[Plugin] FloorGenerator ( Updated 6-Apr-2017)
Re: [Plugin] FloorGenerator (Final Update 30-Jun-2015)
Postby sdmitch » Mon Aug 08, 2016 5:19 pm
gnome_mo wrote:Mitch, I can't thank you enough.
I feel kinda stupid to ask this, but I can't figure it out:
I would like to make tiles or wood like this picture. I've made it "by hand" but I'm sure you have settings to make it like this (next row is half length moved). Is it possible?
Use the 'Brick' pattern or 'Tile' pattern with 50% offset.
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby mumbus » Wed Aug 17, 2016 10:07 pm
First off let me say that this plugin is amazing and I use it often. I do have a question about it. Often times when I am generating a floor with a wood material already attached to the surface, it rotates the texture 90 degrees when it completes the floor. So the texture ends up running perpendicular to the board. I have tried various solutions like rotating the texture 90 degrees before running the plugin, reinserted the texture, etc. Any thoughts on this?
Thanks!
mumbus
Postby sdmitch » Thu Aug 18, 2016 1:23 am
mumbus wrote:First off let me say that this plugin is amazing and I use it often. I do have a question about it. Often times when I am generating a floor with a wood material already attached to the surface, it rotates the texture 90 degrees when it completes the floor. So the texture ends up running perpendicular to the board. I have tried various solutions like rotating the texture 90 degrees before running the plugin, reinserted the texture, etc. Any thoughts on this?
Thanks!
The plugin doesn't do any UV mapping of the existing material so each "board" is treated as an independent face with the material applied to each just as if you did it manually.
sdmitch
PluginStore Author
PluginStore Author
Postby mumbus » Thu Aug 18, 2016 5:22 pm
Perhaps I am not explaining myself properly. I have attached an animated .gif as an example. I use this to randomly distribute the texture around the boards.
mumbus
Postby sdmitch » Fri Aug 19, 2016 12:54 am
If you want the "Wood" pattern to look just like the face with the material applied then you have to map the texture to each face that is created by FloorGenerator.
sdmitch
PluginStore Author
PluginStore Author
Postby devrimimar » Mon Oct 31, 2016 5:15 pm
I downloaded several times but It does not work? Any idea ?
devrimimar
Postby sdmitch » Tue Nov 01, 2016 5:21 pm
devrimimar wrote:I downloaded several times but It does not work? Any idea ?
No, but if you want to provide a little more information like Sketchup version, where you are downloading from, where are you downloading to, Ruby Console output when trying to use, etc., I might be able to help.
sdmitch
PluginStore Author
PluginStore Author
Postby Mousa_SA » Fri Feb 03, 2017 6:30 pm
Hello Sdmitch,
Firstly thanks for this great plugin, it is very useful, I have a feature request and I would be appreciated if you can add it to your plugin.
V-ray 3.4 for Sketchup have a features is called MultiSubTex and TriPlanar, these features will add a ability to random the texture for the same component after rendering (in V-ray Frame Buffer), so it will be great if your plugin have an option to make similar tiles as component, that will reduce the file size in some cases, Note it will put the tiles which have been cut (by the face boundary) in one group, So what so you think ?
Mousa_SA
Postby sdmitch » Sat Feb 04, 2017 8:50 pm
Sorry, but I think not.
sdmitch
PluginStore Author
PluginStore Author
Postby deaneau » Tue Feb 07, 2017 1:41 am
@Mousa_SA is this a post rendering effect?
I think a good way is to provide the developers with pictures. not all dev´s have all plugins on the disk. vray is really a little bit special. i like that some render engine developer provide sketchup. what do you think about to ask the vray developer,too?
@sdmitch i must repeat me by myself... your "small" plugins will be every time helpful. some plugins i use every time when i have a project with sidewalks etc. or when i have an other problem ;-)
some plugins i will never missing. nice that you have now an email contact address.
i will tell you a thank you.
Dean
MADE, BORN AND LIVING IN BERLIN
Big Thank You to all Programmers
Some German words are so long that they have a perspective. M.Twain
deaneau
Postby Mousa_SA » Wed Feb 08, 2017 10:33 pm
deaneau wrote:@Mousa_SA is this a post rendering effect?
Dean
Yes Dean, you can say that, in Sketchup 2017 it's has an object IDs Feature, so Chaos group will implement MultiSubTex, you can read more about it here:
https://docs.chaosgroup.com/display/VRA ... ltiSub+Tex
And Ithil made this tutorial for the TexTriplaner Feature:
https://www.youtube.com/watch?v=VVD_UfJA5Hc
sdmitch, maybe that deserve another look !
Mousa_SA
Postby yourpasswordis » Wed Mar 08, 2017 10:06 pm
I saw it posted on the first page of this plugin, a LAP setting would be AMAZING.
