[Plugin] FloorGenerator ( Updated 6-Apr-2017)
Re: [Plugin] FloorGenerator (Update 2-Jun-2014)
Postby guanjin » Tue Jun 03, 2014 3:16 pm
sdmitch wrote:Posted new version.
Unsuns, I would appreciate it if you would let me take care of my plugins. Thank you.
Each pattern, cannot directly activate command, to repeat the icon to perform。
I come from China, is to learn
guanjin
Postby sdmitch » Tue Jun 03, 2014 4:06 pm
unsuns wrote:Did you test it ?
Now when I select a pattern it closes the window, so I have to reopen to adjust settings and if I select another pattern it's the same.
Apparently not enough!
The .set_on_close had unintended consequences and has been removed. Although it did seem to fix the problem of X'ing out, it, for some bazaar reason, was triggered when the pattern was changed. My bad :puke:
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby unsuns » Tue Jun 03, 2014 6:18 pm
The X-ing problem is back again !
unsuns
Postby sdmitch » Tue Jun 03, 2014 6:52 pm
unsuns wrote:The X-ing problem is back again !
Yes I know and it will be until I can figure out why changing the pattern selection causes the window to close.
Why do you insist on X'ing out of the window? If it is in your way then minimize it.
sdmitch
PluginStore Author
PluginStore Author
Postby jolran » Tue Jun 03, 2014 7:13 pm
Sam I'm looking at your code here. Cant remember which version this is. So you may have changed this behavior.
But in a callback you have a dialog close ?
You have a select with an event onchange:
Code: Select all
<select onChange='patternchanged(value)'>
The function then sends the callback
Code: Select all
function patternchanged(value){
   window.location='skp:PatternChanged@'+value;
In the callback block you have a dlg.close. So everytime select change dialog closes..
Code: Select all
@@dlg.add_action_callback("PatternChanged") {|d,p|
   @@opt=p; puts p
   if @@opt=="Reset" then
                  ["Brick","Tile","Wood","Tweed","Hbone","BsktWv","HpScth","Hexgon","Octgon","Two2One" ,"IrPoly"].each{|o|
  Sketchup.write_default("FloorGenerator",o,nil)};@@opt="Tile";
  @@dlg.close; @@dlg=nil; self.dialog
I also see you have the command self.dialog trying to reopend the dialog ?
But it is set to nil before. Don't know if that messes things up..
Maybe a timing issue ?
jolran
PluginStore Author
PluginStore Author
Postby sdmitch » Tue Jun 03, 2014 7:32 pm
jolran wrote:Sam I'm looking at your code here. Cant remember which version this is. So you may have changed this behavior.
Code: Select all
Code: Select all
Code: Select all
   @@opt=p; puts p
Maybe a timing issue.
Edit: sorry meant to post this in the devlopper forum where you posted specific question. Copied and pasted wrong...
Yes I finally figured that all out. I just had to add a variable that I set to true if the PatternChanged and the window was closed and recreated. I deleted the post to the Developer forum as soon as I figured it out so as not to embarrass my self further.
sdmitch
PluginStore Author
PluginStore Author
Postby jolran » Tue Jun 03, 2014 7:36 pm
Ha ha ! Ah ok! :thumb:
I thought I was getting high or something. One minute I thought I read about it in the developper section, then it was gone. So I removed my last sentence as well, just in case I was wrong :lol: :lol:
jolran
PluginStore Author
PluginStore Author
Postby stagelight » Mon Jun 09, 2014 12:07 am
Thank you for another great plugin !!
This is what I've been working on lately, with your script.
stagelight
Postby sdmitch » Mon Jun 09, 2014 1:16 am
stagelight wrote:Thank you for another great plugin !!
It's a rather funny floor but a very nice bridge.
sdmitch
PluginStore Author
PluginStore Author
Postby djrique » Tue Jun 10, 2014 1:35 pm
Thank you guy for that great plugin. I'm a brazilian and translated it for portuguese. Do you think that it's good?
djrique
Postby sdmitch » Tue Jun 10, 2014 3:18 pm
djrique wrote:Thank you guy for that great plugin. I'm a brazilian and translated it for portuguese. Do you think that it's good?
Good by me.
sdmitch
PluginStore Author
PluginStore Author
Postby djrique » Tue Jun 10, 2014 9:18 pm
Upload .Rb file PT-BR Language: https://drive.google.com/file/d/0BwqiSt ... sp=sharing
i don´t know to create .rbz file... :oops:
THX.
djrique
Postby sdmitch » Wed Jun 11, 2014 2:55 pm
djrique wrote:Upload .Rb file PT-BR Language: https://drive.google.com/file/d/0BwqiSt ... sp=sharing
THX.
An .rbz file is just a .zip file with the extension changed to .rbz
sdmitch
PluginStore Author
PluginStore Author
Postby Mistro11 » Mon Jun 23, 2014 12:06 am
Hope this render reflects my gratitude. :thumb:
i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
Structural Integrity is Not Just Physical...It's in the Design and Purpose
Mistro11
Postby sdmitch » Mon Jun 23, 2014 12:31 am
It's beautiful. Thanks for making me look so good.
sdmitch
PluginStore Author
PluginStore Author
Postby sidewalk » Mon Aug 18, 2014 6:23 pm
Excellent plugin! A tool like this has been on my wishlist for years.
