[Plugin] FloorGenerator ( Updated 6-Apr-2017)
Re: [Plugin] FloorGenerator ( Updated 6-Apr-2017)
Postby Einstein » Sat Jan 06, 2018 4:35 pm
Hi! I think I had the same problem as c3dx and gizeh33 - nothing happened when I clicked the toolbar button. Now I downloaded the latest version from http://sdmitch.blogspot.com/ and it's working. Please update the newest version into Plugin Store if you can.
Einstein
Postby sdmitch » Sat Jan 06, 2018 4:57 pm
Einstein wrote:Hi! I think I had the same problem as c3dx and gizeh33 - nothing happened when I clicked the toolbar button. Now I downloaded the latest version from http://sdmitch.blogspot.com/ and it's working. Please update the newest version into Plugin Store if you can.
The plugin store and blog versions are the same.
sdmitch
PluginStore Author
PluginStore Author
Postby TraxXx » Tue Mar 27, 2018 10:19 am
Hi Sam !
Thanks for the wonderful plugin first of all, that's really helpful ! I have two questions concerning the wood pattern, would it be possible to make continuous wood planks without any cuts ? I tried to increase the lenght value so it's higher than the maximum height of my volume to cover with planks but I'm still getting cuts.
I'm actually working on a house project extension. The original house has single lenghts planks going from floor to roof with three differents width of 7, 13 and 20 cm. Yet, your plugin seems to be the most appropriate to complete this task regarding the fact that I need the same spacing between the planks. But i'm looking for a way to lay planks of these precise widths, randomly against my volume. Your plugin is creating random width which provides me with a close result but not what I meant to do. I hope I'm being clear in my explanation...
I guess there must be a way to achieve that with maybe several plugins, but couldn't find the way. I also tried creating these 3 different planks as components and spray them along line with compospray, but this one doesn't allow me to control the spacing and doesn't adjust the planks top to my shape as your plugin does... Each plugin shows limits for this task and I'm afraid my request is a bit too difficult to solve... But still I'm asking in case of I can avoid making planks one by one :D
Hope you can help :) Thanks !
TraxXx
Postby sdmitch » Tue Mar 27, 2018 5:50 pm
One should never say never but modifying FloorGenerator to allow multiple wood widths is as close as you can get. Sorry but I just don't see it happening.
sdmitch
PluginStore Author
PluginStore Author
Postby TraxXx » Thu Mar 29, 2018 10:31 am
At least I tried ! :D And what about the gaps ? Can I avoid them to happen on the planks smallest sides ? Like continuous planks from floor to roof ? Or does it have to be necessarily linked to the longest sides gaps value ?
TraxXx
Postby sdmitch » Thu Mar 29, 2018 5:14 pm
TraxXx wrote:At least I tried ! :D And what about the gaps ? Can I avoid them to happen on the planks smallest sides ? Like continuous planks from floor to roof ? Or does it have to be necessarily linked to the longest sides gaps value ?
Yes, the gap is the same on all sides.
sdmitch
PluginStore Author
PluginStore Author
Postby awei711 » Sat Mar 31, 2018 1:44 pm
it's good, thanks!
awei711
Postby Kuzmic » Fri May 11, 2018 5:54 pm
The Rand Tex Material Picker isn't letting me select materials from a folder or the model.
Kuzmic
Postby sdmitch » Mon May 14, 2018 8:39 pm
Kuzmic wrote:The Rand Tex Material Picker isn't letting me select materials from a folder or the model.
Operator error obviously.
sdmitch
PluginStore Author
PluginStore Author
Postby CreaVivaCity » Fri Jun 08, 2018 9:13 am
Why, I can't load plugin in SU 2018 (Unrestricted)
Can Anyone help me?
CreaVivaCity
Postby jenujacob » Tue Jun 19, 2018 5:36 pm
this saved my backside today! thanks Sdmitch!
jenujacob
Postby filipeoconde » Wed Jul 18, 2018 3:29 pm
Firstly, thanks a lot sdmitch! Excellent plugin!
I'd like to suggest a feature - or maybe ask for help if I'm not using it properly!
When using a material with a bump image (in V-Ray), the FlrGen tends to rotate the texture but not its bump. Is it right? Should I've been doing something different?
