[Plugin] FloorGenerator ( Updated 6-Apr-2017)
Re: [Plugin] FloorGenerator (Final Update 30-Jun-2015)
Postby sdmitch » Thu Apr 06, 2017 4:26 pm
rogalxxx wrote:here, Floor generator on stock settings, two identical planes-second one with tiles applied.
looks like geometry has some random lines and faces, even though I have set no random parameter.
I retested FloorGenerator in SU2017 using your model and, in 16 tests, 5 appeared to be normal, 1 had a single tile missing and the other 10 had several missing in random locations.
My initial test seemed ok because I stupidly used the Random Colors option.
I will do what I can to fix this problem.
GOOD NEWS!!!! Once again it seems that the problem is the same old group explode redefining the ID of the selected face. Updated version now available in Plugin Store and my blog.
4
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby sdmitch » Thu Apr 06, 2017 7:45 pm
sdmitch
PluginStore Author
PluginStore Author
Postby rogalxxx » Thu Apr 06, 2017 9:54 pm
sdmitch you are awesome! Thank you. Glad I could contribute! :D
rogalxxx
Postby pilou » Thu Apr 06, 2017 11:22 pm
Infinite walk to the perfection! :fro:
Speedy Galerie
Top SketchUcator
Postby enigmatic » Fri Apr 07, 2017 7:09 pm
Sam, you rescue me from a big trouble. Very thanks.
enigmatic
Premium Member
Premium Member
Re: [Plugin] FloorGenerator ( Updated 6-Apr-2017)
Postby rogalxxx » Sun Apr 09, 2017 5:39 am
why is there no option for an origin point where you click? Why center or left lower corner only? I mean this would be useful :)
rogalxxx
Postby sdmitch » Sun Apr 09, 2017 2:17 pm
rogalxxx wrote:why is there no option for an origin point where you click? Why center or left lower corner only? I mean this would be useful :)
Because I assumed that the center or a corner were the most logical points of origin. FYI, the closest corner to the point you pick is used. Not just the lower left corner.
sdmitch
PluginStore Author
PluginStore Author
Postby markpyvi » Mon Apr 10, 2017 6:17 am
Can I please have a link for SU7. Latest one doesn't seem to work in SU7.
Cheers,
Mark
markpyvi
Postby sdmitch » Mon Apr 10, 2017 1:49 pm
markpyvi wrote:Can I please have a link for SU7. Latest one doesn't seem to work in SU7.
Cheers,
Mark
Sorry I can't. There is only one version.
sdmitch
PluginStore Author
PluginStore Author
Postby pilou » Mon Apr 10, 2017 2:10 pm
seems working perfectly in 2017! :enlight:
Speedy Galerie
Top SketchUcator
Postby sdmitch » Mon Apr 10, 2017 4:09 pm
pilou wrote:seems working perfectly in 2017! :enlight:
I think he has version 7 not 2017.
sdmitch
PluginStore Author
PluginStore Author
Postby markpyvi » Tue Apr 11, 2017 5:56 am
Cheers,
Mark
Ok, no worries, will use 2017 for this step. Cheers.
markpyvi
Postby marche3d » Sat May 27, 2017 2:22 am
Hello could you tell me how to install it please...!!!!
marche3d
Postby TIG » Mon May 29, 2017 12:36 pm
marche3d wrote:Hello could you tell me how to install it please...!!!!
Most Plugins and Extensions' RBZs can be downloaded from the SketchUcation PluginStore:
https://sketchucation.com/pluginstore?p ... rGenerator
Have a browse and be amazed...
Use the native Extension Manager to install them.
Alternatively download and install the SketchUcation ExtensionStore³, then you can browse and auto-install extensions directly from with SketchUp itself - sidestepping the download part altogether...
Global Moderator
Postby c3dx » Tue Jun 13, 2017 3:57 pm
Just can't make it work, the command window never show up
I reayly like to make it run.....
There is what i get when i try to run it
SystemStackError: stack level too deep
I do have Sketchup 2017 Version 17.21.2555 64 bit
On windows 10 professionnel version 1703(15063.332)(French Version)
I have Thearender for sketchup plugins install
Graphic card: GTX 1060
CPU: AMD FX-6300
8 gig off ram
i have this message in the console
i also have this line appears many many time before the error
read_default failed
Error: #<SystemStackError: stack level too deep>
C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in `initialize'
C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in `method_missing'
C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:162:in `update_wd'
C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:174:in `rescue in update_wd'
C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:160:in `update_wd'
C:/Users/c3dx/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/SDM_FloorGenerator.rb:170:in `rescue in update_wd'
c3dx
Postby pilou » Tue Jun 13, 2017 5:17 pm
Works fine for me with new Window 10 "creative" (French) not Pro but Familly! :)
Have you some accents on the paths Folders ?