One suggestion: Is it possible to add an exterior clapboard/lap siding setting? The parameters could be very similar to the wood setting.
sidewalk
Postby toto ete » Wed Sep 03, 2014 5:12 pm
great plugin! super work and thanks for sharing it!
keep up the wonderful work!
toto ete
Postby Pixero » Wed Sep 17, 2014 5:55 pm
Suddenly I get the same error as mentioned above.
When I change pattern the window closes.
I've re installed the latest version and tried it on two PCs.
Weird. :?
Pixero
Postby sdmitch » Wed Sep 17, 2014 8:27 pm
Pixero wrote:Suddenly I get the same error as mentioned above.
Weird. :?
That makes no sense at all. Have you installed any new plugins lately? Maybe there is a conflict. Does the Ruby Console show any errors?
sdmitch
PluginStore Author
PluginStore Author
Postby Pixero » Thu Sep 18, 2014 9:34 am
Here is what the console reports:
Code: Select all
Error: #<NoMethodError: undefined method `to_l' for nil:NilClass>
C:/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:93:in `dialog'
C:/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:67:in `initialize'
C:/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:34:in `new'
C:/Users/31jsa/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:34:in `block in <top (required)>'
-e:1:in `call'
As a side note, would it be possible to have a setting for bevel size?
Like if I want half or even a quarter of the size of the bevel.
And some min and max distance of the random imperfections?
I think both are a litte too big for most cases.
Pixero
Postby sdmitch » Thu Sep 18, 2014 2:12 pm
Pixero wrote:Here is what the console reports:
Code: Select all
-e:1:in `call'
The error is occurring when the defaults are being read so use the "Reset" option first and hopefully that will clear up the problem.
I will consider your request as time permits.
sdmitch
PluginStore Author
PluginStore Author
Re: [Plugin] FloorGenerator (Updated 21-Sep-2014)
Postby Mra » Mon Sep 22, 2014 7:24 am
I think there is a bug in the newest verision. On a rectangle it was complaining about non planar faces, even though this was off a box with sketchup box primitive.
Reverting back a version, I was then able to generate a wooden pattern on the same object.
Mra
Postby sdmitch » Mon Sep 22, 2014 3:04 pm
mra wrote:I think there is a bug in the newest verision. On a rectangle it was complaining about non planar faces, even though this was off a box with sketchup box primitive.
I have experienced the same problem with wood on vertical faces. I can't imagine why but will try to sort it out.
Thanks for the heads up
sdmitch
PluginStore Author
PluginStore Author
Postby sdmitch » Mon Sep 22, 2014 8:40 pm
Problem has been fixed. :mrgreen: Quality control and testing director has been severely punished. :puke:
sdmitch
PluginStore Author
PluginStore Author
Postby Mra » Tue Sep 23, 2014 12:36 am
No problem. Thank YOU for such a cool plugin. Can't release images now, but having fun decorating inside of a cafe with wooden panels everywhere. I recommend everyone your plugins.
Mra
Postby deaneau » Sat Sep 27, 2014 10:38 am
Hello,
i would design a special ground with your plugin
here 3 pictures
is this possible with your plugin?
Translation for the picture
A: Big Corner Part
B: Sidewalk Main Part
C Small Corner Part
D: Bishop's cap
measure in cm
25cm=9.8425in
35cm=13.7795in
49,5cm=19.4881in
Gap 1cm=0.3937in
This is a part of a typical sidewalk in Berlin
here a german wiki page
http://de.wikipedia.org/wiki/Pflaster_(Belag)
Thank you
Dean
-1
MADE, BORN AND LIVING IN BERLIN
Big Thank You to all Programmers
Some German words are so long that they have a perspective. M.Twain
deaneau
Postby sdmitch » Sat Sep 27, 2014 2:58 pm
It might be possible, in part at least, for a perfect size face but doubtful for a random size face. I'll see what I can do.
sdmitch
PluginStore Author
PluginStore Author
Postby deaneau » Sat Sep 27, 2014 3:24 pm
sdmitch wrote:It might be possible, in part at least, for a perfect size face but doubtful for a random size face. I'll see what I can do.
that would be great,
if you need a sketchup file i can send this via PM
can i use this in a curve,too?
thank you dean
deaneau
Postby sdmitch » Sat Sep 27, 2014 5:59 pm
thank you dean
Please do. I hate trying to guess.
sdmitch
PluginStore Author
PluginStore Author
Postby deaneau » Sat Sep 27, 2014 6:57 pm
Suggestion for different Texture Packs.
what do you think about different texture pack.
in the texture folder i have different folders with diferent textures.
this could be selected via dropdown.
thank you Dean
deaneau
PreviousNext
Return to Plugins
Users browsing this forum: edgarrlp, lpfurtado, volandon, yonas_arqp and 10 guests
