carve, Emb
Postby fredo6 » Sun Oct 19, 2014 11:49 pm
NEW RELEASE: VisuHole v1.1a - 19 Oct 14
VisuHole 1.1a is required for the support of usernames with non-ascii characters in Sketchup 2014
See main post of this thread for Download of VisuHole.
Fredo
fredo6
Premium Member
Premium Member
Postby MALAISE » Mon Oct 20, 2014 5:04 pm
Once more time, awsome tools. :D MALAISE
MALAISE
Postby reboot05 » Wed Jan 21, 2015 1:45 pm
This is an awesome plug-in, thank you! I have one question, if for example I punch a hole in a component it seems to make that component unique and doesnt make that change to what were instances of the original component. It cant see to find if there was an option to make the change to all instances of the component. Other "typical" changes on components are working properly. Am I doing something wrong? Or have some preference set wrong?
Thanks again!!
reboot05
Postby fredo6 » Thu Jan 22, 2015 1:19 pm
reboot05 wrote:This is an awesome plug-in, thank you! I have one question, if for example I punch a hole in a component it seems to make that component unique and doesnt make that change to what were instances of the original component. It cant see to find if there was an option to make the change to all instances of the component. Other "typical" changes on components are working properly. Am I doing something wrong? Or have some preference set wrong?
Thanks again!!
You have the choice
1) If you are outside the component, only the component selected is affected (and thus is made unique)
2) if you are inside the component, then all instances will be affected.
Fredo
fredo6
Premium Member
Premium Member
Postby skogen75 » Sat Jan 31, 2015 7:36 am
Just found this...awesome indeed. Any tips on how to position the drill on guide points or lines? The stencil seems to disappear when I hover over a guide cross or guideline that intersects a face. I would love to know how to accurately place the drill. Very cool. I'm using SU15.
skogen75
Postby Pants » Wed Feb 04, 2015 1:32 am
skogen75 wrote:Just found this...awesome indeed. Any tips on how to position the drill on guide points or lines? The stencil seems to disappear when I hover over a guide cross or guideline that intersects a face. I would love to know how to accurately place the drill. Very cool. I'm using SU15.
+1.
I think this is what <pilou » Sat Sep 27, 2014 10:55 am> was describing (along with a workaround?) and if so, I don't get his results, or just don't understand exactly what he was suggesting to do the workaround.
I can NOT get it to punch through any semblance of guidelines, pencil-lines, etc. The stencil disappears as soon as it infers an intersection point - though yes, arrow-keys seem to bring it back as per previous post, but...still...there's no punching going on. Yes, I can punch to my heart's content if I just "get random" with it, but I'm trying to hit precise measurements, not do an art piece where measurements don't matter.
Fantastic capabilities, but for me...entirely hamstrung by this flaw. Help!
Downloaded today with Sketchucation plugin store - Downloads: 3037 [ Version Updated: 2014/10/19 ]
Pants
Postby fredo6 » Wed Feb 04, 2015 11:47 am
Thanks for signaling.
I normally fixed this ennoying problem in version 1.2a, now available on the PluginStore
Fredo
fredo6
Premium Member
Premium Member
Next
Return to Plugins
Users browsing this forum: celinemia, ianbslvr, junnani, morock21, renobest and 21 guests
