[Plugin] GKWare Stair Maker
Re: [Plugin] GKWare Stair Maker
Postby Garry K » Sat Jan 10, 2015 12:12 am
Version 1.0.23 is now available.
Garry K
Premium Member
Premium Member
Postby pbacot » Sat Jan 10, 2015 2:25 am
Thanks Garry. Impressive plugins!
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby Esense3d » Fri Jan 30, 2015 2:03 pm
Hello Garry
First Your server is on Limit
I cant buy your great Stair plugin
but i can translate for you to German
Need little help with the following Strings
What exactly does:
Progressive Flare
Flare Count
The current translation is complete except for these strings
Greetings from Swiss
Roland F
Esense3d
Postby Garry K » Fri Jan 30, 2015 9:26 pm
Roland,
Send me your user ID and I will extend your trial.
This is a progressive flare - where the treads at the center get progressively larger.
Garry K
Premium Member
Premium Member
Postby db11 » Mon Mar 23, 2015 8:05 pm
Just wanted to register my satisfaction with this plugin. I bought it to help me generate a set of half-spiral stairs for a client project.
The plugin itself is well-done and works flawlessly. But what really impressed me is how well Garry K supports it. He has been tremendously helpful in showing me how to generate output from it that it was not specifically designed to do. (in this case a single central steel stringer)
And with every query —and there were several in my case!— his replies were prompt and on-point. Really a pleasure to deal with.
Highly recommended to anyone who needs to resolve a spiral stair conundrum.
Doug
db11
Postby Garry K » Thu Jun 25, 2015 7:37 pm
Here are 2 more 2D stair videos.
Garry K
Premium Member
Premium Member
Postby Krisidious » Fri Jun 26, 2015 12:13 am
A man after my own heart... Curved Stairs Pro Style...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Garry K » Fri Aug 26, 2016 4:29 pm
Here are a few more videos:
Flattening stringers for machining - CNC or by hand.
Adding finished bottom to stair.
Second method for adding a finished bottom.
Garry K
Premium Member
Premium Member
Postby Garry K » Mon Oct 03, 2016 2:03 pm
New version 1.0.32 now available for download
- Version number now shows up on title bar of web dialog
- Now uses same License strategy as cabmaker
- Check license now first deletes old license and then updates license
- Has preferred setting for users who have license issues
Garry K
Premium Member
Premium Member
Postby garystan » Fri Dec 16, 2016 2:02 am
Sketchucation :
I'm not sure HOW to install this add-on. I'm running Sketchup 8. garystan
garystan
Postby Garry K » Fri Dec 16, 2016 3:58 am
Log on to my website and email me from there. I'll walk you through it.
Garry K
Premium Member
Premium Member
Stair Maker
Postby garystan » Wed Feb 01, 2017 9:38 pm
Hi everybody :
I tried running Stair Maker, Version 1.0.23, and I noticed that it didn't have the OKAY button. Suggestions ?
garystan
garystan
Postby Garry K » Thu Feb 02, 2017 12:03 am
Stair Maker's current version is 1.0.32
Are you sure you installed 1.0.23
What does it say at the top of the form?
Garry K
Premium Member
Premium Member
Postby db11 » Mon Feb 13, 2017 1:19 am
Hi Gary -
I'm wondering if you're planning on adding L and U-shaped stair options to this plugin? It would seem a relatively easy thing, especially compared to what you've already created for spiral stairs.
I've been following your progress on Cabinet Maker, so I realize that you've likely not had a lot of time to devote lately to Stair Maker. It would be great if I could (eventually) use it for all the stairs I model — the majority of which are either U-shaped or L-shaped.
Any word for future development for this one?
db11
Postby Garry K » Mon Feb 13, 2017 6:18 pm
Doug - I do have plans to get back into StairMaker.
L shaped and U shaped stairs are part of my plans (using simple landings). There will probably be additional parameters. I'm also thinking about including a notching point for either side of the stair. Example the top of the stair is between 2 walls and the stair widens after the notching point, possibly changing from housed to sawtooth after the notch.
Garry K
Premium Member
Premium Member
Postby Garry K » Mon Feb 13, 2017 6:22 pm
Another idea that I have is to create elliptical stairs. There are essentially 2 types where the stair starts either at the minor or major axis. These stairs can be made comfortable without having a change of pitch. They can also be made with a continuous change of pitch (bigger challenge - more costly)
Garry K
Premium Member
Premium Member
Postby db11 » Mon Feb 13, 2017 11:15 pm
That's great Gary — looking forward to seeing future Stair Maker development.
db11
Postby Kassul » Tue Feb 19, 2019 11:45 am
Hey Gary K,
I justed download your "stair maker" plugin but i can't use it.
I'm register on your web site but an error message appears on up left corner of the control window "web service error code 101". You can see on the JPEG file.
thank you for your help.
Kassul
Postby Garry K » Thu Feb 21, 2019 2:11 pm
Error 101 means the internet connection time out on your computer. Stairmaker needs to connect to my web service once every week.
Garry K
Premium Member
Premium Member
Previous
Return to Plugins
Users browsing this forum: skhobby and 15 guests