Thanks a lot,
filipeoconde.
filipeoconde
Postby juju » Wed Jul 18, 2018 4:34 pm
filipeoconde wrote:Firstly, thanks a lot sdmitch! Excellent plugin!
Thanks a lot,
filipeoconde.
I may be wrong, but as far as I know SU only handles a single texture per surface. If you have bump maps linked to a texture, that is normally handled by the rendering software you use, in which case the problem probably isn't with FloorGenerator, or SU for that matter, but rather with your rendering software?
juju
Premium Member
Premium Member
Postby dimashariyanto » Thu Sep 06, 2018 9:52 am
where i can download this plugin? i have been download from the site http://sdmitch.blogspot.com/ but wan't work.. thanks
dimashariyanto
Postby sdmitch » Fri Sep 07, 2018 4:00 pm
dimashariyanto wrote:where i can download this plugin? i have been download from the site http://sdmitch.blogspot.com/ but wan't work.. thanks
I have removed the plugin from the blog and plugin store because I have received a complaint regarding Copyright infringement.
sdmitch
PluginStore Author
PluginStore Author
Postby qishta » Tue Sep 11, 2018 2:11 pm
Thanks a lot sdmitch, the plugin seems to be very powerful!! but how could we get it.
qishta
Postby utiler » Mon Sep 24, 2018 2:21 am
Really, copyright infringement??? I don't know of any other plugin that does this, Sam... that's disappointing that you have to do this.
Where has the complaint come from??
utiler
Top SketchUcator
Postby sdmitch » Tue Sep 25, 2018 3:01 pm
utiler wrote:Where has the complaint come from??
Apparently from Trimble and I still have no idea why or what the complaint is about.
sdmitch
PluginStore Author
PluginStore Author
Postby TIG » Tue Sep 25, 2018 4:19 pm
Why not email Chris Fullmer at SketchUp, and ask him to investigate this...
Apart from my earlier comments about you not implicitly crediting one of the several authors of the 'copied' VoronoiXY code, I can see no reason to consider any © infringement...
Global Moderator
Postby Wolfarelli » Tue Sep 25, 2018 7:29 pm
While this gets sorted out, would someone upload the last version somewhere, please?
Wolfarelli
Postby jenujacob » Thu Sep 27, 2018 10:24 pm
what bollocks!!!!!
copyright infringement - bah humbug!
nothing that a conversation over a cold beer couldnt solve i am sure!!!!
jenujacob
Postby cariothida » Tue Oct 02, 2018 10:17 am
Sad, wanted to download it. If someone have an RBZ file please email me at cariothida @ gmail . com
cariothida
Postby kendyfox » Fri Oct 05, 2018 9:34 pm
Please am new here, how can I get this floor plugin? Please help
kendyfox
Postby kendyfox » Fri Oct 05, 2018 9:43 pm
I wanted to download it but to no avail. If someone have an RBZ file please email me at kendyfox @ gmail . com
kendyfox
Postby Liewe » Mon Oct 08, 2018 9:27 am
How sad that this plugin can no longer be downloaded. :( :(
Does anyone have an alternative plugin that can do the same thing?
Or can I find the floorgenerator in another way?
Liewe
Postby juju » Mon Oct 08, 2018 11:48 am
Liewe wrote:How sad that this plugin can no longer be downloaded. :( :(
Something similar, but different in a number of ways at the same time:
OOB LAYOUTS
The unfortunate thing is sdmitch has always been helpful with plugins / extensions, this incident has triggered something and the subsequent cause (I believe) of him "hanging up his coding gloves".
juju
Premium Member
Premium Member
Postby Liewe » Tue Oct 09, 2018 2:51 pm
Thanks a lot for the tip of OOB Layouts. It seems a good solution for what I need.
Is it possible to 3D print the house, when this plugin was used?
Liewe
Postby juju » Tue Oct 09, 2018 7:30 pm
Liewe wrote:Thanks a lot for the tip of OOB Layouts. It seems a good solution for what I need.
:thumb: I have no experience with 3D printing, so unfortunately cannot help / comment in this regard.
juju
Premium Member
Premium Member
Postby dbalex » Fri Oct 12, 2018 12:42 pm
Can someone send me the plugin?
dbalex
Postby adi196 » Fri Nov 30, 2018 8:28 pm
acnpolska@gmail.com
adi196
PreviousNext
Return to Plugins
Users browsing this forum: Lycan4, PSKW and 17 guests