I'm in Architectural Visualization and material properties don't allow for accurate displacement maps. A plugin like this is tantalizingly close to creating the repeating clap/lap siding which our pro-user group needs. Sketchup has been blessed with rendering engines but this modelling aid is missing!
The difference between good enough and awesome is huge
yourpasswordis
Premium Member
Premium Member
Postby sdmitch » Thu Mar 09, 2017 4:47 pm
yourpasswordis wrote:a LAP setting would be AMAZING.
I did try to develop a clapboard option several years ago but never produced a satisfactory one. Perhaps it would be worth another look.
sdmitch
PluginStore Author
PluginStore Author
Postby seghier » Thu Mar 16, 2017 5:01 am
hello
where is the link ?
seghier
Postby pilou » Thu Mar 16, 2017 10:53 am
You will find Floor Generator here! ;)
http://sdmitch.blogspot.fr/
Speedy Galerie
Top SketchUcator
Postby meegg » Tue Mar 28, 2017 8:39 am
Your plugin is amazing. Thank You.
Is there a possibility to make some additional options in octagons pattern? Option to give the size of two tiles: the big one and the smaller one. It would be very helpful.
meegg
Postby sdmitch » Tue Mar 28, 2017 4:12 pm
meegg wrote:Your plugin is amazing. Thank You.
Have you looked at the "Hopscotch" patterns?
sdmitch
PluginStore Author
PluginStore Author
Postby sdmitch » Tue Mar 28, 2017 4:18 pm
yourpasswordis wrote:I saw it posted on the first page of this plugin, a LAP setting would be AMAZING.
A basic "Clapboard" option has been added.
sdmitch
PluginStore Author
PluginStore Author
Postby peerman » Wed Mar 29, 2017 10:53 am
That is great!! Thank you for the LAP addition!
iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
peerman
Postby meegg » Thu Mar 30, 2017 1:37 pm
"Hopscotch" pattern doesn't fit ;-)
It must be octagonal pattern but with specific dimensions of two tiles: the big one - octagonal and smaller one - square tile.
meegg
Postby rogalxxx » Thu Mar 30, 2017 8:24 pm
I'm having problems with the plugin in SU 2017. Su 2015 seems to be working fine.
Using even stock settings I get a lot of random tiles missing.
rogalxxx
Postby sdmitch » Fri Mar 31, 2017 6:13 pm
Once again SU2017 is acting in a different way than previous versions. Maybe there is a solution but I doubt it.
sdmitch
PluginStore Author
PluginStore Author
Postby pilou » Fri Mar 31, 2017 11:24 pm
So have 2015, 2016, 2017 is a good thing! ;)
(and that divide by 3 number of plugins (if distributed) for a more speed launch) :ugeek:
Speedy Galerie
Top SketchUcator
Postby rogalxxx » Wed Apr 05, 2017 1:44 pm
so, no cure for this bug? any chance It will be patched?
Any other plugin that can generate nice tiles?
rogalxxx
Postby pilou » Wed Apr 05, 2017 2:15 pm
Protrude by Jim + Lattice Maker by TIG + FredoScale by Fredo?
Speedy Galerie
Top SketchUcator
Postby enigmatic » Wed Apr 05, 2017 3:15 pm
rogalxxx wrote:I'm having problems with the plugin in SU 2017. Su 2015 seems to be working fine.
I have that same problem.Is there a solution?
Murat
enigmatic
Premium Member
Premium Member
Postby juju » Wed Apr 05, 2017 3:21 pm
You could always do a work-around by saving the SKP in 2016 version, open SU2016, do what you want there with the plugin, save and open in 2017 again. I know, far from ideal.
Who has any experience with Oob Layouts? It also reports only compatible up to 2015, but I have often had where extensions say that and work fine in the later (supposedly incompatible) SU version. Anybody willing to trial it?
juju
Premium Member
Premium Member
Postby sdmitch » Wed Apr 05, 2017 4:18 pm
I have tested FloorGenerator in SU2017 and had no problem with missing tiles.
Could you post your model so I could test it myself?
sdmitch
PluginStore Author
PluginStore Author
Postby rogalxxx » Wed Apr 05, 2017 10:12 pm
here, Floor generator on stock settings, two identical planes-second one with tiles applied.
looks like geometry has some random lines and faces, even though I have set no random parameter.
rogalxxx
Postby Mousa_SA » Thu Apr 06, 2017 3:57 pm
I confirm, this issue is happening with me too,although there are no other plugins are active with it.
Mousa_SA
PreviousNext
Return to Plugins
Users browsing this forum: 60NC4L0, jessicasewald, jona0123, jumpjack, KOZLOWSKA and 11 guests