Have you install it from the "Red Ruby" Menu from Sketchup ?
Speedy Galerie
Top SketchUcator
Postby TIG » Tue Jun 13, 2017 6:39 pm
@c3dx
These read_/write_default errors [and many more] might be because you have not initially installed SketchUp correctly.
Thereby stopping you/SketchUp accessing the Registry properly.
Here is how to install SketchUp properly...
Find the SketchUp installer's exe file - probably in your Downloads folder.
Select its icon, right-click, context-menu, "Run as administrator"...
This will ensure it's correctly installed, and that you and the app now have proper permissions set up.
If you already have SketchUp installed you probably do not need to uninstall/reinstall it - firstly try this...
Close SketchUp.
Use "Run as administrator" on the installer's exe file, as explained above...
When prompted choose "Repair"...
This should fix issues.
Report back...
Global Moderator
Postby c3dx » Mon Jun 19, 2017 8:17 pm
TIG wrote:@c3dx
Close SketchUp.
Report back...
Thanks Tig
But i just reinstall it with the repair option as administrator but i still have the same result...
i will try to uninstall everything and try it again....
i don't know if it can have something to do with it , i had system mechanic running on it before, may be it did change some rule somewhere about the ability to read the registry....
c3dx
Postby c3dx » Tue Jun 20, 2017 10:06 pm
pilou wrote:Works fine for me with new Window 10 "creative" (French) not Pro but Familly! :)
Yes i did install it with the Red Ruby Menu from sketchup, i have a lap top and its not working there to, same result.... i really dont know why, this plugin can really help me....if i can make it work
I dont have any accent in my path....
c3dx
Postby TIG » Tue Jun 20, 2017 10:56 pm
Your earlier post suggested that you have messed around with the Registry settings.
SketchUp, and some of its plugins need to write and read values from the Registry - so they are remembered across sessions...
If that ability has been limited you will get problems !
What did you do :shock:
Global Moderator
Postby sdmitch » Fri Jun 23, 2017 6:42 pm
Previous versions of SDM_FloorGenerator had a problem with reading defaults from the registry when new pattern options had been added but I believe I finally fixed that problem in the May2017 release. Make sure you have the latest version.
sdmitch
PluginStore Author
PluginStore Author
Postby utiler » Sun Jun 25, 2017 7:07 am
Hi Sam, just have a question about what's going on here...
When I select the random texture option and select the source of the textures, I select a .skm file then I get a material picker dialogue box showing on the screen that has nothing but a select button.
Any suggestions?
Edit: I have loaded the latest rbz file by the way....
utiler
Top SketchUcator
Postby sdmitch » Sun Jun 25, 2017 3:53 pm
utiler wrote:Hi Sam, just have a question about what's going on here...
Any suggestions?
The random texture option is not designed to use .skm files only .jpg,.png,.etc.
sdmitch
PluginStore Author
PluginStore Author
Postby utiler » Mon Jun 26, 2017 12:24 am
No worries. ta.
utiler
Top SketchUcator
Postby c3dx » Tue Jul 18, 2017 4:21 pm
TIG wrote:Your earlier post suggested that you have messed around with the Registry settings.
I really dont know, i never go in there to change value or key's, that's why i suspect System Mechanic
c3dx
Postby gizeh33 » Fri Sep 22, 2017 8:32 pm
doesnt work on sketchup 17 mac os. it is installed but starting the tool results in nothing
gizeh33
Postby sdmitch » Mon Sep 25, 2017 8:32 pm
gizeh33 wrote:doesnt work on sketchup 17 mac os. it is installed but starting the tool results in nothing
Any errors output to the Ruby Console?
sdmitch
PluginStore Author
PluginStore Author
Postby Areczan » Wed Oct 11, 2017 10:05 am
Hello everyone.
I'm trying to figure out what I'm doing wrong using Floor Generator. I wanted to apply a pack of textures to random tiles using BRICK function. However, what i get is not exactly what I need. The texture seems to be rotated which is not cool as I'm using 550x3402 pix images and want to create 194x1200 mm tiles.
My settings and the view from Sketchup in files attached.
I'm using SU 2017
Thanks for any ideas for what I could do differently here.
Areczan
Postby wingedhippo » Tue Oct 24, 2017 2:57 pm
Hello, I understand that Floor Generator is no longer being developed, but I would like to ask how to override or turn off "clapboard pattern can only be placed on a vertical face"? I have a model that is created from rotated and/or scaled components to save building time, so while the faces are "vertical" in appearance they may not be according to Sketchup axis... Even when exploding I still get this error (blue axis is up)...
wingedhippo
Postby Zin Min Tun » Sun Dec 03, 2017 9:18 am
Thanks you SDM.But I cannot download it.
Zin Min Tun
PreviousNext
Return to Plugins
Users browsing this forum: No registered users and 7 guests
